ATC says wrong position
Old April 28th 04, 04:06 PM
Greg Esres
Default ATC says wrong position
When being vectored, and ATC says your 4 miles from X, I noticed
occasionally that they state the wrong X. They confuse the FAF with
the IF. For this reason, I tell students to never rely on ATC's
distance statements to make a descent.
How often do others see this?
Old April 28th 04, 04:42 PM
Ron Rosenfeld
I guess I'm not understanding the circumstance clearly, that might lead
someone to use that kind of information as an "OK to descend" point.
If ATC is giving an approach clearance, and you are being radar vectored or
on a random route, you should have received an "altitude to maintain until
If you are approaching an IAF that has a procedure turn, and you are NOT
receiving radar vectors to final, I was taught that being on a published
portion of the approach meant that I had to cross the IAF first.
Old April 28th 04, 05:28 PM
Greg Esres
lead someone to use that kind of information as an "OK to descend"
point.
When being vectored outside the FAF, ATC will say, "You're 4 miles
from x, turn left heading 210, maintain 2,500 until established,
cleared for the approach".
If you are between the IF and the FAF (as they said you were), then
the published altitude is 2,000. If you are outside the IF, the
published altitude remains 2,500.
If ATC says you're 4 miles outside the FAF, but you're really 4 miles
outside the IF, then if you descend based on that info, you've screwed
up.
Old April 28th 04, 08:26 PM
Ron Rosenfeld
point.
up.
OK, I understand now. I'm not an instructor, so I can only repeat back
what I learned years ago. I think my approach would be to emphasize to the
student the importance of situational awareness in all instances, and the
attitude that he is the one flying and responsible.
An intermediate segment is usually at least five miles long. So if all of
a sudden ATC places the pilot 5+ miles from where the pilot thinks he is,
that should trigger an immediate reaction to verify position.
I think students (and advanced pilots) sometimes fall into the trap of
allowing/expecting too much hand-holding from ATC. That may be more true
in certain areas of the country than others. So I think it's extremely
important to emphasize SA, responsibility, and the importance of being on a
published segment of the approach (and knowing exactly where you are)
before beginning a descent.
Old April 28th 04, 08:49 PM
Greg Esres
I think my approach would be to emphasize to the student the
attitude that he is the one flying and responsible...I think students
I agree with all you said.
I've been aware of this problem with ATC for a while and use it to
illustrate to students how important it is for THEM to be in charge.
I was just curious as to 1) how often others had noticed this, and 2)
who was using this information in order to descend to intermediate
altitudes.
Old April 29th 04, 02:22 AM
Ron Rosenfeld
altitudes.
I cannot recall ever hearing ATC give me a "distance from" an incorrect fix
during an approach clearance. 90% of my flying is in the NE receiving
radar services.
Also, my recollection (and I could be wrong here), is that during the times
I get a "maintain ....ft until established" clearance, it's for a precision
approach. For non-precision approaches, I've received a "maintain ...ft
until crossing xyz"
Old April 28th 04, 05:02 PM
That's one of the many valuable purposes that a moving map of the MVA
chart would serve. Of course, with GPS, the pilot can, and should be,
the final authority on the distance to the final approach fix or point.
Old April 28th 04, 05:31 PM
Greg Esres
Of course, with GPS, the pilot can, and should be, the final
Agreed.
However, this "service" provided by ATC occured (I suppose) long
before we had means to always verify the information. Seems a bit
unsafe.
Old April 28th 04, 07:42 PM
Agreed.
unsafe.
Go back to TWA 514 in 1974 and they didn't provide much information at
all with vectors to approach courses.
There have been more unsafe situations resulting from vectors over the
years than anyone really knows. The NASA database is full of them, but
the FAA ignores the issue. Some are controller errors, some are pilot
errors, and some are a combination of the two.
Old April 28th 04, 07:47 PM
Tarver Engineering
wrote in message ...
Agreed.
unsafe.
That is because FAA is afraid of opening ATC controllers up to civil
liability. What FAA fails to comprehend is that "gross negligence", or
"restraint of trade", is required to win a lawsuit in such a situation.
Human error is not gross negligence and the issue could be safely addressed.
Cessna 206 Pilot position....... [email protected] Home Built 0 January 28th 05 08:27 PM
Glad to hear the initial reports were wrong about accidents, as they usually are. Tedstriker Home Built 0 April 19th 04 02:52 AM
3 blade prop position on 6cyl engine. Paul Lee Home Built 3 February 26th 04 12:47 AM
LED for position lights Jerry Springer Home Built 2 August 19th 03 01:43 AM
Wrong Brothers Air Force Party Invite Jay Honeck Home Built 1 July 20th 03 10:55 PM
