Outer Marker
Old January 22nd 04, 02:29 PM
Barry
Default Outer Marker
When doing an ILS approach, with the glideslope, is it a requirement to be
able to identify the outer marker or a substitute? FAR 91.175(k) lists the
outer marker as one of the "basic ground components" and gives the acceptable
substitutes, but doesn't explicitly say that it's required. The AIM 1-1-9(j)
on "Inoperative Components" mentions the localizer and glideslope, but says
nothing about the outer marker.
If you answer, please give a specific FAA reference that says whether or not
the OM or a substitute is required.
Thanks.
Barry
Old January 22nd 04, 02:31 PM
Paul Tomblin
"or a substitute" is the operative phrase. If the FAF is identified by an
intersection, LOM, or DME, that's an acceptable substitute for a locator
beacon.
"It is a universal truth that the loss of liberty will be charged to
dangers, real or imagined, from abroad." - James Madison
Old January 22nd 04, 06:45 PM
Ron Rosenfeld
On Thu, 22 Jan 2004 14:31:34 +0000 (UTC), (Paul
beacon.
In my experience, it has been most unusual for an OM to be located at the
FAF for an ILS approach. They try to get them close, but they rarely are
(at least here in the NorthEast).
Old January 22nd 04, 08:45 PM
David Brooks
"Ron Rosenfeld" wrote in message
be
an
beacon.
I wondered about that. It *is* at the marker at my home field (PAE), thanks
to a remarkably well-located spit of land north of the bay, and I made the
appropriate mistake on my oral. After a snack break, I looked it up and came
back to the examiner with the right answer (GS intercept).
-- David Brooks
Old January 23rd 04, 07:03 AM
Hilton
Paul Tomblin wrote:
be
beacon.
The FAF on an ILS is glideslope intersect, not the LOM, DME etc which are
not required.
HIlton
Old January 23rd 04, 03:38 PM
Lee Elson
"Hilton" wrote in message thlink.net...
be
beacon.
not required.
HIlton
Ahhh, but suppose your glideslope fails (onboard or on the ground)
after this "not required" intersection (with the "X" on Jepp charts)?
Suddenly you are doing a localizer approach and the FAF identification
becomes much more useful as a place from which you start your timing.
Lee
Old January 24th 04, 09:19 AM
Hilton
Lee Elson wrote:
to
be
lists
by an
locator
beacon.
are
not required.
HIlton
Lee,
I agree with you 100%. I was speaking from a legal view, not a safety view.
A few years ago, an approach's minimum changed if the outer marker was bust.
That is no longer the case.
To be picky, the ILS's FAF is the glideslope intersept, not the 'cross'.
The 'cross' belongs to the non-precision approach that just happens to be
printed on the same piece of paper.
Hilton
Old January 24th 04, 01:24 PM
Barry
I remember there used to be a penalty for a middle marker out of service, but
was the outer marker included on the table, too?
Old January 27th 04, 12:59 AM
Bob Gardner
You tell the controller that you are executing the miss, go around, and get
set up for the LOC-only, if one exists. Changing from an ILS to a LOC in
midstream is not good practice...the assumption is that you briefed the ILS
(even if you are alone), not the LOC.
Bob Gardner
"Lee Elson" wrote in message
om...
thlink.net...
to
be
lists
by an
locator
beacon.
are
not required.
HIlton
Lee
Old March 2nd 04, 03:49 PM
Ray Andraka
THat's how I do it, although I've had instructors doing my IPC ding me for not
starting the timer on an ILS. As politely as I can, I remind them that the
times are for a localizer only approach and that if the glideslope screws the
pooch, I'm going missed.
Bob Gardner--
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
TKM MB75 Marker Beacon Receiver Darrel Toepfer Home Built 0 August 18th 04 10:31 PM
KR-21 marker beacon pinout? JFLEISC Home Built 0 March 17th 04 10:46 PM
Canard planes swept wing outer VG's? Paul Lee Home Built 8 January 4th 04 08:10 PM
Marker Beacon Antenna - Paging Jim Weir. Bart D. Hull Home Built 1 November 27th 03 10:31 PM
marker beacon Gary Gunn Instrument Flight Rules 5 November 3rd 03 05:20 PM
