Dead DG
Old February 23rd 06, 02:21 AM posted to rec.aviation.owning
Default Dead DG
Ummm.. make sure the Knob is not loose and turning freely. We had the
same symptoms, loose knob slipped "in" on the shaft hard against the
panel, so could not push the shaft in to uncage the gyro, so it coud
not be "set". Slid knob back out to proper position on shaft, toghten
set screw, fixed..
Maybe?
Dave
On Mon, 20 Feb 2006 22:33:53 -0600, "mbremer216"
Well, it looks like my directional gyro just went belly up. When I went for
a ride today, the setting knob was very sticky, and then suddenly not sticky
at all as it now rotates freely and doesn't feel like it is engaging
anything. The gyro card does not rotate with the knob.
I have a Cherokee with a heading tracking Autocontrol III autopilot.
What are opinions regarding having it rebuilt as opposed to replaced?
Thanks
Old February 23rd 06, 03:21 AM posted to rec.aviation.owning
Default Dead DG
Pack a small amount of paper into the knob's shaft hole so that the knob
can't slide onto the shaft too far. Some DG knobs, if allowed to slide all
the way onto the shaft, will hit the panel when you try to adjust the card.
If there isn't enough "throw" before the knob hits the panel, it won't allow
you to adjust the card. The set screw should hold it, but the paper trick
makes it fool proof and relieves the pressure from the set screw.
"Dave" wrote in message
set screw, fixed..
Maybe?
Dave
for
sticky
Thanks
Old February 23rd 06, 04:22 AM posted to rec.aviation.owning
Default Dead DG
Thought about that one. The shaft turns with the knob and also goes in and
out. I was, at first hoping it was the knob.
I have recently started some instrument training and when doind timed turns
noticed quite a bit of discrepancy between the clock and the resulting turn
(over 20 degrees). While I may not have been spot on in maintaining the
turn rate via the needle & ball, there's no way I was that sloppy,
particularly since the error was similar with turns in both directions.
I'm just going to change it rather than fix it. Now the challenge is to
find a replacement that won't break the bank.
Thanks
set screw, fixed..
Maybe?
Dave
for
sticky
Thanks
Old February 24th 06, 03:08 PM posted to rec.aviation.owning
Default Dead DG
Rmmmm?
Maybe I'm just confused or you were unclear. This reads as if your timed turns
aren't coming out on the right heading, so you're replacing your heading
indicator. I hope I'm wrong.
Dave
Old February 25th 06, 04:18 PM posted to rec.aviation.owning
Default Dead DG
I'm replacing the DG because the setting knob will no longer engage the
compass card. The DG is also behind the turns (turned at a rate slower than
the mag compass). Also, it's pretty old and is probably past it's service
life.
"Dave Butler" wrote in message
news:1140790596.591398@sj-nntpcache-3...
turns noticed quite a bit of discrepancy between the clock and the
resulting turn (over 20 degrees). While I may not have been spot on in
maintaining the turn rate via the needle & ball, there's no way I was
that sloppy, particularly since the error was similar with turns in both
directions.
Rmmmm?
turns aren't coming out on the right heading, so you're replacing your
heading indicator. I hope I'm wrong.
Dave
Old February 26th 06, 07:28 AM posted to rec.aviation.owning
Default Dead DG
On Sat, 25 Feb 2006 09:18:22 -0600, "mbremer216"
Valid reason.
Which could be quite normal. Mine, and most others, will at times even
turn the opposite direction. Just a fact of life and physics.
life.
If it still works it's not past a service life as I don't think they
have one.
www.rogerhalstead.com
directions.
Rmmmm?
Dave
American nazi pond scum, version two bushite kills bushite Naval Aviation 0 December 21st 04 11:46 PM
Hey! What fun!! Let's let them kill ourselves!!! [email protected] Naval Aviation 2 December 17th 04 10:45 PM
Dead Reckoning, with the 'a' David Megginson Piloting 8 August 11th 04 03:22 PM
Should Memorial Day and America's War Dead be commercialized? Otis Willie Naval Aviation 0 May 24th 04 03:29 AM
Should Memorial Day and America's War Dead be commercialized? Otis Willie Military Aviation 0 May 24th 04 03:29 AM
