Question about the Sport Pilot designation
Old March 20th 06, 12:02 AM posted to rec.aviation.piloting
Default Question about the Sport Pilot designation
I just read a description of the limitations imposed on light sport
pilots, including the following: no flights into Class A airspace,
which is at or over 18,000' MSL; no flights into Class B, C, or D
airspace unless you receive training and a logbook endorsement; and no
flights above 10,000' MSL. It looks like taxiing is the only safe
bet.
If someone was to ask, "Well, what can the sport pilot do," what
would be the answer?
AJ
Old March 20th 06, 01:30 AM posted to rec.aviation.piloting
"AJ" wrote in message
bet.
This sounds all too much like a troll, but I'll play.
Fly anywhere you want to, with relatively simple signoffs, as long as you
don't go really high, like most single engine piston pilots don't do,
anyway.
Fly in VFR conditions, like most single engine piston pilots prefer, anyway.
Fly smaller sized aircraft, with speeds limited to what many single engine
piston planes will never go faster than, anyway.
Fly around with a buddy, which around 50% or more pilots of single engine
piston airplanes don't exceed, anyway.
Fly in a new single engine piston aircraft, with many models costing from 50
to 85 thousand dollars. Try buying a new non-sport airplane for anywhere
near that cost.
Fly in the daytime only, which 75% or more single engine piston flights are,
anyway.
So, in a paraphrase of a very old Wendy's add, "Where's the beef?" You can
do most of what the majority of pilots of single engine piston airplanes do.
Less cost, newer equipment possible, less training.
If you don't like the limitations and can pass a medical, go for the full
ticket. Sport pilot is still a great thing for a great many people , who
due to a technicality, can not pass a medical, or don't want to spend the
money to pass a medical.
Old March 20th 06, 12:32 AM posted to rec.aviation.piloting
Almost anything in day/VFR with one passenger. The Class
BCD airspace endorsement is not too hard to do, a student
pilot may also do those areas solo. Most light aircraft do
not fly above 10,000 feet.
You can learn and do aerobatics, fly cross-country,fly land
and seaplanes or skis, airplanes, helicopters.
James H. Macklin
ATP,CFI,A&P
some support
light sport
airspace,
C, or D
endorsement; and no
only safe
| bet.
do," what
| AJ
Old March 20th 06, 12:38 AM posted to rec.aviation.piloting
Thanks to Jim and Morgans for the replies. I'm not a troll (physical
appearances aside), and the question was an honest one. Thanks for the
honest answers -- they helped a great deal.
AJ
Old March 20th 06, 03:41 AM posted to rec.aviation.piloting
Great. Honestly, there are some compromises that you give up, with SP. To
me, wanting to go cross country, not being able to fly at night is a
problem. Other than that, the limitation is with the plane.
One of the biggest limitations with the plane, as I see it, is the
limitation of the powerplant. There are not a lot of choices out there, to
keep the airframe at a reasonable weight, and give it a reasonable useful
load. If only they had given us a couple hundred pounds more!
Of course, you could play the "if only" game, about many of the
limitations, but "it is what it is."
What it really comes down to is, it give a lot of people a chance to get
their feet off of the ground, that might have not been able to, any other
way. All of the trade-offs seem very reasonable, at that point!
Old March 20th 06, 03:05 AM posted to rec.aviation.piloting
if I am not mistaken you can fly rotorcraft, but not helicopters,
i.e., you are limited to the gyroplane class in this category. But
then may be I misunderstood the new FARs (quite a different style
from the rest of the regulations); anyone?
--Sylvain
Old March 20th 06, 07:22 AM posted to rec.aviation.piloting
You may be correct, I said helicopter but
rotorcraft/gyroplane sounds right.
Thanks for the correction.
James H. Macklin
ATP,CFI,A&P
some support
"Sylvain" wrote in message
land
helicopters,
category. But
different style
| --Sylvain
Old March 20th 06, 02:24 AM posted to rec.aviation.piloting
The "no flights into Class B, C, or D" restriction is not much of a
restriction at all since, as you already noted, it can be removed with some
training.
Basically, a Sport Pilot can do practically all of the kinds of flying that
many people who never stray far from home and just enjoy local sightseeing
and $100 hamburger flights. I used to use airplanes for lots of
long-distance traveling, but frankly in the last few years very little of my
flights could not have been done under a Sport Pilot certificate. I know
lots of pilots who are similar.
Beyond that, it provides a much more effective stepping stone to the Private
Pilot certificate than the Recreational certificate did. Dan Ford
notwithstanding, few pilots found the Recreational certificate to be a
useful route to take, given how little they trimmed from the Private in
terms of training requirements for it.
Pete
Old March 20th 06, 10:51 AM posted to rec.aviation.piloting
On Sun, 19 Mar 2006 18:24:29 -0800, "Peter Duniho"
Dan Ford
I would be the first to say that I am a special case. Call me the
exception that proves (tests) the rule. I had no intention of flying
at night, I didn't like the Cessnas that I would have had to
transition into (nothing against the airplane, only the iterations
available at that particular airport), and I only wanted to fly the
Cub, which became an obsession with me almost from the first day I
flew one. Plus I was 66 at the time, and the fewer things I had to
master, the better.
I don't know which I would do today, recreational cert or Sport Pilot.
I'm happy with the former now that it has been expanded to include
controlled airspace.
-- all the best, Dan Ford
email: usenet AT danford DOT net
Warbird's Forum: www.warbirdforum.com
Piper Cub Forum: www.pipercubforum.com
In Search of Lost Time: www.readingproust.com
Old March 20th 06, 03:28 PM posted to rec.aviation.piloting
66 at the time? You give me hope, Dan!
AJ
LSA instructor? [email protected] Piloting 43 August 12th 05 03:17 PM
FAA has temporarily withdrawn the proposed Sport Pilot rule Larry Dighera Piloting 2 March 27th 04 06:23 AM
