#21
N86CE has multiple records
Bell 206L-3 Certificate Issue Date: 04/27/1993 Cancel Date: ................04/19/1994 Destroyed JOHNSTON COCA COLA BOTTLING CO INC OMG!!! ..don't any a/c owner should ever use this number again. |
On Wed, 25 Jan 2006 20:13:42 GMT, Larry Dighera wrote:
It's beginning to look like there may have been a pilot incapacitation issue involved. Do you know if the Citation 560 is certified for single pilot operation? Another posting here indicated that there was a co-pilot. Could it be possible that they had the whole flight programmed into the FMS and then had a Pane Stewart type problem and the plane finished the flight? Paul |
Could it be possible that they had the whole flight programmed into the FMS and then had a Pane Stewart type problem and the plane finished the flight? In this case, wouldn't there have been reports of the aircraft being NORDO for the last half of the flight? -- Peter |
("cpu" wrote)
N86CE has multiple records Bell 206L-3 Certificate Issue Date: 04/27/1993 Cancel Date: ................04/19/1994 Destroyed JOHNSTON COCA COLA BOTTLING CO INC OMG!!! ..don't any a/c owner should ever use this number again. So you're saying the FAA should ..."86" that number? http://www.straightdope.com/classics/a1_291b.html Montblack |
Montblack wrote:
So you're saying the FAA should ..."86" that number? http://www.straightdope.com/classics/a1_291b.html Well, in that case, 55 and 19. Whoa! 87-1/2! The Monk |
Pilot seemed OK before deadly crash
By Mark Arner UNION-TRIBUNE STAFF WRITER January 26, 2006 CARLSBAD - A federal investigator said yesterday that nothing in the pilot's last conversation with an air-traffic controller indicated there was a problem before a fatal jet crash at McClellan-Palomar Airport. Kurt Anderson, an investigator for the National Transportation Safety Board, also said there are conflicting reports about the jet's speed when it approached the Carlsbad airport Tuesday morning. Witnesses said the jet appeared to be traveling too fast as it touched down near the middle of the 4,600-foot-long runway. All four people aboard were killed when the aircraft skidded off the runway, plowed through barricades and hit a storage building before catching fire. Anderson said he knew about the Internet data from "FlightAware" that shows minute-by-minute ground speed data about such general aviation flights. The Web site said the 1994 Cessna Citation V twin-engine jet was traveling at 227 nautical mph (261 mph) when it touched down at the Carlsbad airport shortly before 6:40 a.m. Anderson confirmed that the recommended landing speed for such a jet is between 105 and 115 knots (121 mph to 132 mph). "There is some discrepancy between that (the FlightAware data) and other data that we have," he said. All the information will take four to six months to fully analyze, Anderson said. He declined to speculate about what caused the crash. "This is a slow and very deliberative, step-by-step process," he said. "At this point, we are nowhere near any specific conclusions." Investigators did determine that the jet's landing gear was down after the crash, and that its "thrust reversers," used to slow the jet, were stowed. That would be the normal position for such equipment if the pilot intended to take off again and attempt another landing, Anderson said. He said the cockpit voice recorder was recovered "in good shape" and was being flown to Washington, D.C., along with reams of other data. Anderson said he also has a recording of the pilot's conversation with an off-site air traffic controller just before the landing attempt. That conversation was with a controller based at an FAA radar station, called a TRACON, next to the Miramar Marine Corps Air Station. Anderson said there was no distress call or indication from the pilot that he was having difficulty with the aircraft. Killed in the wreck were pilot John C. "Jack" Francis, co-pilot Anthony Garrett, New Hampshire science-equipment executive Frank Jellinek Jr. and Janet Shafran of Ketchum, Idaho, authorities said. Mark Arner: (619) 542-4556; |
"AJ" wrote in message
oups.com... Pilot seemed OK before deadly crash But seemed rather unresponsive afterwards? sick-grin |
Grumman-581 wrote:
Pilot seemed OK before deadly crash But seemed rather unresponsive afterwards? sick-grin I don't know weather to laugh with you or scold you, since I'm not the scolding type. g The Monk |
#29
I was thinking hard attack on final with auto-pilot still engaged.
They said clear to land and the pilot replied and then massive coronary. People in the back never knew what happened. "Peter R." wrote in message ... wrote: Could it be possible that they had the whole flight programmed into the FMS and then had a Pane Stewart type problem and the plane finished the flight? In this case, wouldn't there have been reports of the aircraft being NORDO for the last half of the flight? -- Peter |
#30
On Thu, 26 Jan 2006 18:46:26 -0800, "Aluckyguess"
wrote in :: I was thinking hard [sic] attack on final with auto-pilot still engaged. They said clear to land and the pilot replied and then massive coronary. That would have had to occur within the temporal window of opportunity bounded by the time the gear was extended and the time of impact, a period of probably a couple of minutes at the speed the aircraft was alleged to have been traveling. (What's the old saw about preferring luck to skill?) The other questionable issue in this hypothesis, is the necessity for BOTH pilots to have been stricken simultaneously. |
Bakersfield Municipal Airport May Be Sold To Developers | Larry Dighera | Piloting | 3 | November 23rd 05 03:00 PM |
Pilot walks away from crash near Manchester, NH airport | [email protected] | Piloting | 22 | November 11th 05 04:13 PM |
VKX airport (Home of SuperAWOS) CLOSED | awos | Piloting | 0 | November 8th 05 03:15 PM |
[Media] A Marine's journey home | Michael Wise | Naval Aviation | 0 | May 3rd 04 04:57 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
