#21
Apparently, there were three infants also on board.
"Flyingmonk" wrote in message oups.com... This source saids 19 dead, but it also saids 14 plus two crews were on board, huh? Doesn't that equal 16? |
Toks wrote:
Perfect evidence on why you shouldn't trust media that much! Well, I never really trusted them. |
Jim Macklin wrote:
My guess is that they had a loose or broken fuel line, caught fire and the fuel vapor exploded and the fire melted the spar enough for it to fail.. The airplane seems to have been very sturdy, since the fuselage is intact after the impact. Any information as to what altitude they were cruising at? It seems like it would take a minute or more to soften a spar enough to fail, but maybe the pilot wasn't aware he had a problem in time. Then again, it may have been something else entirely. I wonder if they could have hit a gull or something like that also and cause a problem. Matt |
Jay Honeck wrote:
My guess is that they had a loose or broken fuel line, caught fire and the fuel vapor exploded and the fire melted the spar enough for it to fail. Boy, I sure hope that's "all" it was. (Who'd ever think we'd be saying that kind of stuff?) With everyone describing an "explosion" (which the video tends to support) -- and Chalk's not having to do much in the way of security screening, as a small carrier -- this could easily have been some kind of a nut-job with a shoe bomb and a "cause". That seems unlikely as the video seems to show the fuselage pretty well intact and the wing separated. Unless the wing has a luggage locker, I doubt it was a bomb. Matt |
Jim Macklin wrote:
The airplane seems to have been very sturdy, since the fuselage is intact after the impact. There were excellent reasons for people calling Grumman "The Ironworks." George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
Flyingmonk wrote:
This source saids 19 dead, but it also saids 14 plus two crews were on board, huh? Doesn't that equal 16? Plus several infants. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
More likely that a fuel line was not properly safetied or
otherwise failed. Turbine engines have fuel pressures as high a 1,000 PSI, so the fuel system in the engine is highly stressed. The fuel supply pumps are high capacity and 50 to 100 PSI, so again, the fuel connections and lines are stressed. If there was a fuel leak into the nacelle, wing root area, any source of ignition could cause an explosion and the resulting fire would soften the aluminum spar quickly. The emergency procedure for a fire is to shut off the fuel valves, but if the failure was between the tank and fuel tank or the valve was damaged, it might not be possible to shut the fuel off. The NTSB is very good at investigating this type of failure, the will track melted and bent metal, see the pattern of soot and follow the fractures in the metal. -- James H. Macklin ATP,CFI,A&P -- Merry Christmas Have a Safe and Happy New Year Live Long and Prosper Jim Macklin "Otis Winslow" wrote in message ... | I'm wondering if fitting turbine engines on the old airframes | didn't pull something loose in the wing/mount. | | This thing's just a heart breaker. I see them flying all the | time when I'm in Miami. They've been flying off Watson Island | forever. I've always thought it would be fun to fly with them | over to the Bahamas. | | | Jim Macklin wrote: | My guess is that they had a loose or broken fuel line, | caught fire and the fuel vapor exploded and the fire melted | the spar enough for it to fail.. The airplane seems to have | been very sturdy, since the fuselage is intact after the | impact. | | Thanks. | | |
Bird strikes are common, but Grumman was called the Iron
Works for a reason, they built tough airplanes. Aluminum melts at 1100 degrees F and has lost most of its strength at 500 degrees. Kerosene fire is high heat and energy, failure could happen in 10-15 seconds [guess]. -- James H. Macklin ATP,CFI,A&P -- Merry Christmas Have a Safe and Happy New Year Live Long and Prosper Jim Macklin "Matt Whiting" wrote in message ... | Jim Macklin wrote: | My guess is that they had a loose or broken fuel line, | caught fire and the fuel vapor exploded and the fire melted | the spar enough for it to fail.. The airplane seems to have | been very sturdy, since the fuselage is intact after the | impact. | | Any information as to what altitude they were cruising at? It seems | like it would take a minute or more to soften a spar enough to fail, but | maybe the pilot wasn't aware he had a problem in time. Then again, it | may have been something else entirely. I wonder if they could have hit | a gull or something like that also and cause a problem. | | | Matt |
#29
Grumman and Republic both built tough airplanes.
-- James H. Macklin ATP,CFI,A&P "George Patterson" wrote in message news ![]() | Jim Macklin wrote: | | The airplane seems to have | been very sturdy, since the fuselage is intact after the | impact. | | There were excellent reasons for people calling Grumman "The Ironworks." | | George Patterson | Coffee is only a way of stealing time that should by rights belong to | your slightly older self. |
#30
didn't pull something loose in the wing/mount. Turbines run a whole lot smoother than the round Pratts that were on originally. They don't have the power pulses that radial engines have. I'd agree with the other posters that it sounds more like a leaking/broken fuel fitting that went bad, ignited and led to structural failure. |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Seaplane Rating Add-On and Seaplane Rental | Peter Bauer | Piloting | 10 | May 29th 05 11:53 AM |
American Lake SPB Closing | C J Campbell | Piloting | 23 | December 27th 04 03:26 PM |
Copalis Beach State Airport threatened? | C J Campbell | Piloting | 1 | April 14th 04 10:04 PM |
How I got to Oshkosh (long) | Doug | Owning | 2 | August 18th 03 12:05 AM |
