#21
Maybe too late for u. But...the correct way to do it is to do CFII first
with the FSDO. No complex, no T/O's & Lndg's no BS/ Just instruments stuff. Then u do the basic CFI with u'r favorite DE. M. "kontiki" wrote in message ... I am sure this subject has been brought up before (why? because the answer is not immediately obvious in the FARs) but I'd appreciate some input from the knowledge base. I'm close to scheduling my CFI checkride (practical teat to be precise) and although I've always assumed it had to be performed in a complex airplane (and have been doing all the right seat flying in one), I can not find a direct refrence in part 61 as to the requirement for such an airplane. The most pertinent references I can find refer to training and logging PIC in ".. the category and class of aircraft that is appropriate to the flight instructor rating being sought". This sort of reference appears several times throughout 61.185 but I never see a direct reference to a "complex" airplane. So my question, and that raised by my instructor today (gold seal BTW) is where did this come from? He assured me he did his CFI checkride in a 152... Any comments [and FAR references] are appreciated. |
size and power of a Piper Arrow? I'm not talking Bonanza..
do all of your training in the traumahawk.. polish off in the arrow and use the arrow for the check ride BT "Jim Macklin" wrote in message news:iPkwf.41025$QW2.1292@dukeread08... Use a Skipper, C150/152/Tomahawk etc for most of the CFI or commercial test and just use the complex as required is the least expensive way to do it. But people's egos get in the way and they want the size and power of the complex airplane. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Capt. Mike" wrote in message . .. |R u paying for my training in a complex for all the other required stuff ? | | easy with my money pal.. | | | "BTIZ" wrote in message | news ![]() | Show up with a Complex Aircraft and the Spin Endorsement completed.. | If the Examiner REQUIRES the SPIN as part of the test.. then get a | continuance letter specifying what is complete and what is not complete | and what needs to be accomplished to complete. | | It always boggles my mind.. it's the same as showing up for a Commercial | check ride in a non complex aircraft.. and swapping aircraft for a couple | of landings in complex aircraft... just do the whole check ride in | complex. | | BT | | "Peter Clark" wrote in message | ... | On Sun, 08 Jan 2006 20:27:13 -0600, Rachel wrote: | | Peter Clark wrote: | Well, yes and no. The task (section XI, task G) notes that an | endorsement may be substituted for that task, but the task is | required. In the event of no endorsement (or the examiner not | substituting it), a spin-capable aircraft would be required. | | If a complex aircraft is required for takeoffs and landings, how would | one manage that? I can't imagine bringing two aircraft to FSDO (if a | FSDO visit was required). Are any complex aircraft ok to spin? The one | I did my CFI in wasn't. | | I don't know about the complex aircraft question, but I'm sure there's | some way around it if you had to demonstrate them. How about go to | the FSDO, pick up the examiner, bring them back to your home field for | the spin portion of the exam? Or have your CFI ferry the spin capable | aircraft over to the airport the checkride was going to take place in | with you then disappear for a while you get the checkride over with? | Once the examiner is assigned, I presume it would be fair game to ask | them if they'd accept the endorsement so you can arrange appropriate | aircraft for all the pieces of the checkride? | | | | |
Jim Macklin wrote:
Use a Skipper, C150/152/Tomahawk etc for most of the CFI or commercial test and just use the complex as required is the least expensive way to do it. But people's egos get in the way and they want the size and power of the complex airplane. Can you do commercial maneuvers in a 152? I'm trying to imagine that. I just did my commercial from the right seat and talked myself through everything. By the time I got my CFI, it was easy. Saved a lot of time and money, even though I did a lot of it in the 172RG. |
commercial test and just use the complex as required is the least expensive way to do it. Is this true even if paying by the hobbs at a busy airport? Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
Sure you can do "commercial maneuvers" in a CE 152. A
chandelle is a coordination maneuver, not graded on actually gain altitude. On a hot day, you night only gain 100 feet at gross [all dual in a 152 is at gross with two men]. A Bonanza might gain ten times that, but you are graded on getting the "best" performance doing the maneuver as described in the PTS. The 150/152 cabin is tight with two men, not a lot of shoulder and hip room, so the use of a larger airplane may be necessary. It may not even be possible to carry a minimum fuel load and be under certified gross weight, depends on the size of the pilots [2 x 200+] pilots doesn't leave much for fuel, oil and charts, fuel reserve and lesson fuel. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Rachel" wrote in message . .. | Jim Macklin wrote: | Use a Skipper, C150/152/Tomahawk etc for most of the CFI or | commercial test and just use the complex as required is the | least expensive way to do it. But people's egos get in the | way and they want the size and power of the complex | airplane. | | | | Can you do commercial maneuvers in a 152? I'm trying to imagine that. | I just did my commercial from the right seat and talked myself through | everything. By the time I got my CFI, it was easy. Saved a lot of time | and money, even though I did a lot of it in the 172RG. |
