Sounds like a really cool plane. I've always thought doing something
like this would be neat. What speed will it cruise at? |
I suggest that you contact the FAA before you launch a robot
airplane and kill somebody. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Chris W" wrote in message news:TKB0g.933$9c6.344@dukeread11... | It seems as though those who actually read what I was really asking | didn't think it was important to find or know the answer so let me get a | little more specific. I am going to launch a remote control airplane | that has an autopilot. The autopilot has an altitude hold function that | is based on barometric pressure sensor. I will also have a GPS used for | guidance. The data from that GPS will be transmitted using APRS on | 144.39 mhz to any amateur station listening. Once the autopilot is | turned on it will hold the pressure altitude it is at, so as it flies | along it's route (maybe as many as a few hundred miles) and the | barometric pressure changes the plane will climb and descend to maintain | the same pressure altitude. However the only data I will be getting | back is the GPS altitude. I need a way to do a reality check so if I | see the plane is descending or climbing I will know it is because of | changes in the barometric pressure and not the something that has gone | wrong. The plan is to get the latest METAR data from the closest | observation point to the current position of the plane and then do the | math compared to what it was where and when it launched so I will know | about what the GPS altitude should be reading as that is all I will be | able to see. For those who want to know why I don't just have it | transmit the pressure altitude back, I have four good reasons; cost, | weight, size, complexity. My first flights will be only 20 miles or | so. For safety I will be sure it steers clear of any class B, C, and D | air space. I'm not sure what pressure altitude I will have it fly at | .... probably somewhere between 1500' and 6000' AGL depending on the | distance for it to cover. | | -- | Chris W | KE5GIX | | Gift Giving Made Easy | Get the gifts you want & | give the gifts they want | One stop wish list for any gift, | from anywhere, for any occasion! | http://thewishzone.com |
I do hope this UAV flight has been cleared with the local aviation
authorities, or is contained within a "restricted" airspace to keep other VFR and IFR aircraft safe. BT My first flights will be only 20 miles or so. For safety I will be sure it steers clear of any class B, C, and D air space. I'm not sure what pressure altitude I will have it fly at .... probably somewhere between 1500' and 6000' AGL depending on the distance for it to cover. |
![]() "BTIZ" wrote I do hope this UAV flight has been cleared with the local aviation authorities, or is contained within a "restricted" airspace to keep other VFR and IFR aircraft safe. I've got to agree with this one. To the OP: When an RC airplane leaves your sight line, it is now a UAV, and under another set of rules. This is a rather hot topic, and in the news, as of late. Don't be the one that gets used as an example. It could cost you a bunch of money, jail time, or a lifetime of regret. (over the people that your plane killed) Most likely, nothing bad would happen. Is that something you want to gamble your like on? Is it worth it? -- Jim in NC |
Morgans wrote:
Most likely, nothing bad would happen. Is that something you want to gamble your like on? Is it worth it? I'm guessing that you either live east of the Mississippi or on/near the west coast, and not in Oklahoma. RC airplanes can and have killed people. However, generally this happens from a much larger plane than I plan on using, and the chances of someone getting injured is reduced significantly when the engine isn't running. With this in mind these are the situations I foresee potential for serious injury. The only way I see this coming in contact with someone on the ground is if the engine is not running. Therefore, the biggest danger to someone or something on the ground is gone. So for the plane to impact a person while the engine was running it would have to be an impact with a real plane. If the difference in heading of the real plane and the model were between greater than 0 and less than 90, then the prop wold be history before it penetrated the cabin and would the now dead engine would loose most of it's energy before in impacted someone in the plane, most of the rest of the plane would never enter the cabin. If the difference between the heading of the real plane and the model were between 90 and 180, that's big a problem. I'm not sure how feasible it would be to have some kind of sensor to detect such an impending collision and do something about it. Other than avoiding busy airspace, I'm not sure what to do about it. Keep in mind that the class C around KOKC which is with in 3 miles of my house and I plan on staying away from, really isn't very busy at all. There is still the possibility that something goes wrong with the autopilot and sends the plane down the wrong side of the highway at 3 feet off the ground. To virtually eliminate this type of situation, I plan on having a completely independent system that will kill the engine and put the plane in a slow flight configuration should the altitude drop below a given amount. Granted that could also fail but the chances of both the autopilot and that system failing is very remote, that "fail safe" system would be pretty small and light and could be made redundant and possibly include a the deployment of a parachute. All this said I am open to other ideas to make it safer. -- Chris W KE5GIX Gift Giving Made Easy Get the gifts you want & give the gifts they want One stop wish list for any gift, from anywhere, for any occasion! http://thewishzone.com |
