If the missed approach on the IAP says something like:
heading of 270 to 4000 Intercept the XXX VOR R-180 Direct to XXX VOR What should you do if you get to R-180 before you get to 4000? Keep climbing on 270 to 4000? Turn and track the R-180 while climbing? The IAP has no minimum climb gradient specified. What minimum climb gradient is assumed if none is specified? |
![]() "ArtP" wrote in message ... On Fri, 07 Nov 2003 15:54:41 -0800, wrote: If the missed approach on the IAP says something like: heading of 270 to 4000 Intercept the XXX VOR R-180 Direct to XXX VOR What should you do if you get to R-180 before you get to 4000? Keep climbing on 270 to 4000? Turn and track the R-180 while climbing? Follow the procedure (keep climbing on 270 until 4000 feet then turn back to intercept the radial. It is possible that unless you are at 4000 you may not want to be on that radial. I think it far more likely that ATC will expect the pilot to remain on the specified course and if an obstruction was a problem there would be a minimum gradient specified or a minimum crossing. I would interpret the above missed instruction as "climb and maintain 4000, maintain heading of 270 to intercept the 180 radial inbound..." without a second thought. Perhaps an example from "nospam" of an actual plate would be more instructive. -Greg The IAP has no minimum climb gradient specified. What minimum climb gradient is assumed if none is specified? 200 feet per nautical mile. |
On Sat, 08 Nov 2003 02:01:13 GMT, "Greg Goodknight"
wrote: "ArtP" wrote in message .. . On Fri, 07 Nov 2003 15:54:41 -0800, wrote: If the missed approach on the IAP says something like: heading of 270 to 4000 Intercept the XXX VOR R-180 Direct to XXX VOR What should you do if you get to R-180 before you get to 4000? Keep climbing on 270 to 4000? Turn and track the R-180 while climbing? Follow the procedure (keep climbing on 270 until 4000 feet then turn back to intercept the radial. It is possible that unless you are at 4000 you may not want to be on that radial. I think it far more likely that ATC will expect the pilot to remain on the specified course and if an obstruction was a problem there would be a minimum gradient specified or a minimum crossing. According to the AIM (Instrument Departures) a climb gradient would only be specified if a climb of greater than 200 feet per nautical mile were required. Without an indication of a climbing turn via I would continue on the specified heading until the specified altitude were reached. I would interpret the above missed instruction as "climb and maintain 4000, maintain heading of 270 to intercept the 180 radial inbound..." without a second thought. Take a look at FQD LOC RWY 1 for an example of a climb then a climbing turn. Take a look at RWI VOR/DME 22 for an example of a climb via an intercepted radial (the method you are describing). Take a look at RDU NDB RWY 5R for another example. Perhaps an example from "nospam" of an actual plate would be more instructive. I agree. |
![]() "ArtP" wrote in message ... On Sat, 08 Nov 2003 02:01:13 GMT, "Greg Goodknight" wrote: "ArtP" wrote in message .. . On Fri, 07 Nov 2003 15:54:41 -0800, wrote: If the missed approach on the IAP says something like: heading of 270 to 4000 Intercept the XXX VOR R-180 Direct to XXX VOR What should you do if you get to R-180 before you get to 4000? Keep climbing on 270 to 4000? Turn and track the R-180 while climbing? Follow the procedure (keep climbing on 270 until 4000 feet then turn back to intercept the radial. It is possible that unless you are at 4000 you may not want to be on that radial. I think it far more likely that ATC will expect the pilot to remain on the specified course and if an obstruction was a problem there would be a minimum gradient specified or a minimum crossing. According to the AIM (Instrument Departures) a climb gradient would only be specified if a climb of greater than 200 feet per nautical mile were required. Without an indication of a climbing turn via I would continue on the specified heading until the specified altitude were reached. Perhaps if you found just one missed approach, or any procedure that specifies passing through a radial and doubling back after a specified altitude without the benefit of any course guidance; remember, the hypothetical was just flying a heading until the radial was intercepted. I can't imagine a course reversal ever being implied in free space. The hypothetical seemed flawed to me, hence my request for an real example from "nospam". If I was faced with the actual wording posed and ATC was not available, I would not be playing FAR Bingo, I'd fly the course specified and not invent a new one because of a possibility of an implied altitude problem. -Greg I would interpret the above missed instruction as "climb and maintain 4000, maintain heading of 270 to intercept the 180 radial inbound..." without a second thought. Take a look at FQD LOC RWY 1 for an example of a climb then a climbing turn. Take a look at RWI VOR/DME 22 for an example of a climb via an intercepted radial (the method you are describing). Take a look at RDU NDB RWY 5R for another example. Perhaps an example from "nospam" of an actual plate would be more instructive. I agree. |
