Columbia crash...opinions
Old March 30th 06, 04:39 AM posted to rec.aviation.owning,rec.aviation.piloting
Default Columbia crash...opinions
"xyzzy" wrote in message
Kobra wrote:
Check this clip out. What does everyone think happened here?
http://youtube.com/watch?v=ZWC2XJYgcJU
What kind of player does this video use? It doesn't play in my IE and
there is no link on the page to download the player.
You probably have your security set too high, and disallow the necessary
Control.
Old March 30th 06, 05:10 AM posted to rec.aviation.owning,rec.aviation.piloting
("BTIZ" wrote)
Look again, front seat passenger (adult), back seat passenger (adult male)
and I'm guessing that a litter with a medical patient behind the pilot,
look at the oxygen support and other medical supplies.
Is that the same (crash) plane or a second plane?
When I saw the post-crash fire and smoke, and the people on the ground being
treated, I figured the crash plane was toast.
Montblack
Old March 30th 06, 08:35 AM posted to rec.aviation.owning,rec.aviation.piloting
Looks to me like the flap setting may be "a little" more than usually used for
this type of takeoff, but not enough to be causal or contributing.
Hard to say much about speed from this type of video, but he looks slow.
Could be a problem with the C/S prop. The 182, with the prop at fine pitch
usually has abundant excess horsepower on takeoff. If he set the prop wrong, or
if it malfunctioned it could look like this.
Otherwise, as others have stated here, you'd have to know something about the
density altitude at the time, and the loading of the aircraft, as well as
whether the engine itself failed to develmop power.
GF
Old March 30th 06, 10:08 AM posted to rec.aviation.owning,rec.aviation.piloting
On 2006-03-30, Mike Granby wrote:
Someone elsewhere suggested that the gust lock might have been in
place, as you don't see the ailerons moving.
Unlikely. The standard Cessna gust lock locks the elevators in an almost
full nose-down position - it's improbable he'd have been able to raise
the nose at all. It just looks like a classic insufficient
airspeed/mush/stall accident.
Dylan Smith, Port St Mary, Isle of Man
Flying: http://www.dylansmith.net
Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de
Frontier Elite Universe: http://www.alioth.net
Old March 30th 06, 01:17 PM posted to rec.aviation.owning,rec.aviation.piloting
In rec.aviation.owning Greg Farris wrote:
: Looks to me like the flap setting may be "a little" more than usually used for
: this type of takeoff, but not enough to be causal or contributing.
: Hard to say much about speed from this type of video, but he looks slow.
: Could be a problem with the C/S prop. The 182, with the prop at fine pitch
: usually has abundant excess horsepower on takeoff. If he set the prop wrong, or
: if it malfunctioned it could look like this.
: Otherwise, as others have stated here, you'd have to know something about the
: density altitude at the time, and the loading of the aircraft, as well as
: whether the engine itself failed to develmop power.
True. It sure looks like a classic mush/stall though. He got airborne
too early, but with plenty of potential ground-effect acceleration space/time.
Between the partial stall with resulting wing drop, and perhaps seeing the people
ducking for cover, he tried to suck it up and over. Without ground effect to
accelerate, he got irrecoverably behind the power curve.
-Cory
* Cory Papenfuss *
Old March 30th 06, 01:26 PM posted to rec.aviation.owning,rec.aviation.piloting
CG problem..probably aft...which would
make rudder potentially worthless.
Why? An aft CG will reduce the rudder's arm and increase the p-factor,
but it won't render it useless.
Old March 30th 06, 02:08 PM posted to rec.aviation.owning,rec.aviation.piloting
or if it malfunctioned it could look like this.
Don't see how he could have done that. Have you *ever* tried to take off with
the throttle(s) / prop(s) / mixture(s) not pushed full forward? Particularly on
a maximum effort takeoff? (Maybe holding back a little bit on a turbocharged
engine with the throttle as redline dictates).
Mortimer Schnerd, RN
VE
  #29
Old March 30th 06, 06:08 PM posted to rec.aviation.owning,rec.aviation.piloting
Yep, "Behind the power curve".
Al
"Dylan Smith" wrote in message
  #30
Old March 30th 06, 07:34 PM posted to rec.aviation.owning,rec.aviation.piloting
I"m not sure if I think this is really a weight issue. Yes, he may have
been over weight, but a C-182 (with a strong engine) will physically
take off and fly well over gross. Maybe he had too little runway and
tried to pull it into the air too soon? Again, the prop seemed to be
turning slow in the video, but I'm not a video expert and not familiar
with all the effects of the sample rate of the camera.
-Robert, CFI
Columbia crash...opinions Kobra Piloting 35 March 31st 06 02:27 PM
Pilot claims no blame in July crash Mortimer Schnerd, RN Piloting 48 March 15th 06 09:00 PM
Q: How to find info about small plane crash in Columbia (South America)? bud Piloting 5 December 28th 05 04:09 PM
Yet another A36 crash H.P. Piloting 10 April 23rd 05 05:58 PM
