#21
This is Mark Hickey's profile...........
Geez, ya think he's a pilot????? Most people I know that love bicycles are TREE HUGGERS and hate powered things. Like we didn't figure that out on the previous posts you made.. The Veep's shooting spree. rec.bicycles.tech moments ago Oh those CERTIFIED plane engines !!!!!!!!!!!!!!!!! rec.aviation.homebuilt moments ago Making Motorcycle Engines Fly... Litterally. rec.motorcycles.tech 7 hours ago Bike Fit rec.bicycles.tech 7 hours ago Road Tires. rec.bicycles.tech 7 hours ago The Veep's shooting spree. rec.bicycles.tech 8 hours ago The Bikes of China rec.bicycles.misc 8 hours ago Oh those CERTIFIED plane engines !!!!!!!!!!!!!!!!! rec.aviation.homebuilt 8 hours ago how long must threaded fork be to make it threadless rec.bicycles.tech 41 hours ago The Veep's shooting spree. rec.bicycles.tech 41 hours ago |
![]() stol wrote: For all you guys and gals building a homebuilt plane DO NOT use a auto engine conversion or any other option that is not FAA certified, Ya see the feds and Lycoming have a lock on the market providing "quality and time tested powerplants". Let's see now. it all started a few years back when Lycoming had a brain fart and decided they knew more about crankshafts then god, so they redid them, with the FAA's blessing of course. Ya know the feds demand strict safety testing and "high" quality control over certified parts. Well, that batch of hundreds had several break and kill a few innocent souls, So they recalled them and redesigned the problem out of them and in the meantime kept hundrends of planes grounded for months while they " patched" the issue. They introduced a "New and Improved" crank that would cure all their issues. Well, those broke at a alarming rate and killed 14 innocent souls. All the while with the feds watching this all unfold. Lycoming then tried to sue the forging company that stamped out the cranks that THEY speced the design for. Well, that didn't fly either. So here comes round number three. Too bad they don't have the three strike rule in aviation.. http://www.lycoming.textron.com/supp...tins/SB569.pdf Ben www.haaspowerair.com ya, I am the bad guy trying to get ol Barnyard Blob to wake up. G I've got a reason for delaying any decision regarding a kit or the engine. TBOs asice, theres the basic reliability factor. I'm not comnfortable with the current options based on the remote areas I would plan to go. i know there aren't that many engine failures, but I have a magnetic draw to Murphy. He'd certainly be my passenger running somewhere between Calgary and Anchorage. |
![]() Richard Lamb wrote: RapidRonnie wrote: Bottom line is that if you use an auto engine made in the millions you can research the failure rate, particularly if you pick an engine used in motorsports run to destruction you can see where they fail first. I would pay a premium, a big premium, to be able to fly a small block Chevy in terms of a bigger airframe than you otherwise would, just for that huge knowledge base. Gently disagree, Ron. The reason is that the prop loads are far different from anything you'll see on the race track. If I may be forgiven (or not) for reading about the Corvair crank failures with rectal vision, they should not have surprised anyone. I have never heard of anyone breaking the crankshat in their family car, that includes VWs. That tells me that auto manufacturers in general and VW in particular have sucessfully designed their cranks to last indefinately under nominal and even somewhat more adverse than nominal conditions. One supposes, however, that auto manufacturers do not make the crank a whole lot stronger than needed to achieve that result. A part that lasts indefinately is not improved by making it last longer than indefinately when doing so would add weight which, especially to a high RPM moving part, is generally a bad idea. There are a lot of VW powered airplanes, and it is not uncommon for the crankshaft to break in those. If we make the unremarkable assumption that GM did not over- design their Corvair crankshats any more than VW did theirs then the Corvair crankshaft failures are quite predictable. It is highly unlikely that any auto manufacturer is going to put a crankshaft that is a whole lot stronger than needed into a standard engine, don't you think? -- FF |
Orval Fairbairn wrote:
In article .com, wrote: Richard Lamb wrote: RapidRonnie wrote: Bottom line is that if you use an auto engine made in the millions you can research the failure rate, particularly if you pick an engine used in motorsports run to destruction you can see where they fail first. I would pay a premium, a big premium, to be able to fly a small block Chevy in terms of a bigger airframe than you otherwise would, just for that huge knowledge base. Gently disagree, Ron. The reason is that the prop loads are far different from anything you'll see on the race track. If I may be forgiven (or not) for reading about the Corvair crank failures with rectal vision, they should not have surprised anyone. I have never heard of anyone breaking the crankshat in their family car, that includes VWs. That tells me that auto manufacturers in general and VW in particular have sucessfully designed their cranks to last indefinately under nominal and even somewhat more adverse than nominal conditions. One supposes, however, that auto manufacturers do not make the crank a whole lot stronger than needed to achieve that result. A part that lasts indefinately is not improved by making it last longer than indefinately when doing so would add weight which, especially to a high RPM moving part, is generally a bad idea. There are a lot of VW powered airplanes, and it is not uncommon for the crankshaft to break in those. If we make the unremarkable assumption that GM did not over- design their Corvair crankshats any more than VW did theirs then the Corvair crankshaft failures are quite predictable. It is highly unlikely that any auto manufacturer is going to put a crankshaft that is a whole lot stronger than needed into a standard engine, don't you think? Automotive crankshafts are designed to take loads in predominately torquing modes, while aircraft crankshafts have to take bending and thrust loads, due to the fact that they have a very large flywheel hanging on the end, which resists changes in direction. Either engine will work quite nicely for the purpose for which it was intended. It is when you change the mission that you had better understand how the mission changes the operating environment vs the design parameters. And, as Orval had likely experienced himself, (dam long limber chain drives?) PSRU's may take the gyroscopic forces out, but can add harmonic resonance issues that may be even tougher to deal with than a simple broken crank shaft... It all looks so easy on paper... Richard |