Sure it is true. Flight experience required for a rating is
measured in hours, not miles. There is a requirement for both hours and minimum distance for x-c, but the less expensive airplane will wait the same time on the ground as the more expensive complex airplane. The Hobbs meter [John W. Hobbs] invented the meter and sold his company to Stewart Warner. [I knew his daughter, who was a friend of my sister.] The Hobbs meter may be connected to the engine oil pressure, an air speed sensor, or on complex aircraft the landing gear. FBOs like the oil pressure switch since it starts counting when you start the engine. The aircraft owner like the other since FAA maintenance time in service is from lift-off to touch down. Flight time is from first aircraft movement under power with the intention of flight until stopping. Most FBOs use the tach time, which counts revolutions divided by expected cruise rpm to get time in service for maintenance schedules but charge by the Hobbs that measures time by the clock with the engine running. [hint---low rpm cruise saves fuel and time in service since the tach time is slower.] -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Jose" wrote in message m... | Use a Skipper, C150/152/Tomahawk etc for most of the CFI or | commercial test and just use the complex as required is the | least expensive way to do it. | | Is this true even if paying by the hobbs at a busy airport? | | Jose | -- | Money: what you need when you run out of brains. | for Email, make the obvious change in the address. |
I already have a spin training sign-off.
Rachel wrote: Jim Macklin wrote: You also need an airplane available that can be legally spun. Only if you're required to do spins on the checkride. |
But that does not require the examiner to waive the
demonstration, it merely allows the examiner to do so. Some examiners really like to spin. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "kontiki" wrote in message ... |I already have a spin training sign-off. | | Rachel wrote: | Jim Macklin wrote: | | You also need an airplane available that can be legally spun. | | Only if you're required to do spins on the checkride. | |
#29
kontiki wrote:
I am sure this subject has been brought up before (why? because the answer is not immediately obvious in the FARs) but I'd appreciate some input from the knowledge base. I'm close to scheduling my CFI checkride (practical teat to be precise) and although I've always assumed it had to be performed in a complex airplane (and have been doing all the right seat flying in one), I can not find a direct refrence in part 61 as to the requirement for such an airplane. The most pertinent references I can find refer to training and logging PIC in ".. the category and class of aircraft that is appropriate to the flight instructor rating being sought". This sort of reference appears several times throughout 61.185 but I never see a direct reference to a "complex" airplane. So my question, and that raised by my instructor today (gold seal BTW) is where did this come from? He assured me he did his CFI checkride in a 152... Any comments [and FAR references] are appreciated. When I took mine it needed to be in a complex. (Used an Arrow) |
#30
the less
expensive airplane will wait the same time on the ground as the more expensive complex airplane. Yes, but you'll have to do it twice. You need to runup, take off, and land, and taxi both aircraft in order to accomplish the test using a non-complex one for part of the test. You pay 100% for that time, which compensates to some degree for the fact that the more expensive airplane (which you would have otherwise been using for the entire test) costs more. I know of no FBOs that charge by tach. I have run into one FBO aircraft whose hobbs is connected to the master switch - you pay $100/hr for testing the stall warning and setting up radios even before the engine starts. So it doesn't matter (to the renter) what the FBO uses for maintanence, and there's no incentive (to the pilot) to engage in low RPM cruise. FBOs I know will use tach times 1.2 if the hobbs is "too low" (broken). With all that, there's a lot of overhead to switching airplanes in the middle of the test. I'm not convinced that it's not cheaper to just stay with the same airplane for the entire test. Now training, that's another thing. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 10:33 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
