Gas Theft Nashua (ASH)
Old February 10th 06, 09:36 AM posted to rec.aviation.piloting
Default Gas Theft Nashua (ASH)
On Sat, 4 Feb 2006 11:59:40 -0800, "RST Engineering"
(a) You can go through the math all day long and still not explain why I
have drained the (hangared) 182 after a particularly humid day or two and
get a tablespoon or two of water in the quick drains.
It's been years since I've seen water from the Cub. Not since the
switch to 110LL, in fact. So my take is that the water used to come
from the gasoline.
-- all the best, Dan Ford
email: usenet AT danford DOT net
Warbird's Forum: www.warbirdforum.com
Piper Cub Forum: www.pipercubforum.com
In Search of Lost Time: www.readingproust.com
Old February 4th 06, 06:02 PM posted to rec.aviation.piloting
"RST Engineering" wrote:
I would ten times over risk gas theft over water condensation overnight in
half-full or nearly empty tanks.
But, if you fill it up, and they siphon it out, don't you still have the
same problem?
Old February 4th 06, 07:09 PM posted to rec.aviation.piloting
same problem?
First thing that came to my mind as well when I read that.
The Monk
Old February 4th 06, 07:32 PM posted to rec.aviation.piloting
"john smith" wrote in message
in
same problem?
Yes, but the siphoning is an unlikely event. If condensation were a serious
concern, you'd prefer to take a small chance of theft plus condensation
rather than defending against theft at the cost of a much greater chance of
condensation.
--Gary
Old February 4th 06, 05:55 PM posted to rec.aviation.piloting
"Hank Rausch" wrote in message
I've never given any consideration to gas theft
After 102 years of powered flight, you'd think locking gas caps would be
available.
Old February 4th 06, 06:03 PM posted to rec.aviation.piloting
available.
If you hook up a tube to the fuel drain and the vent is working
properly, a locking cap won't make a difference.
Old February 4th 06, 07:38 PM posted to rec.aviation.piloting
You'd have to be pretty patient to drain a significant amount thru a
quickdrain.
Old February 4th 06, 08:05 PM posted to rec.aviation.piloting
I once hooked a tube to the gascolator drain tube of my 182 and drained five
gallons in a few minutes. I put vicegrips on the drain control to keep it
open.
Old February 4th 06, 09:51 PM posted to rec.aviation.piloting
open.
I'm not puttin' vicegrips on *my* quick drain!!!
Have a good day!!
Old February 4th 06, 11:31 PM posted to rec.aviation.piloting
quickdrain.
As quick as they drain, the also unscrew, dumping the entire contents
of the tank on the arm of the person doing the unscrewing..
-Robert (who knows from personal experience)
Theft among friends bumper Soaring 8 July 29th 05 05:51 PM
Theft From Baggage-Continental [email protected] Piloting 73 April 2nd 05 08:17 AM
A-10s at Nashua, NH (ASH) today? William W. Plummer General Aviation 0 May 15th 04 04:03 PM
Good News! Arrest in plane theft case Jamie Rogers Piloting 10 November 8th 03 06:43 AM
Nashua Festival, Avidyne and WSI Doug Vetter Owning 9 September 24th 03 02:45 AM