![]() wrote If I may be forgiven (or not) for reading about the Corvair crank failures with rectal vision, they should not have surprised anyone. If you would read the site again, I think you will find that the breaking problem is limited to higher speed airplanes, not stuff like aircampers, right? It is highly unlikely that any auto manufacturer is going to put a crankshaft that is a whole lot stronger than needed into a standard engine, don't you think? Some manufacturers, at certain times in their lifespan, are less comfortable with cutting design strength margins too closely. GM is more likely to build hell for stout, than are many of the imports, IMHO. -- Jim in NC |
#29
On Sun, 5 Mar 2006 14:22:07 -0500, "Morgans"
wrote: wrote If I may be forgiven (or not) for reading about the Corvair crank failures with rectal vision, they should not have surprised anyone. If you would read the site again, I think you will find that the breaking problem is limited to higher speed airplanes, not stuff like aircampers, right? It is highly unlikely that any auto manufacturer is going to put a crankshaft that is a whole lot stronger than needed into a standard engine, don't you think? Some manufacturers, at certain times in their lifespan, are less comfortable with cutting design strength margins too closely. GM is more likely to build hell for stout, than are many of the imports, IMHO. And even more than the "aircraft" manufacturers, where weight IS the enemy, and where change for improvement's sake is very much frowned upon. If you change or improve something, you are admitting something was less than perfect, and leaving yourself vulnerable to that "unwashed horde" known as the "legal proffesion". *** Free account sponsored by SecureIX.com *** *** Encrypt your Internet usage with a free VPN account from http://www.SecureIX.com *** |
#30
In article t,
Richard Lamb wrote: Orval Fairbairn wrote: In article .com, wrote: Richard Lamb wrote: RapidRonnie wrote: Bottom line is that if you use an auto engine made in the millions you can research the failure rate, particularly if you pick an engine used in motorsports run to destruction you can see where they fail first. I would pay a premium, a big premium, to be able to fly a small block Chevy in terms of a bigger airframe than you otherwise would, just for that huge knowledge base. Gently disagree, Ron. The reason is that the prop loads are far different from anything you'll see on the race track. If I may be forgiven (or not) for reading about the Corvair crank failures with rectal vision, they should not have surprised anyone. I have never heard of anyone breaking the crankshat in their family car, that includes VWs. That tells me that auto manufacturers in general and VW in particular have sucessfully designed their cranks to last indefinately under nominal and even somewhat more adverse than nominal conditions. One supposes, however, that auto manufacturers do not make the crank a whole lot stronger than needed to achieve that result. A part that lasts indefinately is not improved by making it last longer than indefinately when doing so would add weight which, especially to a high RPM moving part, is generally a bad idea. There are a lot of VW powered airplanes, and it is not uncommon for the crankshaft to break in those. If we make the unremarkable assumption that GM did not over- design their Corvair crankshats any more than VW did theirs then the Corvair crankshaft failures are quite predictable. It is highly unlikely that any auto manufacturer is going to put a crankshaft that is a whole lot stronger than needed into a standard engine, don't you think? Automotive crankshafts are designed to take loads in predominately torquing modes, while aircraft crankshafts have to take bending and thrust loads, due to the fact that they have a very large flywheel hanging on the end, which resists changes in direction. Either engine will work quite nicely for the purpose for which it was intended. It is when you change the mission that you had better understand how the mission changes the operating environment vs the design parameters. And, as Orval had likely experienced himself, (dam long limber chain drives?) PSRU's may take the gyroscopic forces out, but can add harmonic resonance issues that may be even tougher to deal with than a simple broken crank shaft... It all looks so easy on paper... I didn't experience it myself, but I have witnessed a few less than spectacular results. One was a Ford V-6 in a Mustang II -- very poor job, V-belt broke and took out the ignition -- fatal. Another two were in Stewart 51s: one was a Ford V-8 with full electronic fuel injection, etc. The computer took awhile to set up for high power, then took awhile for low power. It got some bent valves. Owner replaced it with a Walther turbine after only four flights. Another S-51 had a chain drive PSRU, which started eating up the PSRU housing because of chain slop -- there were no tensioners on the chain. I have also seen a few successes, too. One was the late George Morse's Olds V-6 in his Skybolt and later in the Prowler. He found that you need an AN water pump instead of the automotive one and that you also need a coolant pressure indicator, in addition to temperature. Another success (so far) is an S-51 with a V-8 (geared PSRU) that ahs been flying here for about a year. I don't know what problems (if any) he has had, but he is taking small steps. As I posted earlier, you CAN fly, successfully, on automotive conversions, but it is not for the novice and technically-inexperienced. |
It sure makes a difference to own your own plane!! | Marco Rispoli | Piloting | 9 | June 29th 04 11:15 PM |
Rental policy | Robert | Piloting | 83 | May 13th 04 05:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Accident Statistics: Certified vs. Non-Certified Engines | Ron Wanttaja | Home Built | 23 | January 18th 04 05:36 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