Chris W wrote:
There is still the possibility that something goes wrong with the autopilot and sends the plane down the wrong side of the highway at 3 feet off the ground. To virtually eliminate this type of situation, I plan on having a completely independent system that will kill the engine and put the plane in a slow flight configuration should the altitude drop below a given amount. Granted that could also fail but the chances of both the autopilot and that system failing is very remote, that "fail safe" system would be pretty small and light and could be made redundant and possibly include a the deployment of a parachute. All this said I am open to other ideas to make it safer. What is the purpose of the project? Why couldn't it be done in a way where the model remains within sight at all times - say by flying a pre-established figure-8 course or something similar, and having a manual override capability if it's observed to stray from the planned course? Your current plan certainly appears to violate the model airplane safety guidelines which state that "10. The operator of a radio-controlled model aircraft shall control it during the entire flight, maintaining visual contact without enhancement other than by corrective lenses that are prescribed for the pilot. No model aircraft shall be equipped with devices which allow it to be flown to a selected location which is beyond the visual range of the pilot." http://www.modelaircraft.org/PDF-files/105.PDF |
I lived in Tulsa and OKC and have now been in Kansas over 25
years. Your proposed altitudes are above the MEA on airways. Done properly, with reserved airspace [you can get approval to use the MOAs] what you want to do is safe. But if you just want to launch and depend on luck to avoid killing somebody you're being reckless. A quick Google returned this... Drone aircraft may prowl US skies | CNET News.com Drone aircraft may prowl US skies | Can unmanned aerial vehicles doing ... the FAA says it's created a UAV "program office" to come up with new rules of the ... news.com.com/Drone+aircraft+may+prowl+U. S.+skies/2100-11746_3-6055658.html - 54k - Cached - Similar pages Unmanned Aerial Vehicles (UAVs) and the National Airspace System This process has aided the FAA, other government agencies, and the UAV manufacturers ... except for those flown under the AMA Experimental Aircraft Rules; ... www.house.gov/transportation/ aviation/03-29-06/03-29-06memo.html - 16k - Cached - Similar pages AOPA Online - Regulatory Brief -- Unmanned Aircraft Systems Unmanned aircraft (UA) operate without an on-board pilot or crew. ... The FAA is in the process of drafting rules that establish regulatory guidance for UAS ... www.aopa.org/whatsnew/regulatory/unmanned.html - 29k - Cached - Similar pages Use of Pilotless Planes May Be on the Rise Last year, the FAA allowed two unmanned aircraft to be tested for commercial use. ... The Fine Print: WPNI Rules for Posting Content | Privacy Policy ... www.washingtonpost.com/wp-dyn/ content/article/2006/03/29/AR2006032901814.html - Similar pages Federal Aviation Administration - Unmanned Aerial Vehicles (UAVs) Unmanned Aerial Vehicles (UAVs) – sometimes called “unmanned aircraft systems,” ... The FAA’s main concern about UAV operations in civil airspace is safety. ... www.faa.gov/news/news_story.cfm?type=fact_ sheet&year=2005&date=092005 - 8k - Cached - Similar pages Section 5. Potential Flight Hazards 7-5-1. Accident Cause Factors ... However, some time may pass before the FAA is notified of these outages, ... 7-5-5. Unmanned Aircraft. a. Unmanned aircraft (UA), commonly referred to as ... www.faa.gov/ATpubs/AIM/Chap7/aim0705.html - 57k - Cached - Similar pages [ More results from www.faa.gov ] I see on your website that your name is Woodhouse and you sell wishes. Does your planned UAV that will fly up to 6,000 feet for many miles [you said you early test would be 20 miles] make up a "wish" for a customer? Since you're in OKC, why not visit the Feds and learn what is legal and how to do it safely? -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Chris W" wrote in message news:TpF0g.942$9c6.755@dukeread11... | Morgans wrote: | | Most likely, nothing bad would happen. Is that something you want to | gamble your like on? Is it worth it? | | | I'm guessing that you either live east of the Mississippi or on/near the | west coast, and not in Oklahoma. RC airplanes can and have killed | people. However, generally this happens from a much larger plane than I | plan on using, and the chances of someone getting injured is reduced | significantly when the engine isn't running. With this in mind these | are the situations I foresee potential for serious injury. The only way | I see this coming in contact with someone on the ground is if the engine | is not running. Therefore, the biggest danger to someone or something | on the ground is gone. So for the plane to impact a person while the | engine was running it would have to be an impact with a real plane. If | the difference in heading of the real plane and the model were between | greater than 0 and less than 90, then the prop wold be history before it | penetrated the cabin and would the now dead engine would loose most of | it's energy before in impacted someone in the plane, most of the rest of | the plane would never enter the cabin. If the difference between the | heading of the real plane and the model were between 90 and 180, that's | big a problem. I'm not sure how feasible it would be to have some kind | of sensor to detect such an