Can ATC assign an airway if filed direct?
Old February 14th 04, 03:29 PM
Steven P. McNicoll
om...
I've noticed that! A couple times in the last 5 years I've been told
to go direct to an NDB. I don't have anyway to find NDBs (well, ok
GPS, but otherwise... ) Do you think there will be a formal
"forgiving" of the NDB assumption by the FAA or will it just become
another GPS waypoint?
I see no need for any change. GPS is a perfectly acceptable means of
navigating to an NDB. There's no need to advise ATC that you don't have
ADF, simply acknowledge the instruction and proceed direct via GPS. The
only shortcoming is you can't use GPS to fly a straight NDB approach.
Old February 25th 04, 06:49 AM
Scott
If you file to a VOR direct, can ATC clear you along an airway
instead, and expect you to look up the airways? In other words, how
important is to carry an enroute chart if you don't plan on using
airways?
ATC, to the best of my knowledge, can clear you anyway they'd like. I'm
fairly sure you're not all that legal flying IFR without the appropriate
enroute chart. You're surely not safe. How would you know the MEA/MOCA
altitudes?
Surely if you can afford $XX/hour for the plane you can spring for the
chart.
Scott
www.privacytactics.com -- Protect Your Personal Information Assets
Old February 25th 04, 02:02 PM
Newps
airways?
altitudes?
chart.
I have software for my PDA that does all that now.
Old February 28th 04, 07:56 AM
ross watson
What PDA and software are you using and how do you like it?
"Newps" wrote in message
news:7W1%b.121208$uV3.622724@attbi_s51...
airways?
altitudes?
chart.
Old February 28th 04, 03:29 PM
Newps
I use NavGps. You type in your cleared route, using airways if that's
how you were cleared. After hitting enter the software adds in all the
intersections. On the main map page the software gives you total
distance as well as leg distance. It's simple to remove or add fixes as
your flight plan gets ammended along the way. It draws the extended
centerline of any runway. You can select as a destination the approach
end of any runway. It has ground data like roads, rivers, obstacles
etc. I haven't flown behind it much but so far I like it.
airways?
altitudes?
chart.
More KAP 140 questions News Instrument Flight Rules 41 October 26th 03 06:52 AM
"Direct when able" Mitchell Gossman Instrument Flight Rules 18 October 21st 03 01:19 AM
Filing direct John Harper Instrument Flight Rules 10 October 9th 03 10:23 AM
Don Brown and lat-long Bob Gardner Instrument Flight Rules 30 September 29th 03 03:24 AM
Garmin 430/530 Questions Steve Coleman Instrument Flight Rules 16 August 28th 03 09:04 PM
