Kneeboards, etc.
Old March 19th 06, 11:14 PM posted to rec.aviation.piloting
Default Kneeboards, etc.
I'm a newly minted PP-ASEL flying a C-182. I was wondering what
different solutions pilots have come up with for cockpit data and
checklist management. I've tried kneeboards and find them somewhat
limiting and limited. What do the rest of you do to manage
checklists, charts, airport info, etc?
Right now I'm flying VFR but plan on instrument training when I have
some more time under my belt. I'm sure the data management needs
change when flying IFR.
Thanks for any tips or suggestions.
CPW
Old March 19th 06, 11:22 PM posted to rec.aviation.piloting
CPW
I mostly fly a PA28 (or C172) and use a Tri-Fold kneeboard to carry
checklist, alternate approach charts, pens, pencil, plotter, etc. etc.
I also have a yoke mount clipboard for the flightplan and approach
plate in use with attachments for clock/timer, torch and spare
pen/pencils.
Old March 19th 06, 11:26 PM posted to rec.aviation.piloting
The nice thing about the 182 is the big space between the two front
seats. There is plenty of room to place a small duffle to hold anything
you need within easy reach.
I made my own flip-style checklist which I pick up and set down as I
need it.
I use a kneeboard to write frequencies, weather, clearances, etc.
I also keep a copy of my flight log attached to record all the
incidental times (start/stop, wheels on/wheels off, time arrived at fix,
etc.)
I fold my charts for the area/route I am flying and set them between the
seats when not looking at them.
A flight calculator, handheld radio and headlamp/flashlight are in the
bag between the seats along with spare batteries/battery packs.
Old March 19th 06, 11:41 PM posted to rec.aviation.piloting
I used a word processor and made my own customized checklist. After I
got it down just right I laminated it. I put it in the side pocket. For
a writing pad, I use a 1/2 size yellow pad (4 1/4 x 6 1/2). For charts
I got www.airchart.com VFR and IFR binder charts. I prefer the WACs, he
give s you the whole country in one easy package. For approach plates,
I use the bound govt ones (the pages dont come out which is good
because that means they are always where they should be, and the govt
ones are less expensive). I just put them on the floor when not on my
knee. I always have a couple of pens and a pad of stickies. I put my
heading into the heading bug, altitude into the altitude bug and freqs
into the radio. When things get busy, I have no time to write those
down. I do write down my route clearances.
You can try all the fancy kneeboards but I found I was better off
without them. Just more clutter. I'm kind of a minimalist, but you find
most pro pilots just use the pad of paper from the hotel and the charts
the way they come from the issuer.
Old March 20th 06, 12:38 AM posted to rec.aviation.piloting
With a stick, either center or side, a fancy military style
kneeboard is nice, with a control wheel, the kneeboard gets
in the way. For general use, I like the cheap vinyl
secretary 5x8 yellow pad with a clear plastic insert, which
can hold an approach plate. I write on the yellow pad and
stick a plate under the clear plastic. I use a Third Hand
clip from Sporty's to hold it on my thigh. It is light and
cheap and can be slid to the side out of the way.
There is room in the slot behind the pad for a couple of
plotters and pencils.
James H. Macklin
ATP,CFI,A&P
some support
"Doug" wrote in message
checklist. After I
side pocket. For
1/2). For charts
the WACs, he
approach plates,
is good
and the govt
when not on my
stickies. I put my
bug and freqs
write those
better off
but you find
and the charts
Old March 20th 06, 01:28 AM posted to rec.aviation.piloting
I'm not a fan of kneeboards when used in yoke equipped aircraft. I had a
friend killed demonstrating a P38 while wearing a kneeboard that was
considered a major contributing cause in the crash.
As for GA airplanes with yokes, I just don't like the distance equation
between the yoke and the kneeboard as the yoke comes aft in it's normal
travel for positive pitch.
It's a judgment call of course, and some pilots do use them and haven't
complained of issues, but my business is flight safety, and I always make it
a point to mention how I feel about kneeboards when asked, or when not asked
:-) if someone posts here about using them.
Just be extremely careful and aware of the possible control confliction
issue.
Dudley Henriques
"cpw" wrote in message
CPW
Old March 20th 06, 12:28 PM posted to rec.aviation.piloting
On Mon, 20 Mar 2006 01:28:57 GMT, "Dudley Henriques"
issue.
Dudley Henriques
A very interesting reply Dudley. I have short legs so sit fully
forward in PA28/C172. I also make a point of reducing the seat height
to it's lowest to give maximum clearance for just that reason. When
checking for 'controls full & free movement' it's the mid range fully
left or right which affects me! Unfortunately my wife has very much
longer legs and I have to remember to warn her when I'm checking 'full
& free movement' :-)
David
Old March 20th 06, 01:50 PM posted to rec.aviation.piloting
it
asked
issue.
Dudley Henriques
David
As I said David, it's a toss up, like everything else in the add on goodies
category you can stuff in the cockpit with you :-)
A lot depends on the specific airplane you're flying as to exactly where
something will go. You can put something one place in one airplane that will
conflict like hell in the next one you fly.
The basic answer with these things is to be aware, which obviously you are.
What I would do in your case is to actually sit down in the cockpit of each
airplane of choice on the ramp and physically check your favored seat
position vs control movement vs the exact kneeboard of choice. You will
either find it's a non issue or a POSSIBLE issue. If it's a POSSIBLE issue
in any situation,(consider the crosswind flare carefully) then make your
decision based on this input.
Dudley Henriques
Old March 20th 06, 02:40 PM posted to rec.aviation.piloting
On Mon, 20 Mar 2006 13:50:43 GMT, "Dudley Henriques"
it
asked
issue.
Dudley Henriques
David
Dudley Henriques
Dudley, thanks.
If there was any problem my answer is to keep my knees slightly
further apart and let the left side of the kneeboard fall between my
legs. As for my Wife she knows that she'll have to move!!!
Most 172's means I only get full rudder using the balls of my feet but
the Warrior allows me to be more flat footed, which I prefer!
As you say you need to just sit in the cockpit and work it all out.
I once deliberately made a X/wind landing in the Warrior with about
15Kt X/w and 25° flap, just to see if I could cope if I had to. I'm
pleased to say it went well and I'm still here, although one pilot
listening on the frequency said afterwards why on earth would you want
to do that :-) Why? for the same reason I took off to 200ft and did a
PFL to the runway, just to make sure I could, should the fan stop for
real.
David
Pub Bags and Kneeboards Pilot3400 Military Aviation 0 July 21st 04 03:35 PM
Pub bags and kneeboards Pilot3400 Military Aviation 0 February 27th 04 07:42 PM
Pub Bags and Kneeboards Pilot3400 Military Aviation 0 January 16th 04 05:56 PM
Flight Bags and Kneeboards Pilot3400 Military Aviation 0 August 29th 03 03:21 PM
