Thrusting or Sucking (where's Howard Stern when we need him.)
Old January 10th 06, 07:03 PM posted to rec.aviation.soaring
Default Thrusting or Sucking (where's Howard Stern when we need him.)
Since the FAA still tests on Bernoulli, you have to know that. I too am
much more comfortable with the Newtonian approach. As others have
pointed out in extreme detail, both are imperfect but they can both
provide useful understandings and numbers.
Such a well behaved community.... you know an item like this should
never be allowed to stand unabused. :-)
Ken Kochanski (KK) wrote:
OK, what is the better explanation to give fledgling students. Should
you say the wing deflects/pushes/thrusts the air down to hold the
aircraft up ... or should you say the wing/airflow creates a low
pressure area that sucks the wing/aircraft upwards.
Like many people, Bernoulli was the initial and only explanation I was
aware of ... but I now think it is easier and more accurate to explain
that a wing/airfolil pushes the air downward. Yes, you do have
pressure differences, but that is just an artifact of the process.
A Bernoulli based explanation seems to create some inconsistencies.
For example, boat and airplane propellers are basically identical
devices and differ in engineering specifics primarily because they
operate in different fluid mediums. Both employ "fluidfoils" ... and
both produce "thrust" ... but wouldn't a Bernoulli view argue that the
airplane prop is actually sucking ... and how would you use Bernoulli
to explain the thrust produced by the boat prop.
What about a Bernoulli view of SR-71 flight ops as it climbs from
sea-level to 85,000 feet.
thanks,
Old January 10th 06, 10:47 PM posted to rec.aviation.soaring
"toad" wrote in message
What ??? Bernoulii works great for flat plate airfoils ! Or are you
confusing the real Bernoulli with the bogus equal transit time BS that
some "dumb the truth down for the stupid pilots" wiseass created ?
Does anyone know who the aforementioned wiseass was? Or when this myth was
invented?
Geoff
the sea hawk at wow way d0t com
Spell checking is left as an excercise for the reader.
Old January 11th 06, 01:17 AM posted to rec.aviation.soaring
On Mon, 9 Jan 2006 15:52:44 UTC, "Ken Kochanski (KK)"
: OK, what is the better explanation to give fledgling students. Should
: you say the wing deflects/pushes/thrusts the air down to hold the
: aircraft up ... or should you say the wing/airflow creates a low
: pressure area that sucks the wing/aircraft upwards.
It does both, obviously. Equal and opposite reactions and all that.
Plane gets pushed up, air gets pushed down.
: Like many people, Bernoulli was the initial and only explanation I was
: aware of ... but I now think it is easier and more accurate to explain
: that a wing/airfolil pushes the air downward. Yes, you do have
: pressure differences, but that is just an artifact of the process.
: A Bernoulli based explanation seems to create some inconsistencies.
If you think there is a "Bernouilli based explanation" you have been
misinformed.
Ian
Old January 11th 06, 01:19 AM posted to rec.aviation.soaring
On Mon, 9 Jan 2006 19:05:38 UTC, Don Johnstone
: I think you can also obtain books that prove the earth
: is flat and the Holocaust never happened. Oh and I
: forgot there are several that prove global warming
Indeed. Any book which explains why Bernouilli doesn;t work was
written by someone who doesn;t understand what Bernouilli's theorem
say in the first place, or when and how it is applied.
Ian
Old January 11th 06, 01:20 AM posted to rec.aviation.soaring
On Mon, 9 Jan 2006 16:49:18 UTC, Marty
: Stick the cambered side of a standard spoon under a running tap! Ease
: the cambered side of the spoon gradually into the running water until
: the flow ‘sucks’ the spoon into the flow.
Bad example. That's (almost) nothing like a wing - the force is a
result of the momentum transfer of the water as it follows the curve
of the spoon, thanks to the Coanda effect.
Ian
Old January 11th 06, 01:25 AM posted to rec.aviation.soaring
On Mon, 9 Jan 2006 23:27:10 UTC, "1MoClimb"
: Bernoulli is not explaining 70% of the lift an ordinary airfoil
: generates. Bernoulli completely fails when using a flat plate which
: creates plenty of lift at normal angles of attack.
