Some additional comments to this excellent list.
I had a turbo normalized Mooney. Did not have an inter cooler which would have helped reduce some heat especially CHT on climb out. I'm here in Houston and in summer time I'd climb 10-15 mph faster than published figures to keep engine well below red line (baby that baby). This of course caused more time to altitude. At destination I'd pull MP back 5 or so inches (keeping good power on engine to prevent cooling shock) and run AS up to yellow line for descent. My block time was as good or better than published even with the very slow climb. On comment #5. 100% on the mark. This relates directly to $ and down time to replace the turbo. Cool that baby off before shut down. Additional. Don't over boost the engine. Again more $ exposure and possible failure when you don't want a failure if you have stressed the engine. The Bo's a good bird. Most accidents in it are related to pilot proficiency and bad decisions. I'd get a pencil and paper and lay out the good and bad of the 210-182-Bo for my requirements before I put my money down. I've got time (and instructed in) 182-210 and a little in Bo. Also T-34 time). All good birds if maintained properly. If I were going to lay out hard cash I'd go fly (rent) each bird that I didn't have time in and fly it on a typical mission to see how it fit my requirements. Keep the fan turning and the beer cold ![]() Big John `````````````````````````````````````````````````` ````````````````````````` On Mon, 27 Mar 2006 10:28:26 -0700, Michael 182 wrote: I've owned a TR182 for about five years. Here are a few impressions: 1) The turbo is HOT, and the heat causes some engine problems. I've replaced the turbo once, and had various waste gate and hose problems along the way. Not a huge concern, but has probably averaged $500-700 a year over the five years. 2) The oil cooler is not efficient. Climb out on a hot day (especially in Colorado, where I live) generally has to be done as a step climb to keep the oil cool enough. There is an STC to add an additional cowling hole in front of the oil cooler, but I believe it would trim a few knots off the plane as well. 3) Given that the engine runs hot, it is a good idea to try and avoid shock cooling. Plan ahead. 4) There is a carb heat knob. I've never used it. (See engine runs hot, above....) 5) Always, always, always let the engine idle for at least four minutes before shutdown to keep the turbo alive another day. 6) The turbo is, of course, a normalizer. I get 31" on climbout up to about 8,000 feet. 28" at about 10,000. 17" at FL180. Obviously different numbers in summer and winter, but that's a general idea. 7) Cruise speeds do not really match the book, at least in my plane. I get roughly 140 at 5.000, 150 at 10,000, 160 at 17,000. 8) Although everyone talks about it, I've never had a landing gear problem, except one self-induced problem when I did a carrier landing after encountering some low wind shear and I got a hairline crack in part of the gear. That was expensive - around $1,500 I believe. 9) I don't have a lot of experience with other planes, but I have to say that the 182 is a very simple IFR platform. Very stable, trim works excellently, easy to nail the ILS almost hands off. 10) Along the same lines, it is a very forgiving airplane. Having the gear to drop is like being able to throw out an anchor - makes speed management and descents pretty simple. 11) It can haul a lot of weight. Although I have not, of course, ever exceeded the weight part of the W&B, no matter what load has been in the plane I have been able to get 600 fpm climb out of my 5,000 foot airport on a hot summer day. Alone on a cold winter day I can be at 17,000 feet in less than 15 minutes. 12) Fit and finish is typical of a 25 year old Cessna. Lots of air leaks. Luckily it has a good heater. Don't expect to stay dry flying through heavy rain. 13) I've run the engine at all types of settings, but I feel most comfortable about protecting the cylinders by running about 100 degrees rich. This gives me fuel burn of about 15gph at 10,000 and about 13 gph at 17,000. You can certainly run it much leaner, but I believe it will show up in the annual compression checks. By the way, the $160 K is high (although I wish it wasn't). There's probably more, but I can't think of it off the top of my head. Feel free to email me off line. Michael |
Naval Air Refueling Needs Deferred in Air Force Tanker Plan | Henry J Cobb | Military Aviation | 47 | May 22nd 04 03:36 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
