Busted IFR Checkride
Old April 23rd 04, 09:01 PM
Martin Kosina
First the operational reason - holds are sometimes used for course
reversal on approaches in lieu of procedure turns. In such a case,
you are expected to do only the hold entry. Further, for your own
good you need to be well established on the inbound course before
crossing the fix. Finally, when this is done, the reason the hold was
chosen over the PT was to keep you out of airspace or obstructions.
So the bottom line is holding is not important until it it. Still,
there are other items that fall into that category (for example IFR
departures from VFR fields) that are not covered at all.
Good point, screwing up an enroute hold is rarely a big deal, but IFR
departure procedures often prescribe identical orbiting procedures
(even if they are not called "holds") that really do keep you out of
the weeds, sometimes with not very big margins. If you get messed up
there, I'd say head straight back to the navaid while climbing and try
to sort it out.
I only became really aware of published IDP's and the various TERPS
issues after reading Wally Robert's site, my own instrument training
did not emphasise this too much, which is a bit scary in retrospect...
Old April 24th 04, 01:31 AM
Ron Rosenfeld
On 22 Apr 2004 23:59:48 GMT, Andrew Sarangan wrote:
I never understood why holding patterns are so damn important. I have
received a holding clearance only once in my life. Why are they required
for the recency experience and the checkride? Also, why are the entry
procedures so important? Is there any example where an incorrect entry
procedure would have caused an accident?
The only requirement for a holding pattern is to stay within the protected
area. Getting to the holding fix and turning the shortest way to remain
within the protected area can be a simpler (and acceptable) method of
getting into the hold than the "recommended" procedures.
From the IR PTS holding procedures: "Explains and uses an entry
procedure that ensures the aircraft remains within the holding pattern
airspace for a standard, nonstandard, published, or nonpublished holding
pattern."
So far as it's usefulness, just a few days ago I missed an approach into my
home base because the ceiling was below minimums. The missed approach
procedure included a holding pattern. My plan was to hold for a 1/2 hour
and then try the approach again. If that didn't work, I would be off to my
alternate. Of course, my fairly new CNX80 made holding pretty simple. The
box even adjusted the holding pattern size (and shape) to account for the
winds!
Old April 24th 04, 01:54 AM
Roy Smith
winds!
How does it know what the wind is?
My club has the CNX-80 in four of our planes now. It's a cool radio,
but there is certainly a learning curve. I've got about 25 hours behind
box now, and havn't learned everything there is to know about it yet.
Old April 24th 04, 03:55 AM
Matt Whiting
winds!
Seems like it would have to have an internal compass or some other
source of heading information to do this trick.
Matt
Old April 24th 04, 07:06 PM
Ron Rosenfeld
I don't know that it knows the winds. But it knows the ground track and
ground speed. It probably assumes a constant airspeed and makes
computations that way. It was interesting seeing the *shape* of the
holding pattern (as drawn on the screen) change.
Old April 24th 04, 11:34 PM
Andrew Gideon
Nice club. Where's this, again?
- Andrew
Old April 24th 04, 03:54 AM
Matt Whiting
pattern."
winds!
That is definitely cheating! :-)
Matt
Old April 24th 04, 07:11 PM
Ron Rosenfeld
On Fri, 23 Apr 2004 22:54:16 -0400, Matt Whiting
And no apologies!!
Old April 23rd 04, 02:26 AM
A Lieberman
Jon Kraus wrote:
Took my IFR checkride today and busted... I screwed up the holding
pattern big time and that was that...
Hey Jon,
Appreciate your post. I am getting closer to that time.... What part
of holding did you bust, timing? Entry? Suggestions for my check ride
to come down the road???
Allen
IFR Checkride Checklist BTIZ Instrument Flight Rules 0 April 18th 04 12:06 AM
IFR Checkride Scheduled Jon Kraus Instrument Flight Rules 15 April 6th 04 05:30 AM
Passed my IFR checkride today. [email protected] Instrument Flight Rules 5 February 8th 04 07:04 AM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 09:03 PM
CFI-I Checkride stories? Jim Instrument Flight Rules 11 July 18th 03 01:04 AM
