Prop pitch cycling?
Old April 25th 06, 03:43 AM posted to rec.aviation.piloting
Default Prop pitch cycling?
Nice link. Good article.
James H. Macklin
ATP,CFI,A&P
"Dudley Henriques" wrote in
message
nk.net...
| Hi Al;
| May I refer you to an article written by John Deakin. John
has written an
| excellent explanation for exactly what you are asking
about here.
| http://www.avweb.com/news/columns/182082-1.html
| All the best,
| Dudley
| "Al" wrote in message
| Jim & Dudley, I've a question I've been meaning to ask.
| "Jim Macklin"
| news:yZS2g.6789$ZW3.6526@dukeread04...
| The prop governor controls within a range and should
hold a
| steady rpm within that range. When the run-up is done
at
| say, 2400 rpm the prop should be cycled to the minimum
rpm
| and allowed to stabilize for a few seconds to check
that the
| governor is working properly. On a multiengine
airplane the
| prop should be reduced to just outside the feather
detent
| and allowed to run for several seconds to be sure that
| prop isn't feathering at the minimum governed speed
[usually
| 2000 rpm on most piston engines].
| What is the minimum governed speed on a constant
speed prop?
| It has been my experience that below 1200-1400 rpm
someplace, a C/s
| prop will no longer cycle. In a glide, the RPM is
generally below that.
| In another thread, some time ago, you(Jim) mentioned
that to get the best
| glide out of a single engine(without the engine), one
should pull the prop
| control out fully. I have tried this in a Mooney 201,
and could not make
| the RPM change a bit, (Power off, best glide).
| Have any of you ever been able in influence a glide
with the prop
| control?
| Al
Old April 25th 06, 03:47 AM posted to rec.aviation.piloting
Deak has a ton of time in big radials and is LOA for several warbirds. His
stuff is off the cuff and straight forward.
I like his style.
Dudley
"Jim Macklin" wrote in message
news:u1g3g.8051$ZW3.6469@dukeread04...
James H. Macklin
ATP,CFI,A&P
message
nk.net...
| Hi Al;
has written an
about here.
| All the best,
| Dudley
| "Jim Macklin"
hold a
at
rpm
that the
airplane the
detent
[usually
speed prop?
someplace, a C/s
and could not make
with the prop
| control?
| Al
Old April 25th 06, 10:57 AM posted to rec.aviation.piloting
And now to sleep, to dream of charter flights in the King
Air or Beechjet, with wake-up calls that are late, blizzards
and floods, cold coffee, taxi strikes, no hotel car, my
clothes lost and I'm flying nude, I'm stuck on the outside
of the airplane, trying to get in the pilot's seat before
the crash as the plane flies between the buildings under the
telephone wires.
Good books are really nice, it even helps when they are easy
to read, unlike a lot of the factory manuals and government
publications.
James H. Macklin
ATP,CFI,A&P
some support
message
nk.net...
| I like his style.
| Dudley
| "Jim Macklin" wrote
in message
| James H. Macklin
| ATP,CFI,A&P
| message
nk.net...
| | Hi Al;
John
| has written an
| about here.
| | All the best,
| | Dudley
ask.
| | "Jim Macklin"
| wrote in message
should
| hold a
done
| at
minimum
| rpm
| that the
| airplane the
| detent
that
| the
| [usually
| speed prop?
rpm
| someplace, a C/s
one
201,
| and could not make
glide
| with the prop
| | control?
| | Al
Old April 26th 06, 09:29 PM posted to rec.aviation.piloting
news:l3d3g.8037$ZW3.808@dukeread04...
But did you notice a change in rate of descent when you
repositioned the prop? The rpm may not change but it should
change the blade angle and thus the drag.
No, I didn't.
If I had gotten the blade angle to change, the rpm would have changed also.
The windmilling prop is producing drag by generating lift which it uses to
turn the engine. It takes a certain amount of energy to turn the engine over
at 800 rpm or so. If, after pulling the prop control, the glide ratio
increases, then the prop is producing less drag, and has less energy with
which to turn the engine. This means the engine must slow down.
My original question was "What is the minimum governed speed on a constant
speed prop?"
I enjoyed the article Dudley pointed to, and the mechanics involved are
clear. But
there is a minimum rpm below which the centrifical weights do not respond,
and the oil is not sent to the prop to alter blade angle. A windmilling
engine at glide is below this rpm.
