#21
Is there any way to leave the skis in Tahoe? You're certainly not going to
get much use out of them in the Bay Area. That would open you up to many more choices in aircraft. "EridanMan" wrote in message One of the number one uses I want for the aircraft is to be able to make VFR flights up to Tahoe in the winter for ski trips (hopefully regularly, as the weather permits). What singles would you reccommend to be able to carry a load of 2 (or possibly 3, with one being my very petite (105lb) Fiancee) people and a load of baggage and Skis (the big issues imho) from The Bay Area to Tahoe... Anything else I should consider? Thanks. |
I have been following this thread and the best suggestion made so far is for
the pilot to take a serious mountain flying course. Hopefully one that would include 4 place aircraft in the 180-300hp range. Both Truckee and South Lake Tahoe can be pretty unforgiving both in summer and winter (albeit for different reasons). I have experienced -500fpm rate of climb in a C182 with 1/2 fuel and two on board 65Knot IAS in May departing Truckee due to mountain wave activity. From the bay area to Tahoe door to door is about the same amount of time whether you drive or fly. If the roads are closed due to a storm I don't think you want to be in a C172, arrow or Navion above those roads. Howard C182P |
On 2006-05-06, Peter Duniho wrote:
"soxinbox" wrote in message ... I know this used to be critically important, but is this still necessary in today's environment with hand held GPS and cell phones with built in tracking. If I call 911 with exact coordinates, will I really have to wait the night. It depends. Having GPS and a cell phone certainly improves your odds. But... How about a handheld aviation radio? It's likely you are going to be in reasonably frequent line-of-sight from an airliner. -- Yes, the Reply-To email address is valid. Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de |
On 2006-05-08, Howard Nelson wrote:
different reasons). I have experienced -500fpm rate of climb in a C182 with 1/2 fuel and two on board 65Knot IAS in May departing Truckee due to From someone who flies gliders - do NOT fly slowly in sink. It will just prolong the amount of time you spend in the sink (resulting in a greater altitude loss). You will of course have to work out the speed to fly for your particular aircraft -vs- the observed sink rate to determine the best speed to fly. For example, imagine a plane that climbs at 1000 fpm in still air at 60kts, and 700 fpm at 120kts. You're at full power and in sink at 60kts, and you're showing 500fpm down. Imagine the sink lasts for 4 miles. It'll take you 4 minutes (1 mile per minute) to get through, and you will lose 2000 feet. The air is sinking at 1500fpm. If you instead fly this particular plane at 120 knots through the same sink, you'll only spend 2 minutes to get through it, and your rate of descent will be 800 fpm - and you'll come out of the sink having lost 1600 feet (and therefore be 400 feet higher than if you'd flown through the sink slowly). The example here is obviously contrived (for easy calculation) - but you can work out some scenarios based on the performance of your plane to figure out the best speed to fly in sink. -- Yes, the Reply-To email address is valid. Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de |
![]() "Dylan Smith" wrote in message ... On 2006-05-08, Howard Nelson wrote: different reasons). I have experienced -500fpm rate of climb in a C182 with 1/2 fuel and two on board 65Knot IAS in May departing Truckee due to From someone who flies gliders - do NOT fly slowly in sink. It will just prolong the amount of time you spend in the sink (resulting in a greater altitude loss). You will of course have to work out the speed to fly for your particular aircraft -vs- the observed sink rate to determine the best speed to fly. For example, imagine a plane that climbs at 1000 fpm in still air at 60kts, and 700 fpm at 120kts. You're at full power and in sink at 60kts, and you're showing 500fpm down. Imagine the sink lasts for 4 miles. It'll take you 4 minutes (1 mile per minute) to get through, and you will lose 2000 feet. The air is sinking at 1500fpm. If you instead fly this particular plane at 120 knots through the same sink, you'll only spend 2 minutes to get through it, and your rate of descent will be 800 fpm - and you'll come out of the sink having lost 1600 feet (and therefore be 400 feet higher than if you'd flown through the sink slowly). The example here is obviously contrived (for easy calculation) - but you can work out some scenarios based on the performance of your plane to figure out the best speed to fly in sink. Understand what you are saying but this was on departure at about 1000ft AGL. Perhaps something could have been done differently but at the time we were trying to balance rate of climb (which was negative) with stall speed. Luckily (which is not anything to depend on) after about 30-60 secs the -500 fpm turned into +1500fpm. This was not an especially hot day (maybe 60f). The point I was making is that any non turbo single in the Tahoe basin may rapidly reach the limits of it's performance envelope. We were enroute home from Idaho to the bay area and did not follow a mountain flying rule that had been taught to me by my mountain flying instructor. That was "in the summer in the mountains be on the ground between 1000 and 1600hrs". Howard |
I have helped build a Murphy Moose, and you better know what you are
doing. That is no easy chore! Ross KSWI Drew Dalgleish wrote: On 5 May 2006 19:07:01 -0700, "EridanMan" wrote: Hey Guys, I'm in plane-search mode after recently passing my check flight. One of the number one uses I want for the aircraft is to be able to make VFR flights up to Tahoe in the winter for ski trips (hopefully regularly, as the weather permits). Anything else I should consider? Find a storage locker in Tahoe to keep all your ski equipment at for the winter or just carry your boots and rent skis when you get there or build a murphy moose and take all your stuff |