instructive. Take a look at the ILS to RWY 24 and (K)CRQ This is where I saw the missed. It is not a good example as the missed takes you out over the ocean and in fact either way you look at it, it would be safe. I'm just trying to understand in the general sense what the rules are. In reading the recent AOPA magazine it had a sumary of accidents in CA and one was someone getting a radar vector and assuming that he could let down to the crossing altitude of the next segment. He did this at night and it was fatal. I understand that not understanding the subleties of what the rules are for flying IFR can also be Fatal so I'm just trying to understand. Another approach with a similar missed that is unlclear: KCNO ILS RWY 26R Missed: Climb to 1400 then climbing left turn to 4000 direct PDZ and hold. Looking at the plate missed seems to be about 4 mi from PDZ. DH is 836 so at 200ft /mi 1400 gets you to 6 mi from PDZ Assume that the turn gives you another 200 ft thats 1600 and 6 miles at 200 per nm that gets you to PDZ and 2800. The missed specifies 4000 So what do you do hold at PDZ and climb to 4000? Again in this specific case it looks like that would be safe. |
![]() "ArtP" wrote in message ... On Fri, 07 Nov 2003 20:45:57 -0800, wrote: Take a look at the ILS to RWY 24 and (K)CRQ This is where I saw the missed. It is not a good example as the missed takes you out over the ocean and in fact either way you look at it, it would be safe. I would climb to 3000 then I would do the turn. If they wanted you to turn before you reached 3000 they would have specified a climbing turn or do what they did below (specify an altitude straight ahead and then a climbing turn). When they specify a climb altitude before the turn, you are expected to be at that altitude before you start the turn. Assuming you are in radar contact (and that is a very good bet) if you followed your own advice you would get a call from ATC asking you what you're doing. The missed says to climb to 3000' via a specified route consisting of a heading and a radial to intercept. If you are intercepting a radial, a turn is implied. -Greg |
![]() wrote in message ... Perhaps an example from "nospam" of an actual plate would be more instructive. Take a look at the ILS to RWY 24 and (K)CRQ Had to look in the old logbook. Haven't flown there since 6/27/1974. Wonder if it's changed much. This is where I saw the missed. It is not a good example as the missed takes you out over the ocean and in fact either way you look at it, it would be safe. You transcribed the meaning incorrectly. It says "Climb to 3000 via heading 245 and OCN R-145 to OCN VORTAC", which is, in essence, what I said I would do. It doesn't say climb to 3000 on a heading of 245 and tben intercept. It gives you a route (heading 245 and OCN R-145 to OCN) and an altitude (3000')to climb to. I'm just trying to understand in the general sense what the rules are. In reading the recent AOPA magazine it had a sumary of accidents in CA and one was someone getting a radar vector and assuming that he could let down to the crossing altitude of the next segment. He did this at night and it was fatal. I understand that not understanding the subleties of what the rules are for flying IFR can also be Fatal so I'm just trying to understand. Another approach with a similar missed that is unlclear: KCNO ILS RWY 26R Gee, more of my old stomping grounds. I soloed at Chino on 1/16/1974. Missed: Climb to 1400 then climbing left turn to 4000 direct PDZ and hold. This is also crystal clear and not at all similar. You climb to 1400 and then continue a climb while turning direct to PDZ. There is no possibility of overshooting a radial that needs to be intercepted. Looking at the plate missed seems to be about 4 mi from PDZ. DH is 836 so at 200ft /mi 1400 gets you to 6 mi from PDZ Assume that the turn gives you another 200 ft thats 1600 and 6 miles at 200 per nm that gets you to PDZ and 2800. The missed specifies 4000 So keep climbing. Don't worry, SoCal Approach will be asking you about your climb rate, and the initial climb to 1400 seems to be chosen to get you high enough. So what do you do hold at PDZ and climb to 4000? Yep. Next time in your thought experiments, don't fly a C-150 under IFR with full fuel and extra passengers in the baggage compartment and you'll climb faster ![]() Again in this specific case it looks like that would be safe. yep! cheers -Greg |
The perfect approach | Capt.Doug | Home Built | 25 | December 3rd 04 03:37 AM |
DME req'd on ILS (not ILS-DME) approach? | Don Faulkner | Instrument Flight Rules | 13 | October 7th 03 03:54 AM |
Instrument Approaches and procedure turns.... | Cecil E. Chapman | Instrument Flight Rules | 58 | September 18th 03 10:40 PM |
Which of these approaches is loggable? | Paul Tomblin | Instrument Flight Rules | 26 | August 16th 03 05:22 PM |
IR checkride story! | Guy Elden Jr. | Instrument Flight Rules | 16 | August 1st 03 09:03 PM |