impending collision and do something about | it. Other than avoiding busy airspace, I'm not sure what to do about | it. Keep in mind that the class C around KOKC which is with in 3 miles | of my house and I plan on staying away from, really isn't very busy at | all. There is still the possibility that something goes wrong with the | autopilot and sends the plane down the wrong side of the highway at 3 | feet off the ground. To virtually eliminate this type of situation, I | plan on having a completely independent system that will kill the engine | and put the plane in a slow flight configuration should the altitude | drop below a given amount. Granted that could also fail but the chances | of both the autopilot and that system failing is very remote, that "fail | safe" system would be pretty small and light and could be made redundant | and possibly include a the deployment of a parachute. All this said I | am open to other ideas to make it safer. | | -- | Chris W | KE5GIX | | Gift Giving Made Easy | Get the gifts you want & | give the gifts they want | One stop wish list for any gift, | from anywhere, for any occasion! | http://thewishzone.com |
On Sun, 16 Apr 2006 19:58:19 -0500, Chris W wrote:
It seems as though those who actually read what I was really asking didn't think it was important to find or know the answer so let me get a little more specific. I am going to launch a remote control airplane that has an autopilot. The autopilot has an altitude hold function that is based on barometric pressure sensor. I will also have a GPS used for guidance. The data from that GPS will be transmitted using APRS on 144.39 mhz to any amateur station listening. Once the autopilot is turned on it will hold the pressure altitude it is at, so as it flies along it's route (maybe as many as a few hundred miles) and the barometric pressure changes the plane will climb and descend to maintain the same pressure altitude. However the only data I will be getting back is the GPS altitude. I need a way to do a reality check so if I see the plane is descending or climbing I will know it is because of changes in the barometric pressure and not the something that has gone wrong. The plan is to get the latest METAR data from the closest observation point to the current position of the plane and then do the math compared to what it was where and when it launched so I will know about what the GPS altitude should be reading as that is all I will be able to see. For those who want to know why I don't just have it transmit the pressure altitude back, I have four good reasons; cost, weight, size, complexity. My first flights will be only 20 miles or so. For safety I will be sure it steers clear of any class B, C, and D air space. I'm not sure what pressure altitude I will have it fly at .... probably somewhere between 1500' and 6000' AGL depending on the distance for it to cover. I do not believe there is any formulaic method to convert from GPS altitude to pressure altitude. GPS altitude may be more akin to true altitude, with variations based on the precise geographic location that could be placed into a table. But if altitude is varying with pressure altitude, bearing in mind that the pressure altitude sensor is also sensitive to temperature, I think you have your work cut out for yourself. Perhaps you could graph the METAR derived data and compare it with the GPS derived altitude, and if the trend (direction of change) is the same, be satisfied that the aircraft is performing as designed. If you had the lookup table to derive geographic position vs GPS altitude error; and also something like a SKEW-T plot to look at temperatures aloft; and also the METAR data, perhaps you could develop something to convert true altitude (from your corrected GPS output) to assumed pressure altitude reading on your altimeter) and draw some conclusions that way. It sounds like an interesting problem. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
On Sun, 16 Apr 2006 14:37:53 -0500, Chris W wrote:
It is my understanding that even if a GPS is reading perfectly and your standard altimeter is reading perfectly even on a standard day that the 2 values will not be the same Mine generally read within 50-100 feet of one another. However, I rarely fly above 3,500 feet. (Altimeter is 60 years old, assuming same age as airplane.) -- all the best, Dan Ford email: usenet AT danford DOT net Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com In Search of Lost Time: www.readingproust.com |
Does your old Cub have a sensitive altimeter or just a
standard? -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Cub Driver" usenet AT danford DOT net wrote in message ... | On Sun, 16 Apr 2006 14:37:53 -0500, Chris W wrote: | | It is my understanding that even if a GPS is reading perfectly and your | standard altimeter is reading perfectly even on a standard day that the | 2 values will not be the same | | Mine generally read within 50-100 feet of one another. However, I | rarely fly above 3,500 feet. (Altimeter is 60 years old, assuming same | age as airplane.) | | | -- all the best, Dan Ford | | email: usenet AT danford DOT net | | Warbird's Forum: www.warbirdforum.com | Piper Cub Forum: www.pipercubforum.com | In Search of Lost Time: www.readingproust.com |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Pressure Altitude and Terminology | Icebound | Piloting | 0 | November 27th 04 09:14 PM |
What's minimum safe O2 level? | PaulH | Piloting | 29 | November 9th 04 07:35 PM |
GPS Altitude with WAAS | Phil Verghese | Instrument Flight Rules | 42 | October 5th 03 12:39 AM |
GPS Altitude with WAAS | Phil Verghese | Piloting | 38 | October 5th 03 12:39 AM |