Rubbish. Bernouilli explains it perfectly well, as long as you have
the right velocity distribution. What Bernouilli's theore, does /not/
do is predict velocity distributions, and certainly not thos ebased on
fatupus ideas like "it's the different lengths of the top and bottom
surfaces that matter."
As you go on to say, rightly, it;s circulation that matters, and one
you know how big the bound vortex is a simply momentum equation on a
cylindrical control volume around the vortex/wing produces the
Kutta-Joukowski Theorem: lift = free stream velocity x circulation x
density. But do do that, no need the pressure distribution on the
control surface. Guess how you do that?
Yup. Bernouilli.
Ian
Old January 11th 06, 01:26 AM posted to rec.aviation.soaring
On Tue, 10 Jan 2006 14:55:28 UTC, Alexander Georgas
: -The particles are going to separate at the leading
: edge and meet up together approximatelly at the wing's
: trailing edge.
Utter rubbish. Why the hell should they?
Ian
Old January 11th 06, 01:28 AM posted to rec.aviation.soaring
On Tue, 10 Jan 2006 14:20:38 UTC, T o d d P a t t i s t
: Circulation theory is 100% consistent with Bernoulli.
What the unititaited don't realise is that forces can be transmitted
by pressure or by momentum flux. At the surface of a wing, all the
force comes from pressure. A long way away from the wing, all the
force comes from momemntum transfer (there is effectively no pressure
difference). As you go from one to the other the balance changes. Most
people who "prove" theories of lift wrong simply forget to take
account of momentum flux.
Ian
  #29
Old January 11th 06, 09:25 AM posted to rec.aviation.soaring
OK OK,
I said it was inaccurate to begin with!
Good to see this has stirred up some debate, thought.
While I agree this is more urban myth than fact, I
do feel that it helps more in visualization than statements
such as 'pressure builds below the wing' or 'it is
the Bernulli effect above the wing' (some even refer
to the Venturi effect).
I feel that the equal transit time proposition is a
good first step in helping people visualize what happens
when lift is generated, i.e. people start to think
about the flow fields over the entite wing section
in a more visual manner.
It is quite intuitive and easy to visualize. Once one
has actually understood this, he can now accept that
it is not true and move to the next level of understanding.
So if you drop the wing geometry idea (which I do not
aspise to begin with) and replace it with the concept
of angle of attack and also do not get too stuck with
the 'particles exit at exactly the same time' proposition,
you are starting to visualize things more properly.
Once you understand this, and the fact that the flow
over the wing is much faster than what the equal transit
time proposition must suggest and that the angle of
attack has created a low pressure area which has accelerated
the top flow field quite considerably, you can start
visualizing things like the vortices that are generated
once the two flows meet up behind the trailing edge
etc.
Now you are getting somewhere!
Otherwise, jumping from the 'there must be a Bernulli
effect somewhere' to the Euler equations is just too
much of a leap for the imagination (at least my imagination).
Now, concerning the Newtonian explanation, I consider
this too much of a cop out. Ok we all know it is correct,
and it is plain simple to understand. It just doesn't
explain anything about the mechanics of flight. It
is as saying (it is, in fact, saying) that the laws
of energy conservation will be upheld and that the
laws of thermodynamics will not be broken and that
the universe will keep on working the same way as it
was before. We sort knew this already. So where is
the understanding that comes from this explanation?
So I feel that while the equal transit time paradigm,
while false, is a good starting point for introducing
people to the aerodynamics of wing sections. They just
need to be told, once they understand the concept,
why it is false.
It is as useful as the Bohr model of the Atom: extremelly
inaccurate, but easy to visualize as a starting point
to understanding a very complex phenonenon. Would you
ever introduce particle physics to a student by writing
down the Schroedinger equation and solving a few Hamiltonians?
Alexander Georgas
At 16:24 10 January 2006, T O D D P A T T I S T wrote:
Alexander Georgas
Ok, here is another way this can be explained (if just
a bit inaccurate):
Sorry, but this is a lot inaccurate (a.k.a 'wrong')
The critical point to consider is angle of attack.
You just need to think of the airflow meeting the wing
at a specific angle. If you now imagine the airflow
separating to move above and below the wing section
as two particles, you have the following explanation:
trailing edge.
