the garmin 430 and 530 are basically the same, only a few small exceptions, screen size
being the biggest. But as you approach your destination the 430/530 puts your freq into standby "O. Sami Saydjari" wrote: I read the that garmin 530 anticipates the COM frequencies you need and loads them into an internal Com radio. That is a really nice feature. Does the Garmin 430 do this? Or can the 430 combination accomplish the same thing by interfacing to standard radios? Jeff wrote: the garmin weather module is here http://www.garmin.com/products/gdl49/ it sends weather overlay to the GPS. having 2 gps's gives you the ability to have like an arrival procedure on one GPS, say the 430, then you canhave the actual approach on the MX20. but you can go cheaper since the mx20 is such an awsome product, and get a small cheaper ifr certified GPS, connect it to the MX20 and get the same information that a 430 would supply to it. Having 2 GPS's is really nice, I have my 430 and still use my handheld 295. But this is only a temp solution untill I get the MX20 installed (after I get my wife another horse) "O. Sami Saydjari" wrote: Thanks. Interesting. So, does one send the Garmin 430 GPS information to the MX20 and have it displayed there? I would prefer to have one integrated display of nav and weather information. If so, then it seems that the garmin 430 display space is a waste of valuable panel real-estate. If not, how are the two different displays used differently? Seems like it adds to workload that way to have to monitor 2 screens. On a separate note, what sort of weather modules exist to feed-into these displays. I here they are available, but I can not find them on the garmin website. I am looking to learn about 1 or 2 options of such modules that uplink to satellites and download weather, and displays it on the MFD. I would like to know ballpark cost of the module, panel real estate requirements, and what the cost of a subscription would be. -sami Windecks wrote: We have a Garmin 430 and an MX20 and they work really well together. The terrain display on the MX20 is great, and the resolution on VFR and IFR charts is sharp and the map's easily readable in direct sunlight. The MX20 is easy to use and configure, and really enhances the capabilities of the 430. I'd only go for a 530 if there wasn't enough space in the panel. Never seen a CNX80 in action, but it sounds like an enhanced 430. Still, UPSAT (and now, of course, Garmin) has been marketing the CNX80/MX20 combo. Go figure, they want to sell 2 boxes instead of 1!! "O. Sami Saydjari" wrote in message ... In an article at http://avionicswest.com/archive/shootout.htm#2003 about Garmin 530 vs CNX-80, many of the pilots said that they would want a combination of a Garmin 530 AND an MX20. I do not understand. Isn't the Garmin 530 also an MFD capable of displaying multiple inputs, like weather and terrain? Can someone tell me why both might be desirable? Does anyone have experience with an MX20? -Sami |
The reader's digest version of why we chose the 430:
It fits, is not that much more expensive, works well with the MX20, has a superior user interface, and the display is very handy when used for setup/lookup tasks. The map is redundant, and includes incremental info not found on the MX20. Unabridged version: The Garmin NAV info is sent to the MX20, where it is combined with terrain, weather and chart databases contained in the MX20. It's true that you can put in a cheaper (and smaller) IFR GPS to interface with the MX20, but we chose to go with the 430 for the following reasons: - Combined with a SL30 Nav/Com, XPNDR, audio controller/Marker Beacon, the 430 and MX20 all fit in a single stack in our panel - Subjective preference for 430 user interface over King KLNs, UPSAT MXs and others - 430 map page has better ID for roads, bodies of water etc. than MX20 - $$$ difference not all that great between 430 and others, if you consider installation and certification costs 90+% of the time I use the combination of MX20 moving map+terrain+NAV overlay with the 430 CDI page, yielding awesome SA for both VFR and IFR. Our Sandel EHSI also displays the GPS waypoint, flight plan, groundspeed as well as standard HSI info. Since flying behind the MX20/430 combo, I haven't unfolded a sectional, terminal or enroute chart while in the plane. Except to ID roads and lakes (on long boring flights), the 430 map page doesn't get used all that much. The display on the 430 works well for looking up NRST data for position fixes, waypoint info, setting up approaches, and other miscellaneous stuff. We don't have the weather input installed, so can't help you there. I'm not sure if the TIS info from a Garmin Mode S XPNDR (GTX330?) can be displayed on the MX20; that or perhaps a TCAD input would be really nice. Here's a link to the MX20 documentation: http://www.garminat.com/mx_docs.shtml (garminat.com is the website for the APOLLO products) If so, then it seems that the garmin 430 display space is a waste of valuable panel real-estate. If not, how are the two different displays used differently? Seems like it adds to workload that way to have to monitor 2 screens. |
OK, so does anyone know what a Garmin 430/Apollo MX-20 would cost to buy
and install. I think a Garmin 430 runs about $9K installed and an MX20 runs about $7.2K (just for the equipment). So, do you think I should figure $20K? The aircraft that I am considering is a Comanche 260 and it only has a Loran in it for area navigation. So, a GPS antenna would need to be installed and I would need a panel to switch between Nav and GPS (I figure that would cost a few $K). I am just looking for a ballpark figure here...for planning purposes. -Sami O. Sami Saydjari wrote: In an article at http://avionicswest.com/archive/shootout.htm#2003 about Garmin 530 vs CNX-80, many of the pilots said that they would want a combination of a Garmin 530 AND an MX20. I do not understand. Isn't the Garmin 530 also an MFD capable of displaying multiple inputs, like weather and terrain? Can someone tell me why both might be desirable? Does anyone have experience with an MX20? -Sami |
There are several I/O options for the MX20,
with different serial communications ports. Prices vary accordingly. Be sure you get prices for the configuration you need. I needed many of the advanced features for displaying and controlling radar, TCAD, and ChartView. ---JRC--- "O. Sami Saydjari" wrote in message = ... OK, so does anyone know what a Garmin 430/Apollo MX-20 would cost to = buy=20 and install. I think a Garmin 430 runs about $9K installed and an = MX20=20 runs about $7.2K (just for the equipment). So, do you think I should=20 figure $20K? The aircraft that I am considering is a Comanche 260 and = it only has a Loran in it for area navigation. So, a GPS antenna = would=20 need to be installed and I would need a panel to switch between Nav = and=20 GPS (I figure that would cost a few $K). I am just looking for a=20 ballpark figure here...for planning purposes. =20 -Sami =20 O. Sami Saydjari wrote: In an article at http://avionicswest.com/archive/shootout.htm#2003 = about=20 Garmin 530 vs CNX-80, many of the pilots said that they would want a = combination of a Garmin 530 AND an MX20. I do not understand. = Isn't=20 the Garmin 530 also an MFD capable of displaying multiple inputs, = like=20 weather and terrain? Can someone tell me why both might be = desirable?=20 Does anyone have experience with an MX20? =20 -Sami =20 |
| Thread Tools | |
| Display Modes | |
