Nothing good about Ethanol
Old June 1st 06, 03:57 PM posted to rec.aviation.owning
Default Nothing good about Ethanol
Dan Luke wrote:
What experts? Employed by whom? What are their qualifications? What
peer-reviewed studies did they publish?
Think about it logically. Besides, in order to be "energy independent"
with Ethanol alone, we would haqve to plant corn on every arcre of
farmland in this country.... forget growing any actual food.
Ethanol is a pipe dream, and except as an additive to boost octane
it is not cost efective.
Old June 1st 06, 07:38 PM posted to rec.aviation.owning
Bah, we've got millions of acres here in Montana, any wheat producing
state will, that are not farmed right now because it won't support sweet
corn. But it will grow the field corn that you use to produce ethanol
quite nicely.
Old June 1st 06, 10:01 PM posted to rec.aviation.owning
Bah, we've got millions of acres here in Montana, any wheat producing state
will, that are not farmed right now because it won't support sweet corn.
But it will grow the field corn that you use to produce ethanol quite
nicely.
And the only reason we're talking about ethanol from corn is the mighty U. S.
corn lobby. Other crops--sugar beets up North, sugar cane down South--can
give much higher ethanol yields/acre.
Dan
"Gut feeling"
Intestinologists concur that the human gut does not contain
any rational thoughts.
What the human gut *is* full of is moderately well known.
Old June 3rd 06, 05:46 AM posted to rec.aviation.owning
On Thu, 1 Jun 2006 16:01:37 -0500, "Dan Luke"
There is a *lot* of field corn grown in Michigan and the Mid West. In
both Michigan and Wisconsin a lot of that is used to feed dairy
cattle. We also have large farms producing cattle for beef.
nicely.
Well, we are limited to how many acres of sugar beets we can grow and
they bring a premium price compared to corn. As a SWAG I say we
might be able to come up with another 15% in acreage planted to beets
up here in the frozen north. We might get more alcohol and we might
not. I don't know what the net energy yield would be, but it most
likely would be more expensive than corn alcohol.
I don't know what the yield would be from Sorghum. Too bad, we as a
country, have such a fixation against growing commercial hemp. (not
the recreational kind)
www.rogerhalstead.com
Old June 1st 06, 02:11 AM posted to rec.aviation.owning
The ethanol is blended with the gasoline right at the tanker truck.
Shake'n'bake with the tanker truck on the road does further mixing, so the
gasoline "stocks" are devoid of ethanol contamination right now. THe
problem is to get suppliers back to giving us straight gasoline.
The EPA has
ruled California no longer has to use it. But will be some time
before stocks no longer contain it. That's what I read anyway.
Old June 1st 06, 12:26 PM posted to rec.aviation.owning
I heard an interview on a financial show a few weeks back that had an
oil company executive telling a completely different story. He
explained that plants and storage facilities needed certain parts and
seals changed to switch from MTBE laced gas to a gas / alcohol blend.
Could this be a regional thing?
Old June 1st 06, 12:45 PM posted to rec.aviation.owning
I know of no Homo sapiens trying to conserve himself into prosperity.
The yankee dollar reigns supreme. You pilots putting auto gas in your
planes need to think again, carefully.
Old June 1st 06, 01:05 PM posted to rec.aviation.owning
You pilots putting auto gas in your planes need to think again, carefully.
Not much thinking required, you *MUST* now test each and every load of fuel
for the presence of ethanol before you put it in your plane. Ethanol free
autogas is geting much harder to find. And it is certainly not labeled at
the pump anymore like it used to be.
Old June 2nd 06, 02:09 PM posted to rec.aviation.owning
fuel
It is here in Iowa -- by law.
Ironic, no?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old June 1st 06, 03:45 PM posted to rec.aviation.owning
Which explains why the blending is done at the truck instead of the
plant.
You think it could take a while to shut down a plant and do the
conversions required?
Jim Pennino
Remove .spam.sux to reply.
Any good aviation clip-art? zingzang Piloting 2 August 11th 05 01:32 AM
We lost a good one.... [email protected] Piloting 10 May 28th 05 05:21 AM
HAVE YOU HEARD THE GOOD NEWS! [email protected] Soaring 0 January 26th 05 07:08 PM
Commander gives Navy airframe plan good review Otis Willie Military Aviation 0 July 8th 03 09:10 PM
