#21
("Jose" wrote)
Now if we could only get MontJet Inc. to move a few decimal places too... ![]() Did you see the "new improved" updated numbers - from the MontJet thread? I need to get Williams International to move a few digits ...FJ44 ...FJ33 ....and hopefully, a new FJ22 for the MontJet! MontJet: (415 kts/FL450) (Range: 1,500+ miles) Empty Weight ............600 lbs (x6 = S-33) Fuel (4 hrs)..................600 lbs @ 21.5 gph (7 lbs/gal) Pilot + stuff .................260 lbs MTOW .....................1,460 lbs (x5 = S33) Spectrum 33: (415 kts/FL450) (Range: 2,000 miles) Empty Wt. ...............3,620 lbs MTOW .....................7,300 lbs BTW, I'm using the same engine as the Spectrum 33: Engine ................................290 lbs Williams FJ33-4A [1,568 pound-thrust] Unless a smaller (less fuel burn) FJ22 becomes available! g http://www.williams-int.com/high/pro...FJ33Planes.htm Planes using the FJ33 Engine Team.Mont.Jet. |
Wallace Berry wrote:
For my tastes, most GA aircraft have poor visibility from the cockpit. Small windows, wings blocking the view above or below and to one side or the other in turns serve to block out a lot of the sky. Adding to this I suspect that the relatively high level of noise (engine and radio) and vibration in GA cockpits causes a sort of "sensory overload" that may adversely affect the visual scan. The extent of the effect probably varies quite a lot from person to person, relative levels of distractions in different aircraft, and level of experience. Quieter headsets may improve the situation, but I think the "isolation" of hearing protectors serves as a sort of temporary distraction in it's own right. I can't say I agree, especially about the sensory overload. While my Beech Sundowner (Slowdowner G) dosen't have a bubble canopy, it has excellent visibility everywhere but straight up, far better than any single engine Piper or Cessna I've flown. The wing sits farther back than a PA28, so I have nice visibility to the sides and below. Since straight up and straight back aren't part of the typical scan, I don't think I'd be better off with a bubble. As far as the headset goes, my current ANR set is so comfortable, I can doze off while my co-owner flies! G |
![]() "Montblack" wrote Did you see the "new improved" updated numbers - from the MontJet thread? I need to get Williams International to move a few digits ...FJ44 ...FJ33 ...and hopefully, a new FJ22 for the MontJet! Damn, if they keep going at this rate, pretty soon there will be a FJ00, and it will not burn any fuel at all! g I'll bet you could keep two of those in your pockets! -- Jim in NC |
![]() "FLAV8R" wrote in message ... A few years back, before the New Smyrna Beach Airport (KEVB) had a control tower we made all our call outs on the CTAF and while on short final we noticed something odd. The image before us was hard to make out but as we got closer to the runway we realized that it was a twin on takeoff from runway 20. The problem with that was the fact that we were on the reciprocal end landing on runway 02. The reciprocal end of runway 20 is not runway 02, it's runway 2. |
"Peter R." wrote:
Paul Tomblin wrote: Any suggestions how to reassure her? Upgrade to a mode-S transponder and then display the TIS information on your moving map. The entire NY State Thruway corridor, including your home airport, is covered by the TIS network. That assumes that this system will be around a while. Seems like it or something like it is not long for this world so buying equipment to use it may not be worth it. Ron Lee |
Well, I hope this isn't too far OT, but which of those oft-advertised
portable traffic detectors are good/bad? Any opinions or pilot reports? I'm tempted every time I read one of the ads, but just haven't made the leap...yet. Are they truely of any help? |
Ron Lee wrote:
That assumes that this system will be around a while. Seems like it or something like it is not long for this world so buying equipment to use it may not be worth it. The authors of _Aviation Consumer_ seem to disagree but no matter; I don't really expect Paul to take my suggestion seriously anyway. -- Peter |
In a previous article, "Peter R." said:
Ron Lee wrote: That assumes that this system will be around a while. Seems like it or something like it is not long for this world so buying equipment to use it may not be worth it. The authors of _Aviation Consumer_ seem to disagree but no matter; I don't really expect Paul to take my suggestion seriously anyway. Not in a club plane, anyway. -- Paul Tomblin http://xcski.com/blogs/pt/ "If Bill Gates had a dime for every time a Windows box crashed... ..... Oh, wait a minute, he already does." |
#29
Larry Dighera wrote: On Mon, 01 May 2006 13:09:28 -0500, Wallace Berry wrote in :: I think the "isolation" of hearing protectors serves as a sort of temporary distraction in it's own right. Are you sure you're wearing your headset correctly. The cups are meant to placed over your ears not over your eyes. :-) Dang! So that's the problem! |
#30
On 2006-05-01, Peter Duniho wrote:
"Paul Tomblin" wrote in message ... You non-Unix/non-Mac users don't know what you're missing: You non-Internet users don't know what you're missing: http://www.google.com/search?q=250+k...+per+6+seconds Of course, Google runs Linux :-) -- Yes, the Reply-To email address is valid. Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
