bought the plane today
Old April 28th 06, 02:37 PM posted to rec.aviation.owning
Default bought the plane today
Guy Byars wrote:
I try and keep a 50/50 mix of av/auto gas in my Skylane. More avgas in the
winter, more autogas in the summer.
Shouldn't it be the other way around, if you're concerned about vapor
lock?
Autogas in winter makes starting much easier due to its higher vapor
pressure.
Old April 28th 06, 05:54 PM posted to rec.aviation.owning
Congratulations, I think you'll like the plane. I have the F model with
a 180 hp coversion and C/S prop. I do like the extra hp. I am interested
where you live and what you get (amenities) for the $250/month hangar.
Ross
KSWI
houstondan wrote:
my first airplane. cessna 172C.
this group, along with a couple of others, has given me the best
information as i've progressed. by way of payback, i intend to tell
some about the process i went thru for the benefit of others who may be
planning; hoping.
why a 172-c?? well, a couple of reasons. mechanical flaps (you pull a
rod that's laying on the floor) and the 6 cylinder engine which,
although it is 5-15 hp light of later models, is smooth music compared
to the banging of the 4s. any airport in america has mechanics and
parts to fix a 172. it is slow by most standards but i think i see
15/mpg which ain't that bad considering the advantage you get over cars
on "direct route". i'm retired; i've got lots of time.
i paid 34k$ and wells fargo financed me at 7.75 for 15 years. makes it
managable. very friendly people. i like them.
i joined aopa and subscribed to trade-a-plane and g.a. news. haunted
the web for any and all information i could find on airplanes including
the new light sport stuff.
every evening, or something close to that, i would read the adds in
trade a plane and e-bay and whatever i could find untill i had a good
working understanding of the issues around aircraft purchase and
ownership. i have not been flying much lately because i knew i would
need the money to buy - not rent.
when the plane showed-up at my local airport, i expressed interest and
had the owner agree to a full inspection by my mechanic. that uncovered
an exhaust valve problem. he fixed it and we closed today. yipee!! i
now own a plane. had my mechanic not examined the plane then i would be
looking at a grand in engine fix already. now, at least, i've got all 6
doing well north of 70lbs.
i''ll be joining the cessna pilots assn. shortly. thanks y'all who
advised there. hooks airport is renting t-hangers at 250/month and i'll
be getting one tomorrow. i really like having a tin box for my bird.
anyway, that's my experience so for. hope it helps.
i can see that i'm going to be needing a lot of money for gas.
dan
Old April 28th 06, 11:57 PM posted to rec.aviation.owning
Default Vapor lock in a Skylane... not possible!
pressure.
I have heard a lot of arguments about vapor lock, but I do not understand
how vapor lock could ever be a problem in a Cessna 182.
With the high wing configuration, the carberator will always have a positive
fuel pressure due to hydrostaic pressure. How can vapor lock *EVER* happen
in a Skylane? As an engineer, I don't see it happening.
Now, on the other hand, if you have a low wing airplane with a fuel pump,
then vapor lock is a very real problem.
But vapor lock in a high wing carberated engine.... not possible.
Old April 29th 06, 01:28 AM posted to rec.aviation.owning
pressure.
Au contriare, mon ami!
Piper Tripacer running avgas on a hot summer day can vapor lock.
It's all in how and where the plumbing is routed from the wing to the
engine.
Old April 29th 06, 06:10 AM posted to rec.aviation.owning
Congrats! Next thing on your "to do" list:
Go to www.cessna.org and join the Cessna Pilots Association. Lots of good
info on how to maintain it.
Chris
"houstondan" wrote in message
planning; hoping.
dan
Old April 29th 06, 07:59 AM posted to rec.aviation.owning
Of course it's possible. On a hot day if the plane is flown and then
parked on the ramp with the cowling closed, the heat under the cowling
can be so intense that it can potentially vaporize the fuel in the fuel
lines forward of the firewall. If the engine is restarted shortly
afterwards it's possible to experience vapor lock. This problem will
be worse if higher vapor pressure fuel is used (such as winter blend
autogas).
The solution is surprisingly easy. During those short turn-around
always open the cowling immediately after the shutdown. That'll let
the heat escape and avoid the vapor lock.
Old April 29th 06, 08:03 AM posted to rec.aviation.owning
autogas).
Old April 29th 06, 01:41 PM posted to rec.aviation.owning
Vapor lock is a starving of fuel at the carb bowl while a low
pressure-high temperature area in the fuel delivery system delivers
enough vapor that the fuel pump can't get to liquid fuel. You just
don't have that situation in a gravity system.
What you may be considering vapor lock in a gravity system may be fuel
boiling in the carb bowl due to radiated heat from the exhaust system.
This causes the float to sink in the "foam fuel". The bowl then
overfills, and the excess fuel is vented from the bowl into the air
intake, flooding the engine.
The key is that all aircraft carbs vent the bowl to the air intake,
allowing a way to flood the engine. This is not very well publicized.
TriPacers probably flood the second way. Cherokees could go either
way.
Does this jibe with any observations? Comments?
  #29
Old April 29th 06, 02:39 PM posted to rec.aviation.owning
joined c.p.a. but they say they're in the middle of a move this weekend
so it'll be a couple of days before that's complete.
dan
  #30
Old April 29th 06, 03:20 PM posted to rec.aviation.owning
I recall some planes getting ito trouble on autogas when they went too
high in the summer.
pressure.
My first lesson Marco Rispoli Aerobatics 3 May 17th 05 08:23 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 07:27 AM
