o and io engines
Old May 8th 06, 01:40 PM posted to rec.aviation.owning
Default o and io engines
Robert M. Gary wrote:
For the Lyc 360, the difference is 20 horsepower.
-Robert
But that's not a universal truth. In fact, there are sometimes
different HP ratings for the same major engine major series...
IO-470's for example come in different HP ratings based on the
suffix (an IO-470-C is like 240HP, where an -H gets 260).
Old May 12th 06, 07:23 AM posted to rec.aviation.owning
On 4-May-2006, "Robert M. Gary" wrote:
Ok, I'm still confused. The O-360 engine puts out 180hp on 9gal hr. The
IO-360 puts out 200 hp on 10 gal/hr. The difference between the two is
just that that IO-360 is fuel injected. So how is it that you can say
"And slightly less fuel burn than if it had a carburetor". That
certainly doesn't seem to be the case here.
In my limited experience with an O-360 in an Archer I generally planned on
burning very close to 10 GPH at 75% (of 180 hp), running as lean as possible
for smooth engine operation. In our Arrow with an IO-360, I burn about the
same, or maybe just a tiny bit more, at 75% (of 200 hp). The IO-360 thus
has a lower specific fuel consumption (the per-hour fuel flow required per
hp produced). Reason: I think the main one is that the better fuel
distribution on the FI engine allows operation with a leaner mixture.
-Elliott Drucker
Old May 12th 06, 06:51 PM posted to rec.aviation.owning
wrote)
The IO-360 thus has a lower specific fuel consumption (the per-hour fuel
flow required per hp produced). Reason: I think the main one is that the
better fuel distribution on the FI engine allows operation with a leaner
mixture.
Curious - If approval from the FAA was NOT a factor:
How difficult, practical, expensive, etc, would it be to convert an O to an
IO?
What all would be involved? What would go, what would stay, etc?
Thanks.
Montblack
Old May 12th 06, 10:29 PM posted to rec.aviation.owning
The main reason the IO engine is more efficient is the compression ratio is
higher. The compression ratio is in the numerator of the efficiency formula,
so there is a direct relationship.
Karl
ATP CFI ETC
"Curator" N185KG
"Montblack" wrote in message
wrote)
the better fuel distribution on the FI engine allows operation with a
leaner mixture.
an IO?
Thanks.
Montblack
Home Built Aircraft - Alternative Engines - Geo/Suzuki OtisWinslow Home Built 1 October 12th 05 02:55 PM
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 10:14 PM
P-3C Ditches with Four Engines Out, All Survive! Scet Military Aviation 6 September 27th 04 01:09 AM
Engines and Reliability Dylan Smith Piloting 13 June 30th 04 03:27 PM
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 05:36 PM
