George Patterson wrote:
RG batteries are very sensitive to being left in a partially discharged state. I plug in the trickle-charger every time I come back from a flight and leave it on until I go again (lead-acid battery). Mechanic concurs that this is a good idea. I usually fly once or twice/week. Sounds like this would be a good thing for an RG battery as well? |
If you are servicing the battery more than once per year there may be
something wrong. I replace my battery every 2-3 years. The only othertime the battery box is opened is during annual. -Robert |
I've used a RG battery for 6 years and consider them a good solution to
a potentially nasty problem (leakage). I think the life is comparable to a wet battery, and would certainly use one in your situation. The RGs are a little more sensitive to overcharging, so have your mechanic check the charging voltage when installing the new battery. |
Crash In The Nolichucky | W P Dixon | Piloting | 2 | June 22nd 05 04:16 PM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 04:05 AM |
The Best Airplane | Veeduber | Home Built | 1 | February 13th 04 05:43 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
