Painless Removal of External Male Catheter? (ouch)
Old April 26th 06, 06:28 AM posted to rec.aviation.soaring
Default Painless Removal of External Male Catheter? (ouch)
Aw, just leave it on for the whole contest; what with
the high price of petroleum products these days, etc.
And think of the saving of space in the land fill!
You might also try vice grips; there's a couple of
ways these can be used -- for removal, or instead of.
(OK to dangle a preposition in this thread?)
At 23:00 25 April 2006, Hl Falbaum wrote:
The secret is the same as the secret for removing bandages.
No, not
Acetone--not *there*!
The secret is counter-traction. Gently lift a bit of
catheter from the
skin-(the last bit is not adhesive coated), then pull
the catheter material
gently towards 'off', while gently pulling the skin
towards the body. No
need to pinch it, just a bit of thumb pressure and
pull toward the body.
Stay close to the catheter with the skin thumb, and
as the catheter comes
off, advance the thumb incrementally. A deep breath
helps!
Hope that helps.
Hartley Falbaum
DG800B--'KF'
'ContestID67' wrote in message
roups.com...
Ever since my first contests and XC flights I have
been wearing an
external male catheter. Putting these things on is
easy. Taking them
off is another matter altogether. I know they have
to be sticky or
they might fall off at an inopertune time but jeez-la-wheez
they sure
can stay stuck and are a literal pain to remove.
So what is the secret to pain-free removal of an external
male
catheter? Any other advice on usage is welcome.
- Anonymous
Old April 26th 06, 06:40 AM posted to rec.aviation.soaring
I've tried several brands including some of the Mentors and found most
of the adhesives to be too aggressive. I've ended up using "Mentor
Clear Advantage with Aloe". Look for the "with Aloe", I found these
were sticky enough not to come off or leak yet not too dificult to
remove.
Darryl
6DX
Mark628CA wrote:
Mentor has two different lines. The Standard Care is the one I use. I
was advised that the Active Care line is the one with the more
aggressive adhesive.
The Zee Medical catheters were almost impossible to remove- It took a
long hot shower and substantial swearing. And even then there was
adhesive residue left. Wish I''d known abouut the detachol. I wasn't
going to risk any of the solvents I rely on in fiberglass layups, paint
removal or metal prep. The concept of "You First" is highly developed
in aviation, and I believe in it.
Old April 26th 06, 02:09 PM posted to rec.aviation.soaring
Of course, you could use the non-adhesive catheters (brand name Texas)
that use a foam strip around the outside to seal. I have used for 5
years with no leaks.
Todd Smith
3S
Old April 26th 06, 04:05 PM posted to rec.aviation.soaring
I was reading this thread in befuddlement, until I saw the post
suggesting leaving
the catheter on for an entire multi-day contest.
When I saw that I realized the problem some of you are having, and why
I myself
do not have any trouble just yanking those things off on the occasions
I use them.
The key here is, as usual in aviation-related matters, training.
The adhesive used on catheters is designed to adhere properly to skin
that has been
somewhat toughened and conditioned by regular use. It would seem many
of you are not
being diligent, especially in the off-season, with a vigorous regimen
to maintain fitness
in this particular area.
The fact that someone would consider leaving a catheter on for a whole
contest shows
this in glaring detail. Unthinkable! Currency must be maintained!
We must all be sure that we get our wives and/or girlfriends up to
speed with this as well.
They need to be made to understand the crucial role they play in making
soaring safe and
enjoyable for us, not only by approving expensive purchases of
uncomprehensible "stuff",
but by joining with us to keep us up to the physical challenges of
soaring.
This would seem like a great inclusion to the otherwise excellent "Back
in the Saddle" (BITS) seminar held in region 12 each year...
quietman "ZR"
www.roenation.com
Old April 26th 06, 06:48 PM posted to rec.aviation.soaring
On 25 Apr 2006 22:33:02 -0700, "Mike the Strike"
male
- Anonymous
Tightly pinch the tube downstream of the catheter while peeing. It
will first inflate like a balloon, then detach itself painlessly in a
cockpit shower of yellow rain. Don't ask how I know!
Been there. Done that!
Old April 26th 06, 07:02 PM posted to rec.aviation.soaring
Doug Haluza wrote:
Mark628CA wrote:
Not all catheters are the same.
Yes, I have found that they fall into two categories, the kind that
don't stay on, and the kind that don't come off. After too many bad
experiences with the ones that don't stay on, I've switched the the
ones that don't come off.
So, how many weeks can you leave one on before replacement is required?
www.motorglider.org - Download "A Guide to Self-launching Sailplane
Operation"
Old April 26th 06, 08:35 PM posted to rec.aviation.soaring
Replacement of what?
Ray Warshaw
1LK
Old April 26th 06, 09:12 PM posted to rec.aviation.soaring
This is a very important question and I have been including it on all
Biennial Flight Reviews. The correct answer is of course, "it may remain
in place up to but not including the date of the next BFR or until
circulation ceases, which ever occurs first" [14 CFR 91.1444 (6) (ii)].
I also require all students to demonstrate catheter removal
proficiency during 200 foot simulated rope breaks. I find that this
really keeps 'em on their toes.
Paul
  #29
Old April 27th 06, 02:33 AM posted to rec.aviation.soaring
Cheaper that way. ;-)
Shawn
  #30
Old May 1st 06, 03:27 AM posted to rec.aviation.soaring
I have found that you cannot allow your catheter and willy to get any
direct sunlight. I will bring a small towel with me to lay over my lap
to make sure that there is no direct sunlight. Since I have been doing
this, I have yet to have a painful dismount. Also as the instructions
say....roll it off, dont pull or peal it off. But try and unroll as you
had rolled it on. I know some find this gross, but I prefer the
catheter after the second day of usage. I am unsure how to keep it on
for a whole contest. But then again I am young enough to have other
early morning issues, but if you lay off your viagra prescription for 9
days, you should be okay with leaving it on the whole time.
The catheter company also makes a cleaner for pre instilation (works
well) and a adhesive remover that works wonders (much better than Goo
be Gone). They come in a package the size of a condom and I leave them
in the glider. I found this from a student that uses them everyday.
