#21
Didn't see 3/8 mile anywhere.
NASDAC BRIEF REPORT -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- GENERAL INFORMATION Data Source: AVIATION SAFETY REPORTING SYSTEM Report Number: 294800 Local Date(Yr/Mon): 199501 Local Day: Local Quarter Time: 0601 To 1200 Facilty ID Nr Aircraft: ATL State of Facility Nr Acft: GA Magnetic Bearing (deg): Facility Distance (nm): Altitude AGL - LO(ft) 0 Altitude AGL - HI(ft) 200 Altitude MSL - LO(ft) Altitude MSL - HI(ft) -------------------------------------------------------------------------------- Environmental/Location Information Weather Conditions: IMC Ceiling: 200 Light Condition: Daylight Runway Vis - LO(ft): 5000 Runway Vis - HI(ft): 5000 Visual Range - LO (sm): .5 Visual Range - HI (sm): .5 -------------------------------------------------------------------------------- SYNOPSIS ACFT DEVIATED FROM LOC (FULL-SCALE DEFLECTION), AND CONTINUED BELOW DECISION HEIGHT TO LNDG, AFTER SEVERAL WILD BANKS. -------------------------------------------------------------------------------- NARRATIVE ON APCH INTO ATL, 2700 FT MSL, 1 MI OUTSIDE FINAL APCH FIX, THE ACFT WAS STABILIZED. CAPT FLYING FLEW THROUGH THE LOC, OVER COMPENSATED AND FLEW BACK THROUGH THE LOC AGAIN AT THE MARKER. ONCE THE MARKER LIGHT ILLUMINATED, THE 'GEAR DOWN/LNDG CHKLIST, TO THE LINE, WAS CALLED. I PROCEEDED WITH THE LNDG CHKLIST AND CALLED OUT THE MAJOR DEVS. SEVERAL WILD EXCURSIONS ENSUED. AT 400 FT AGL, WE WERE FULL-SCALE R OF LOC AND ON GS. I CALLED GAR, AT THAT POINT, NOW 200 FT AGL, WE BROKE OUT WELL R OF THE RWY AND ADJACENT TO THE TOUCHDOWN ZONE. THE CAPT CALLED GAR. I PUSHED UP THE PWR, TO WHICH HE CALLED, 'NO, I GOT THE RWY MADE.' LNDG WAS MADE AFTER SEVERAL WILD BANKS AND AN ENSUING JEST BY THE TWR. I SHOULD HAVE BEEN MORE ASSERTIVE AS AN FO AND NEVER ALLOWED THE APCH TO PASS THE FIRST DEV AFTER MISSING THE LOC. -------------------------------------------------------------------------------- Aircraft Information -------------------------------------------------------------------------------- Findings For Aircraft Sequence 1 -------------------------------------------------------------------------------- General Info Acft Make/Model Desc: Brasilia EMB-120 All Series Crew Count: 2 Passenger Count: Aircraft Involved: Unique Event Flight Conduct Rule: Part 121 Flight Purpose: Passenger Operation Type Carrier Operation: Air Carrier GA Operation: Other Operation: Phase of Flight Climbout: Climbout Other: Cruise: Other Cruise: Descent: Approach Other Descent: Ground: Other Ground: Landing Other Landing: Landing Other Flight Phase: Airspace Info Class A: Class B: ATL Class C: Class D: ATL Class E: Class G: Special Use: Temp Use: -------------------------------------------------------------------------------- Findings Anomaly Descriptors Acft Equip Anomaly: ASP Anomaly: Alt Dev Anomaly: Cabin Event Anomaly: Conflict Anomaly: Excursion Anomaly: Ground Encounter Anomaly: Incursion Anomaly: In-Flight Anomaly: Maintenance Anomaly: Non-Adherence Anomaly: Published Procedure Non-Adherence Other Anomaly: Other Anomaly: Other Spatial Dev. Anomaly: Track Or Heading Deviation Anomaly Consequences Consequence Desc: Other Consequence Desc: Misc. Consequence Desc: Anomaly Detected By Controller A: Unspecified Controller B: Crew A: Unspecified Crew B: Anomaly Resolution Aircraft: Controller: Crew: Other Action: No Action: Anomaly Accepted Event Type: Unique Event -------------------------------------------------------------------------------- Reporter Information -------------------------------------------------------------------------------- Findings For Reporter Sequence 1 -------------------------------------------------------------------------------- Reporter Function Controller: Flight Attendant: Flight Crew: First Officer Instructor: Maintenance: Observer: Other Personell: Oversight: Reporter Activity: Monitoring -------------------------------------------------------------------------------- Findings For Reporter Sequence 2 -------------------------------------------------------------------------------- Reporter Function Controller: Flight Attendant: Flight Crew: Captain Instructor: Maintenance: Observer: Other Personell: Oversight: PIC Reporter Activity: Pilot Flying -------------------------------------------------------------------------------- Findings For Reporter Sequence 3 -------------------------------------------------------------------------------- Reporter Function Controller: Local Flight Attendant: Flight Crew: Instructor: Maintenance: Observer: Other Personell: Oversight: Reporter Activity: Controlling -------------------------------------------------------------------------------- END REPORT "Matt Barrow" wrote in message ... | | "Jim Macklin" wrote in message | news:9MLVf.913$t22.188@dukeread08... | I can't answer that because I never saw the airport or | approach identified, so I can't look it up. Was it in the | USA or Europe? But if there was an accident, the current | reported weather would be reported. | | | | | https://extranet.nasdac.faa.gov/pls/portal/STAGE.ASRS_BRIEF_REPORT?RPT_NBR=294800&AC_VAR=TRUE &RPRT_VAR=TRUE&ANMLY_VAR=TRUE&SYN_VAR=TRUE&NARR_VA R=TRUE&NARR_SRCH='' | | |