Understand what you are saying but this was on departure at about 1000ft AGL. Perhaps something could have been done differently but at the time we were trying to balance rate of climb (which was negative) with stall speed. Even so (of course this is hindsight - don't take this for being critical, you only know what you know at the time!) under most circumstances [0], speed up in sink. Especailly don't fly on the ragged edge of stall speed - you're not only flying slowly, but slower than best rate of climb speed and the added dangers of stall). As I was saying - the speed to fly will of course depend on the L/D of your particular aircraft. Even when low to the ground (especially when low to the ground) speeding up in sink is important. Even if it only nets you 10 feet - that can be the difference between being in the treetops and merely collecting some foliage in your landing gear. Had I not sped up in sink in my glider this weekend when I was at around 1000' AGL, I'd have been landing in a field not at the airport! [0] Obstructions may be a circumstance where you would NOT want to speed up! had been taught to me by my mountain flying instructor. That was "in the summer in the mountains be on the ground between 1000 and 1600hrs". Having flown in the mountains in the summer in an underpowered aircraft, I can entirely agree. Doubly so if it's windy. -- Yes, the Reply-To email address is valid. Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de |
![]() "Dylan Smith" wrote in message ... On 2006-05-08, Howard Nelson wrote: Understand what you are saying but this was on departure at about 1000ft AGL. Perhaps something could have been done differently but at the time we were trying to balance rate of climb (which was negative) with stall speed. Even so (of course this is hindsight - don't take this for being critical, you only know what you know at the time!) under most circumstances [0], speed up in sink. Especailly don't fly on the ragged edge of stall speed - you're not only flying slowly, but slower than best rate of climb speed and the added dangers of stall). As I was saying - the speed to fly will of course depend on the L/D of your particular aircraft. Even when low to the ground (especially when low to the ground) speeding up in sink is important. Even if it only nets you 10 feet - that can be the difference between being in the treetops and merely collecting some foliage in your landing gear. Had I not sped up in sink in my glider this weekend when I was at around 1000' AGL, I'd have been landing in a field not at the airport! [0] Obstructions may be a circumstance where you would NOT want to speed up! Excellent advice. Everything you say makes perfect sense. I will try to heed it if I find myself in a similar situation again. Thanks Howard |
#29
... How about a handheld aviation radio? It's likely you are going to be in reasonably frequent line-of-sight from an airliner. As a substitute for carrying survival gear? I don't think that's a reasonable exchange. First, you'll have to define "likely". A friend of mine was rescued via helicopter when he landed in a remote lake with his seaplane, but couldn't get it started again later (starter had failed). Using the airplane's radio, he was eventually able to reach an airplane passing overhead (I don't recall if it was an airliner or not). But it took awhile, and in the end it was a bit of luck involved. The lake where he landed is a small mountain lake, with steep slopes all around. Line-of-sight is only about a 60-80 degree cone straight up. The lake is not far laterally from one of the airways leading to Sea-Tac airport (the nearest commercial airport), and even then it took awhile before an airplane came close enough to being overhead to be contacted by radio. Even once the airplane overhead was contacted, getting an accurate message relayed to someone who could come pick them up was non-trivial. He probably also benefited from the additional power of the airplane's radio. A handheld would probably have reduced the volume of airspace in which a potential contact could be found. Had he been in a more remote location, there may not have been any airline traffic going overhead, ever. So...could you take advantage of a handheld aviation radio? Perhaps. But I'd say it's more akin to being stranded on a deserted island and relying on a bonfire to alert a passing ship. IMHO, one of the best things a person can do, beyond having a good, reliable ELT with them is to have filed an accurate flight plan with someone who will come looking for you if you don't arrive on time. There are few forms of communications that are highly reliable when you're in a remote location. Expecting to be able to contact someone after the crash seems optimistic to me. And of course, while you're waiting for the person who knows you've crashed to actually find and rescue you, you'll probably want the appropriate survival gear to keep yourself alive until you're rescued. Pete |
#30
"Jim Logajan" wrote in message
.. . Any advantage to having a satellite phone and a handheld GPS versus a 406 MHz ELT (the ones capable of being detected by satellites)? Any advantage? Sure...the 406 Mhz ELTs don't let you speak to anyone. That's an advantage. ![]() That said, I'd agree that having a 406 Mhz ELT is a pretty good solution, at least with respect to being found. As you note, it's probably built sturdier than a phone and/or handheld GPS would be. Even if the ELT doesn't have GPS input, triangulating a 406 Mhz ELT is supposed to be relatively rapid. Even so, I don't see a 406 Mhz ELT as being a substitute for survival gear. As already noted, even if someone knows exactly where you are, they may not be able to get to you right away. And survival gear would include first-aid equipment, which would be important whether or not you need to stay the night. Pete |
Cessna's next piston single | [email protected] | Owning | 0 | February 11th 06 07:14 PM |
Mazda single rotor weight? | [email protected] | Home Built | 6 | January 10th 06 06:44 PM |
O2 single pilot and VLJ | [email protected] | Piloting | 5 | August 18th 05 09:15 AM |
Is taking off on single mag bad for engine | flyer | Home Built | 10 | September 21st 03 09:43 PM |
WANTED: partnership, rental or club with fast single or light twin in San Diego | Jim McGarvie | Aviation Marketplace | 0 | September 13th 03 03:55 PM |