I believe that pulling the prop control in a glide in almost any of our
single engine aircraft, will have no effect on the glide. Indeed this is
indicated by it's lack of effect on the windmilling rpm.
Al CFIAMI
Old April 26th 06, 10:48 PM posted to rec.aviation.piloting
I have seen a change in Bonanzas and other models, it may be
different airplanes and engine/prop combinations will have
some different results.
| "Jim Macklin" wrote
in message
should
| No, I didn't.
have changed also.
which it uses to
glide ratio
less energy with
down.
speed on a constant
| speed prop?"
involved are
| clear. But
do not respond,
A windmilling
almost any of our
Indeed this is
| Al CFIAMI
Old April 27th 06, 02:35 AM posted to rec.aviation.piloting
There is a big change in glide with respect to RPM. My 185 has a McCauley
"Big Foot" (86" 3 blade STC) prop which maximizes takeoff performance.
During a glide if I reposition the prop to max RPM the airplane will
noticeably decelerate, so much so that Bush pilots use this to their
advantage for steeper approaches.
Alternatively, pulling the prop noticeably extends the glide.
Karl
"Curator" N185KG
No, I didn't.
also.
over at 800 rpm or so. If, after pulling the prop control, the glide ratio
speed prop?"
clear. But
Al CFIAMI
Old April 27th 06, 03:46 AM posted to rec.aviation.piloting
That has been my experience. It may be that a low
compression engine or one with small displacement, or with
the throttle open or closed on a dead engine will make a
difference.
James H. Macklin
ATP,CFI,A&P
some support
"karl gruber" wrote in message
has a McCauley
performance.
airplane will
this to their
glide.
| Karl
| "Curator" N185KG
| "Jim Macklin"
should
| No, I didn't.
have changed
| also.
turn the engine
less energy with
slow down.
speed on a constant
| speed prop?"
| clear. But
almost any of our
| Al CFIAMI
Old April 27th 06, 04:29 AM posted to rec.aviation.piloting
"Ronald Gardner" wrote in message
On the C-182 I have always been told to cycle 3 time just enough for a 200
rpm
drop. This verifies it is working and the oil is flowing.
Ron
Frode Berg wrote:
Hi!
I was told by my mechanic to only pull the prop handle until I could
audibly
hear a slight pitch change to establish that it was working.
However, the aircraft manual says it should be cycled completely, and on
a
cold engine three times to make sure oil is applied to the governor, or
pitch mechanism.
Can someone elaborate on this?
What is recommended?
Frode
What the mechanic is telling you (I think), is to pull the pitch control all
the way out, but just for a moment, long enough for the RPM's to drop a
little. Don't pull it out and leave it.
On the first flight of the day, I always cycle it three times during the
runup. Like the manual says, it shows you that the governor is working and
allows warm oil to flow to it.
  #29
Old April 27th 06, 04:52 PM posted to rec.aviation.piloting
Do you get a change in the windmilling rpm also?
Al
Karl
"Curator" N185KG
No, I didn't.
also.
to turn the engine. It takes a certain amount of energy to turn the
engine over at 800 rpm or so. If, after pulling the prop control, the
glide ratio increases, then the prop is producing less drag, and has less
energy with which to turn the engine. This means the engine must slow
down.
constant speed prop?"
clear. But
respond, and the oil is not sent to the prop to alter blade angle. A
windmilling engine at glide is below this rpm.
Al CFIAMI
  #30
Old April 28th 06, 01:34 PM posted to rec.aviation.piloting
"Michael Ware"
all
Do you mean pull the prop control all the way? Not just far enough to get a
200 rpm drop?
Pulling it all the way seams a bit harsh to me, and this is just what the
mechanic is saying, however, I've heard both....
Frode
PA28: Difference in constant speed prop vs fixed pitch Nathan Young Owning 25 October 10th 04 04:41 AM
Prop Pitch Question Eugene Wendland Home Built 2 April 25th 04 03:22 AM
Pitch and Diameter of 3 blade prop for IO-360 200HP Bart D. Hull Home Built 1 December 11th 03 11:42 PM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
ALTRAK pitch system flight report optics student Home Built 2 September 21st 03 11:49 PM
