see four-point sockets
Old January 4th 06, 02:49 PM posted to rec.crafts.metalworking,rec.autos.tech,rec.aviation.homebuilt
Default see four-point sockets
Roger wrote:
On 3 Jan 2006 11:39:10 -0800, wrote:
four point (square) sockets (and/or wrenches)
who makes them, who retails 'em?
Who on an aviation group uses "FARMER BOLTS" :-))
I've never see a 4-pt socket, but open end wrences work well. Usually
the bolt is of such quality you can plan on twisting it off rather
then getting the nut off.
Good luck,
www.rogerhalstead.com
I don't know about more modern cars, but on my old Studebakers there's
quite a few pipe plugs that have square heads.
nate
Old January 4th 06, 03:43 PM posted to rec.crafts.metalworking,rec.autos.tech,rec.aviation.homebuilt
Default see 5-point sockets
On Wed, 04 Jan 2006 05:53:00 GMT, "Stephen H"
Looked real hard at the nut... I'll be dammed a 5-point nut.
Where the hell did that come from.
Fire hydrant ?
Old January 4th 06, 04:46 PM posted to rec.crafts.metalworking,rec.autos.tech,rec.aviation.homebuilt
Leatherman Multitools
My wave has a 5 point security bit
Fire hydrant ?
Old January 4th 06, 07:54 PM posted to rec.crafts.metalworking,rec.autos.tech,rec.aviation.homebuilt
In article .com,
says...
My craftsman tool set came with a few square sockets. I haven't checked, but I
would assume that they also sell them individualy.
Alex
Old January 4th 06, 08:07 PM posted to rec.crafts.metalworking,rec.autos.tech,rec.aviation.homebuilt
"Fred May" wrote in message
news:PGAuf.5198$WX3.947@trndny09...
They sell 8 point, not 4 point sockets, perhaps that is why you cant
find them.
Regards
Phredd
A couple sets came with my Craftsman 900 pc set. I'd check your local
Sears
Phredd sed: "perhaps that is why you cant find them"
Just like I said "A couple sets came with my Craftsman 900 pc set". Alex
seems to have the same set. Is there a problem?
Old January 4th 06, 10:46 PM posted to rec.aviation.homebuilt
Working on Dodge caravan the other day, couldn't get my 19mm to fit and the
20 was too large. Went to the sae set, nothing would fit.. Looked real hard
The electric company uses them here to secure the lids on in-ground
boxes. Regular 1/2" bolt with pentagon head.
Old January 4th 06, 11:46 PM posted to rec.crafts.metalworking,rec.autos.tech,rec.aviation.homebuilt
According to Roger :
If you check the headers, you will see that this is cross-posted
to rec.crafts.metalworking and rec.autos.tech as well as your newsgroup.
Enjoy,
DoN.
Email: | Voice (all times): (703) 938-4564
(too) near Washington D.C. |
http://www.d-and-d.com/dnichols/DoN.html
--- Black Holes are where God is dividing by zero ---
Old January 4th 06, 11:54 PM posted to rec.crafts.metalworking,rec.autos.tech,rec.aviation.homebuilt
This has been going on for so long that I can't resist a "tool gloat".
Two years ago I picked up at a fles market 3 new old stock 9 piece 1/2"
drive 8 popint socket sets for $25. Don't bother they are all gone
except for the one I kept.
Chuck P.
  #29
Old January 5th 06, 01:21 AM posted to rec.crafts.metalworking,rec.autos.tech,rec.aviation.homebuilt
Morgans wrote:
"Stephen H" wrote in message
older Dodge Caravan (grand?) , but the round body style Late 90's I think
2.4 4cly, it held the upper motor mount together (pointing the same
direction the cam did)
Didn't actually have to remove it; and according to another tech it's a
Chrysler special tool. I wouldn't buy a set yet!
Oh, the BF Vise grip tool, or the BFH and cold chisel? Sounds like what I
would end up using! g
Of course, then there is the fire ax or the sawz-all!
BF oxy acetylene, LF dremel
  #30
Old January 5th 06, 01:44 AM posted to rec.crafts.metalworking,rec.autos.tech,rec.aviation.homebuilt
What're BF, BFH and LF?
The Monk
Adding a lifting point. [email protected] Home Built 1 March 8th 05 03:05 PM
A Question For Real Airline Pilots Blue Simulators 34 September 6th 04 01:55 AM
flight training - 100nm night flight requirement Jonathan Piloting 36 May 11th 04 07:34 PM
How fast should an ADF point? Ben Jackson Instrument Flight Rules 6 November 21st 03 03:50 AM
Reaming needed on aft wing attach point. Boelkowj Home Built 0 November 7th 03 01:30 AM