The particles do *not* meet up at the trailing edge.
This
is often referred to as the 'equal transit times'
explanation of Bernoulli, which is thoroughly discredited.
-Because of the angle of attack (and of the wing's
thinkness), the air particle that will travel above
the wing section will have a greater discance to cover,
so it will have to run faster if it is to meet up with
the other particle which is traveling below the wing
section
The particles do not have to meet up.
-Particles traveling at greater speeds (compared to
particles in neighboring areas) create areas of low
pressure -- just think: because the particles are running
faster over the wing compared to under the wing, there
are fewer of them in a specific area. Alternativelly,
you can take Bernoulli's word on this one.
Bernoulli does not explain the flow pattern. Bernoulli
explains the lift (pressure differentials given a specific
flow pattern. You have to call in some other physics,
namely that the air flows smoothly off the trailing
edge, to
establish the flow pattern. Once you have that, you
apply
Bernoulli.
-Now let's examine the situation from the perspective
of the wing. There is a low pressure above and a high
pressure bellow. The resulting force is thus upwards
(in relation to the angle of attack).
The only presumption which remains to be explained
is why the two particles have to meet at the back of
the wing section. The easiest way to gloss over this
Take a look at John Denker's start page:
http://www.av8n.com/how/
See the graphic and the bands of red, orange green
blue?
The blue band air over the top hits the trailing edge
before
the blue band air at the bottom, even though they started
out together.
is to consider that if this is not approximatelly the
case, an imbalance will be created whereby there will
be more air crossing below the wing section and a low
pressure area buildup at the top back end of the wing,
created by the lack of air (teh air has just not had
the time to reach there). This would probably invite
air from below the wing to bleed back up towards the
back top.
Guess what, that 'low pressure buildup' causes the
air on
top to accelerate, and it does tend to cause the high
pressure to flow around to the top (resisted by air's
finite
viscosity and the sharpness of the trailing edge).
In this case, the airflow above the wing
would separate from the wing section before the trailing
edge (does this sound a bit like a stalled wing?)
In a stalled wing, this does happen, but we're talking
about
a non-stalled wing and in that case the air flows faster
over the top.
I don't know how much science there is behind this
explanation. I just find it a bit easier to swallow
than the Newtonian explanation. In my view the action-reaction
way of putting it (air is deflected downwards) is true,
but unable to shed any light on the mechanism.
I agree that the Newtonian explanation is hard, but
so is
the Bernoulli. That's the nature of lift.
I think of it like this: When the wing starts forward
at a
positive angle of attack, the space behind the wing's
upper
surface is being swept clear of air molecules - at
least
that's what the wing is trying to do. However, in
a fluid
(air), sweeping the molecules clear would produce a
vacuum
behind the wing, so the instant that the pressure begins
to
fall behind the wing, air from on top and ahead of
the wing
and air above the wing begins to rush towards this
region.
The air from ahead and on top of the wing that rushes
back
towards this low pressure region is being accelerated
exactly what the Bernoulli explanation needs for its
lower
pressure due to faster flow. The air above the wing
moving
down, coupled with higher pressure air below the wing
(also
moving down to escape that higher pressure) produces
downwash - exactly as the Newtonian explanation needs.
In reality, these are just two faces of the same coin.
There's no need to use the false 'equal transit times'
explanation of Bernoulli.
It is
just an energy checks-and-balances way of explaining
lift, which we already know occurs.
Alexander Georgas
T o d d P a t t i s t - 'WH' Ventus C
(Remove DONTSPAMME from address to email reply.)
  #30
Old January 11th 06, 10:27 AM posted to rec.aviation.soaring
Well, trying to explain something by starting with a statement which is
completely wrong is a very strange educational twist...
The Bohr model is not accurate enough to explain all details, but it is not
wrong.
Bert
ASW20 "TW"
"Alexander Georgas" wrote in message
OK OK,
etc.
why it is false.
Alexander Georgas
Alexander Georgas
a bit inaccurate):
trailing edge.
This
section
edge, to
apply
Bernoulli.
blue?
before
out together.
back top.
air on
finite
about
over the top.
so is
at a
upper
least
a fluid
vacuum
to
the wing
region.
back
lower
moving
(also
It is
Alexander Georgas
