![]() "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote Same problem in the auto industry. The bigges difference is that broken cranks or cams or... show up in the warrenty data - not in NTSB accident reports. Can you point to a major auto maker's crankshaft recall? -- Jim in NC |
"Morgans" wrote in message
... "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote Same problem in the auto industry. The bigges difference is that broken cranks or cams or... show up in the warrenty data - not in NTSB accident reports. Can you point to a major auto maker's crankshaft recall? -- Jim in NC Manufacturer Number Product Reason Country Year General Motors 150000 Chevrolet, Chevette, PontiacT-1000 Defective crankshaft U.S.A 0/1986 Mazda 25400 Familia, Laser Danger of crankshaft fracture and engine damage due to defective bolts WORLD WIDE 7/1990 Suzuki Motor Corporation has determined that the Eiger automatic ATVs were produced with an internal manufacturing flaw. This flaw could cause the crankshaft to break during operation. A broken crankshaft will interrupt power transfer from the engine to the transmission and the drive wheels, leaving the driver stranded away from his or her base of operation. My dad had a mid 70's Plymouth that broke 2 cranks in about as many years - last time he ever bought a Chrysler product. Don't know if there was ever a recall, or it was just covered under the warrenty. Plus, if you break, say 0.01% of the crankshafts (1 out of 10,000), would that trigger a recall for a car? How about for an aircraft? I think the "threshold" is a lot different. As suggested by the following: ........ begin quote...... A 'walking' crankshaft is a crankshaft that moves too much inside the engine. This is also known as excessive thrust bearing play. The movement is usually due to the crankshaft not fitting inside its bearings correctly. While not bad for the crankshaft, the movement can place excessive or uneven loads on the bearings, causing premature failures. Many 2G owners have suffered from walking crankshafts. It appears that Mitsubishi built many 2G engines using defective crankshafts, which were machined out of specification and are thus capable of moving around too much inside the block. All 2G model years appear to be affected to some degree. snip It can be difficult to tell if a particular car is experiencing crankwalk. Symptoms are usually indirect and difficult to diagnose until major damage occurs. snip Although 2G DSM owners have been anxiously awaiting a recall or TSB on the crankwalk problem, there is none as yet. According to Paul's second post on the subject, there may never be a TSB, although some members of DSM Canada are pushing for one in this thread on their discussion board. As a result, it is doubly important that affected 2G owners get their bearings (or blocks, if necessary) replaced before their warranty expires. This might be difficult for owners of aftermarket clutches, as dealerships often claim the aftermarket pressure plates are the cause of the problem. ......... end quote ...... -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail Spell checking is left as an excercise for the reader. |
![]() "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote General Motors 150000 Chevrolet, Chevette, PontiacT-1000 Defective crankshaft U.S.A 0/1986 Chevette-nuff said! GM's attempt to get into the economy car market, and to be cheap enough, everything was under-built. Mazda 25400 Familia, Laser Danger of crankshaft fracture and engine damage due to defective bolts WORLD WIDE 7/1990 Goes along with my feelings about Japanese cars. Suzuki Motor Corporation has determined that the Eiger automatic ATVs ATV's? You have to be kidding. Are we going to count Briggs and Stratton, also? My dad had a mid 70's Plymouth that broke 2 cranks in about as many years - last time he ever bought a Chrysler product. Don't know if there was ever a recall, or it was just covered under the warrenty. Plymouth had some major issues, during that time. Feel safe to say that they would not be in the running for aircraft engines, AFAIAC. Was that by chance a K car engine? Fiasco, from the word go. -- Jim in NC |
Back in the days prior to WWII, a student pilot might expect
to have several genuine engine failures before the license was issued. Today the engine is pretty good as long as you put fuel in the tank and oil in the engine [cap secured]. Sometimes you read about a prop strike and they check the run-out to see if the crank is OK. That doesn't mean the crank isn't damaged, just that it wasn't left crooked. It could have been bent 10 thousands left and then back to the right 12 thou, and be within tolerance. It will break some time. But some people won't pull the engine down and MagnuFlux and X-ray the crank and rods because the insurance company won't pay for it unless they find it's broken. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message news:WrqdnUxuq4FjS7TZnZ2dnUVZ_tKdnZ2d@wideopenwest .com... | "Jim Macklin" wrote in message | news:tH4Wf.1271$t22.320@dukeread08... | Unfortunately, people make parts and people are not perfect. | All the companies buy parts from suppliers. Rarely a | suppliers of parts knowingly uses weak materials or skips | some step to manufacture. Some times a part is not designed | properly and sometimes there is a error such as not using | the proper radius on a machine flanged. | Lycoming and Continental build engines and buy parts. | Everything gets inspected, all the paperwork is checked, but | stuff happens. | Any manufacturer who designs and certifies a new engine will | have the same sort of problems, plus the technology will be | new and untried, so there may be problems that are | unexpected. | | | Same problem in the auto industry. The bigges difference is that broken | cranks or cams or... show up in the warrenty data - not in NTSB accident | reports. | | | -- | Geoff | The Sea Hawk at Wow Way d0t Com | remove spaces and make the obvious substitutions to reply by mail | When immigration is illegal, only illegals will immigrate. | | |
I don't know about anyone else, but Lycoming's latest dirty trick with the
crankshafts... What "dirty trick"? Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
![]() "Jose" wrote in message m... I don't know about anyone else, but Lycoming's latest dirty trick with the crankshafts... What "dirty trick"? If a company admits that they have manufactured a faulty part, then they should be replacing it, free of charge, including any labor to replace it. If they do not stand behind their product, and expect the customer to pick up the tab, I call that a dirty trick. What do you call it? -- Jim in NC |
...I call that a dirty trick.
What do you call it? It doesn't matter. I was unaware of the root news item. Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
Aircraft maintenance.... |
Which overhauled Lycoming 0-360 A4M Engine To Fit In My Archer ? | Roy Page | Owning | 7 | February 2nd 06 02:19 AM |
Book Review:Maintenance/overhaul guide to Lycoming aircraft engines, Christy | Paul | Home Built | 11 | December 26th 04 03:24 AM |
Book Review:Maintenance/overhaul guide to Lycoming aircraft engines, Christy | Paul | Owning | 11 | December 26th 04 03:24 AM |
Lycoming 0-360 factory overhaul core charges - Does Air Powertell the truth ? | Mike Spera | Owning | 6 | December 13th 04 01:13 AM |
Lycoming 320 and EAA Light Sport Aircraft ? | Dave Jackson | Home Built | 29 | October 20th 03 01:20 AM |
