#21
("Big John" wrote)
New super-gun to be tested in Feb Can you crosspost to multiple newsgroups, instead of starting separate threads in separate newsgroups? Many (most?) newsreaders will cancel 'read posts' from one newsgroup to another. Thanks Gun: Didn't a couple of Mormons, out in Utah back in the late 80's, have a gun that fired .22 rounds? It was suppose to be able to shoot down a telephone pole and slice through a moving car - like a knife through warm butter. It was lightweight and inexpensive because it used .22 shells. Something like 6,000 round per minute. 100/sec. The story was featured in our daily paper - there might have been a Twin Cities connection. Montblack |
![]() wrote in message The GAU-8's biggest limitation besides ammo supply is that the recoil slows the A-10 quickly, The recoil will do no such thing. |
![]() "Stubby" wrote I really don't understand the "environmental issue." Those rounds are meant to melt through armor and shatter into pieces which bounce around inside the tank and function as an anti-personnel weapon. That's fairly high on the "toxicity" scale compared to DU which is approximately as radioactive as common rock. Many (most) of the rounds miss the tank, and are in the surrounding environment, and in villages, and such. -- Jim in NC |
and gasses from the muzzle get sucked into the engines while firing.
Not true. The engines are mounted where they are, to prevent that. IIRC from the A-10 show on Military Channel, the engines are mounted where they are to give the plane better survivability against AAA. That dictated placement of the engines. One could be blown off the airframe and the plane could still fly. The trail of spent gas from the gun was fairly obvious in the airborne footage of the gun firing IIRC. Also mentioned in the narration. Also mentioned was the recoil slowing the aircraft. If this is not accurate then the Military Channel has poor sources. |
![]() "Morgans" writes: The GAU-8's biggest limitation besides ammo supply is that the recoil slows the A-10 quickly, [...] A myth, according to a A-10 driver here, a while back. [...] A quick visit to Newton's second law indicates a roughly 2 m/s^2 ~ 6.5 ft/s^2 deceleration due to the recoil force (10000 lbf acting on 50000 lb airplane). From a hypothetical slowish flying speed of 200 mph (300 ft/s), it would require about **20 seconds** of fire to get down to the A-10's ~115 mph stall speed. Whether that's "quick" or "a myth" depends on your point of view (and on whether I did my estimations correctly). - FChE |
![]() "Frank Ch. Eigler" wrote in message ... "Morgans" writes: The GAU-8's biggest limitation besides ammo supply is that the recoil slows the A-10 quickly, [...] A myth, according to a A-10 driver here, a while back. [...] A quick visit to Newton's second law indicates a roughly 2 m/s^2 ~ 6.5 ft/s^2 deceleration due to the recoil force (10000 lbf acting on 50000 lb airplane). From a hypothetical slowish flying speed of 200 mph (300 ft/s), it would require about **20 seconds** of fire to get down to the A-10's ~115 mph stall speed. Whether that's "quick" or "a myth" depends on your point of view (and on whether I did my estimations correctly). - FChE Did your estimation take into account that the Warthogs engines are still producing power while they shoot? |
George Patterson wrote:
There's no recoil from a rocket launch. Thank you George my brain wasn't fully angaged yet when I posted. The Monk |
#29
That's alright Steven, my brain wasn't fully angaged yet when I posted.
:^) The Monk |
#30
![]() "Frank Ch. Eigler" wrote Whether that's "quick" or "a myth" depends on your point of view (and on whether I did my estimations correctly). What you failed to take into account, is that the engines keep applying thrust, and will partially negate that issue, and that the gun is nearly always fired while the airplane is in a rather steep descent (to get guns on target), so there is more force to keep the airplane from slowing down. So it appears as though it would take considerably more to slow the airplane to stall speed, and it the guns fired much longer, they would be a molten pile of metal, or out of ammo. Anyone remember how many seconds of ammo are carried? As to the engines ingesting the gun smoke, consider how much air they take in. Massive amounts. Most of that is bypassed around the engine, so only a little is burned. Even if some of the smoke is taken in, I doubt that it is enough to make the engine even stutter. -- Jim in NC |