An interesting sidelight. Instructing China airlines pilots in the MD-80
flight simulator. The procedure is to have the FO be the "pilot flying" even though he is really just monitoring the autopilot. The Captain is looking for the runway as they approach minimums. We brief them that if the Captain doesn't see the runway and call that out and assume control by minimums, the FO is to execute a go around. We had a hard time with their culture to convince the Captain that this is OK. The Captains thought this violated the Captain's authority by allowing the FO to make the go around just because the Captain hadn't said anything by minimums. We finally got around that by telling the Captain that HE has briefed the FO to go around under those conditions so the FO is only following the Captain's instruction. -- Darrell R. Schmidt B-58 Hustler History: http://members.cox.net/dschmidt1/ - "Jon Woellhaf" wrote in message . .. I guess it's time to repost this: (A recent update to the British Airways Flight Operations Manual) Flight Operations Department Notice, Operational Origin: Operational Standards Group to: All fleets - long and short haul. Eff. Date: 01-05-95. Subject: Pilot Role Reversal During PICUS. There appears to be some confusion over the new pilot role titles. This notice hopefully will clear up any misunderstandings. The titles P1, P2 and copilot will now cease to have any meaning within the BA operations manuals. They are to be replaced by Handling Pilot, Non-Handling Pilot, Handling Landing Pilot, Non-Handling Landing Pilot, Handling Non-Landing Pilot and Non-Handling Non-Landing Pilot. The Landing Pilot is initially the Handling Pilot and will handle the takeoff and landing, except in role reversal when he is the Non-Handling Pilot for taxi until the Handling Non-Landing Pilot hands the handling to the Landing Pilot at 80 knots. The Non-Landing (Non-Handling, since the Landing Pilot is handling) pilot reads the checklists to the Handling Landing Pilot until after the Before Descent Checklist completion, when the Handling Landing Pilot hands the handling to the Non-Handling Non-Landing Pilot who then becomes the Handling Non-Landing Pilot. The Landing Pilot is the Non-Handling Pilot until the "Decision Altitude" call, when the Handling Non-Landing Pilot hands the handling to the Non-Handling Landing Pilot, unless the latter calls "Go Around," in which case the Handling Non-Landing Pilot continues handling and the Non-Handling Landing Pilot continues non-handling until the next call of "Land" or "Go Around," as appropriate. In view of recent confusion over these roles, it was deemed necessary to restate them clearly. Authority: Operational Standards Group S 4220 H3 TBA,OPS12/A34/0595 |
![]() "Jim Macklin" wrote in I can't answer that because I never saw the airport or approach identified, so I can't look it up. Was it in the USA or Europe? But if there was an accident, the current reported weather would be reported. here's the first segment of the original post in this thread: ******************** NASA ASRS Incident #294800, Atlanta, GA (ATL): ------------------------------------ Crew: Two-man crew, Captain (CAPT) and First Officer (FO); report submitted by FO Aircraft: MDT (Medium Transport, 30,001 - 60,000 lbs); large turboprop Flight Conditions: IMC; apparent ceiling 200 ft ILS Approach Min: 200 ft ceiling and 3/8 mi visibility ***************************** Note: "Atlanta, GA (ATL)" and "ILS Approach Min: 200 ft ceiling and 3/8 mi visibility" That's what I'm referring to. I've never seen an ILS with these minimums, and I've flown lotsa lotsa ILSs into ATL (although, some were Cat II and III) Maybe a typo, but that's why I asked. |
![]() "Jim Macklin" wrote in Didn't see 3/8 mile anywhere. here's the first segment of the original post in this thread: ******************** NASA ASRS Incident #294800, Atlanta, GA (ATL): ------------------------------------ Crew: Two-man crew, Captain (CAPT) and First Officer (FO); report submitted by FO Aircraft: MDT (Medium Transport, 30,001 - 60,000 lbs); large turboprop Flight Conditions: IMC; apparent ceiling 200 ft ILS Approach Min: 200 ft ceiling and 3/8 mi visibility ***************************** |
Did the Germans have the Norden bombsight? | Cub Driver | Military Aviation | 106 | May 12th 04 07:18 AM |
Why was the Fokker D VII A Good Plane? | Matthew G. Saroff | Military Aviation | 111 | May 4th 04 05:34 PM |
No US soldier should have 2 die for Israel 4 oil | Ewe n0 who | Military Aviation | 1 | April 9th 04 11:25 PM |
Germany Lost the War... So What? | robert arndt | Military Aviation | 55 | February 26th 04 08:51 AM |
What about the AIM-54 Pheonix Missile? | Flub | Military Aviation | 26 | October 5th 03 05:34 AM |
