#21
How many charge/discharge cycles do they figure?
More than your PDA ;-) There's more detail on the Lange web site under FAQs http://www.lange-flugzeugbau.de/bild...terie-engl.pdf Hope that helps ! Best Regards, Dave |
Did anyone figured out the cost per, say, 1000ft of altitude, giving
the battery replacement cost, charging cost, engine maintainance etc? It would be interesting to see a comparisom between electric glider, motorgliders, aerotows and winch tows as for the overall cost per 1000ft of altitude. Ramy |
You could get 200 US glider pilots to chip in $500 on something that
won't increase their L/D? You must be quite a salesman 8^) I for one, will be more than happy to chip in $500 for something that will significantly increase safety. Most of us spend up to about $1000 on parachutes which we probably never use, so why not a Flarm like device? I hope someone will either license the Flarm or produce something similar, and then make it mandatory... Till then we will continue average at least one mid air per year in the US... Ramy |
Ramy wrote:
You could get 200 US glider pilots to chip in $500 on something that won't increase their L/D? You must be quite a salesman 8^) I for one, will be more than happy to chip in $500 for something that will significantly increase safety. Most of us spend up to about $1000 on parachutes which we probably never use, so why not a Flarm like device? I hope someone will either license the Flarm or produce something similar, and then make it mandatory... Till then we will continue average at least one mid air per year in the US... I gave a short presentation on FLARM at the 2005 SSA convention, and have tried to generate some interest in it. Very few people have had any interest in it, unlike the huge response in Europe. I think the difference is we don't have nearly the mid-air collision problem that they do in the Alps, Pyrenees, and other places. Their airspace can be far denser with gliders than ours, even including the White mountains and the ridge-runners along the Alleghenies, and as a result, they run into each other more frequently. The poor response I get may be reasonable: personally, I think a transponder is a better value at, say, $2000, than FLARM at $620Euro (US$745). My experience is the glider that is likely to run into me is the one I'm thermalling with and already know about. Except for contests, I see more airplanes en route than gliders. Even so, I hope people will pursue it. There are mitigating features; for example, the FLARM will log a flight in IGC format, though it's not secure at this point. If that happened, it wouldn't cost much more than just an IGC logger. Busy clubs could benefit from it's use with a ground station and automatic logging of tows and club glider use by it's members, and there are other applications under way. Besides technical people, I think we need some good lawyers that can analyze the liability situation, then create a means to license or otherwise acquire the technology from FLARM that would ease the concerns of the FLARM developers. I'd be willing to chip in at least $200 for starters. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA www.motorglider.org |
Marc Ramsey wrote:
I also suspect that FLARM won't do much to help where I'm most concerned about a collision with another glider, the ridge running down the White and Inyo mountains near the CA/NV border. FLARM advertises an effective range of 2-3 km, or 1 to 1.5 nm. Given a head-on approach between two gliders, each running at a TAS of 150 knots, you'll be lucky to get 10 seconds of warning. Might work for an ex-fighter pilot, but that's not much time for someone like me... But in the case of running the Whites, there's a radio procedure in place. http://www.soaringsafety.org/present...2Nose_2002.ppt Any idea how universally adopted (or not) it is? Jeremy |
At the risk of further hijacking the thread , may I suggest pilots not to
turn off their transponders when flying over the white mountains? Some of us nowadays are equipped with low cost TPAS and would like to receive your transponder signal... Ramy "Jeremy Zawodny" wrote in message ... But in the case of running the Whites, there's a radio procedure in place. http://www.soaringsafety.org/present...2Nose_2002.ppt Any idea how universally adopted (or not) it is? Jeremy |
Did anyone figured out the cost....
Are you mad ? If we knew the real cost we'd never fly ! Especially if our spouses knew the real cost ! See ya, Dave |
Actually, I may try to convince wife it may be cheaper on the long run
to buy a motorglider (or electric glider) then pay for aerotows, but I need numbers... Ramy |
#29
![]() "Ramy" wrote in message ups.com... Actually, I may try to convince wife it may be cheaper on the long run to buy a motorglider (or electric glider) then pay for aerotows, but I need numbers... Ramy Actually, it's probably best to forget about using numbers, as that implies that you will try to use logic and fact . . . and we all know *that* won't work. Naw, overall it's probably more expensive to operate a self-launch. But that extra money buys amazing versatility, the ability to go where pure gliders can't (or at least not without a retrieve), And the convenience of always having your "tow plane" tucked away conveniently along for the ride. Purist?? Hawks and eagles self-launch! bumper ASH26E Minden, NV |
#30
I did a very rough analysis of another glider instrument, probable
market size, and necessary pricing he https://www.freytag.us/twiki/bin/vie...rLiftDetectors The good thing about the FLARM is that the design/function is resolved so your costs are reduced there. But then you still have the risks of distribution and, implicit, support. Cheers, Richard "H3" Ramy wrote: You could get 200 US glider pilots to chip in $500 on something that won't increase their L/D? You must be quite a salesman 8^) I for one, will be more than happy to chip in $500 for something that will significantly increase safety. Most of us spend up to about $1000 on parachutes which we probably never use, so why not a Flarm like device? I hope someone will either license the Flarm or produce something similar, and then make it mandatory... Till then we will continue average at least one mid air per year in the US... Ramy |
CFI without commercial? | Jay Honeck | Piloting | 75 | December 8th 10 04:17 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Dumb Reg question | John Gaquin | Piloting | 67 | May 4th 05 04:54 AM |
NAS and associated computer system | Newps | Instrument Flight Rules | 8 | August 12th 04 05:12 AM |
Real World Specs for FS 2004 | Paul H. | Simulators | 16 | August 18th 03 09:25 AM |
