Gear up landings can happen to ANYONE...
Old June 8th 06, 01:28 AM posted to rec.aviation.piloting
Default Gear up landings can happen to ANYONE...
http://www.sftt.us/cgi-bin/csNews/cs...iewone&id =41
http://www.freerepublic.com/focus/f-news/1629804/posts
Old June 8th 06, 02:02 AM posted to rec.aviation.piloting
Yes, I've been flying a retractable for only two years now and am
paranoid about making a gear-up landing. It can obviously happen to anyone.
Matt
Old June 8th 06, 05:36 AM posted to rec.aviation.piloting
"Matt Whiting" wrote in message
Yes, I've been flying a retractable for only two years now and am paranoid
Matt
You're right, and the way to approach this issue is by realizing exactly
this, then setting up a personal regimen for a pre-landing cross-check that
is deliberately formated to be an exact final cross check procedure executed
the same way as a habit pattern every time you fly.
There are many of these axioms in use, and every pilot has his/her own
favorite. It doesn't matter which one is used, as long as it's used exactly
the same way every time you fly and at the same place in the approach every
time. This has to become an ingrained habit pattern.
My own personal cross check in ADDITION to the required regular pre-landing
checklists, and the one I taught for years to every pilot I trained was the
following; done on final.
This cross check was always said aloud and each item had to be touched and
verified as it was spoken.
"All good pilots must land fine check"
Each word was spoken individually as it was checked
All: Altimeter
Good; Gas
Pilots; Prop
Must; Mixture
Land; Landing Gear
Fine; Flaps
Check; Carb Heat (if applicable)
50 years in retracts. No wheels up landings :-)))
Dudley Henriques
Old June 8th 06, 11:27 AM posted to rec.aviation.piloting
Matt
All: Altimeter
Good; Gas
Pilots; Prop
Must; Mixture
Land; Landing Gear
Fine; Flaps
I use the GUMPS check, but as you say, the important thing is to do the
same thing every time, no matter what the circumstances. This is
obviously easy to say, and easy to do assuming no distractions of any
substance. My concern is distractions.
I run the GUMPS check on downwind, after completing the turn to base and
after completing the turn to final. I then do one more check right
before crossing the runway threshold: I look at the runway lights and
say "lights, lights." Which is when I see the runway lights I double
check the gear lights. Takes just a second and it is one last reminder
to check.
I hope my two years becomes your 50 years! Although, I likely won't
hold a medical long enough for that to happen as I was mid-40s when I
first flew a retractable.
Matt
Old June 8th 06, 03:15 PM posted to rec.aviation.piloting
About distraction and the cross check;
It's for this exact reason we do the cross check.
Distraction is something that every instructor working in the complex
environment should be dealing with from the first hour of dual with a pilot
moving up into complex aircraft. In fact, it's SO important, it should be
treated as a formal step into the complex checkout scenario.
The way the instructor handles this single issue will either produce a pilot
who has a habit pattern that will stay with him/her the rest of their flying
days, or simply one more pilot pushed through the complex checkout stage who
is a gear up landing waiting to happen. The role of the complex check pilot
is CRITICAL in creating this habit pattern in the pilot being trained.
The way it's handled will of course vary from instructor to instructor.
I suggest introducing the issue of distraction during the FIRST dual session
with a complex transition pilot; first stressing it's existence and dangers
in the retract gear environment in the multi-task scenario, then stressing
the need for the gear cross check on final.
Now this seems normal enough at first glance, and naturally every instructor
will do this.
But wait........there's more to creating a habit pattern in a pilot then the
first step!!!!!!!
Usually at this point, this information is simply digested by the trainee as
one more thing to remember, but the seed is planted. The next stage is
critical. Just planting the seed for a needed habit pattern is not nearly
enough, and this unfortunately is where many complex instructors fumble the
ball.
On EVERY FLIGHT with a complex trainee, before the flight, during the
flight, and after the flight, the need for the cross check on final should
be RE-INTRODUCED by the instructor. In other words, this single facet of a
complex checkout should be repeated on each flight several times. By doing
this, the CONSTANT REPETITION of a single item becomes ingrained as a
conditioned mental reflex that will function in a distraction environment.
Also, one more thing on distraction;
The cross check is SO important, and SO critical, that the way it should be
taught is that ANYTHING causing a break in the cross check requires a
RECHECK of the cross check itself!!.
The end result of all this is hopefully a pilot with a highly trained mental
trigger concerning his/her final cross check who will be on final and half
way through the final pre landing cross check as a distraction occurs. The
pilot will AUTOMATICALLY handle the distraction, then REDO the final cross
check.
If you train yourself to this level of awareness about your final cross
check, you should be just fine in the complex environment.
One additional thing; your "concern" about making a gear up landing is
actually a desired result of proper training for a complex pilot. It's this
"concern" that defines the edge that triggers the cross check.
So relax......you're perfectly normal!! :-)))))))
Dudley Henriques
Dudley Henriques
anyone.
Matt
that is deliberately formated to be an exact final cross check procedure
executed the same way as a habit pattern every time you fly.
exactly the same way every time you fly and at the same place in the
approach every time. This has to become an ingrained habit pattern.
pre-landing checklists, and the one I taught for years to every pilot I
trained was the following; done on final.
and verified as it was spoken.
All: Altimeter
Good; Gas
Pilots; Prop
Must; Mixture
Land; Landing Gear
Fine; Flaps
after completing the turn to final. I then do one more check right before
crossing the runway threshold: I look at the runway lights and say
"lights, lights." Which is when I see the runway lights I double check
the gear lights. Takes just a second and it is one last reminder to
check.
I hope my two years becomes your 50 years! Although, I likely won't hold
a medical long enough for that to happen as I was mid-40s when I first
flew a retractable.
Matt
Old June 8th 06, 07:00 PM posted to rec.aviation.piloting
[wonderful response to gear up comments snipped]
Dudley,
This kind of gem is why I wish you were still instructing (in my neck
of the woods). Of course, you are still instructing on usenet, I just
learned something.
John Stevens
PP-ASEL
Old June 8th 06, 10:33 PM posted to rec.aviation.piloting
Is anyone aware of any techniques for stopping the gear cross check after
the plane is put away in the hangar and you're driving home? I still find
myself thinking, "Oh my god, did I put the gear down for that landing?"
when I'm a few miles away from the airport in my car...
Ben Jackson
http://www.ben.com/
Old June 8th 06, 11:04 PM posted to rec.aviation.piloting
will do this.
first step!!!!!!!
ball.
check.
Dudley Henriques
I've been fortunate to have had three instructors (primary, instrument
and retractable check-out) who not only taught the above, they gave lots
of practice by causing distractions almost all of the time. My
instrument instructor was so bad that I flew virtually all training
flights with something "not working." The only flight that didn't have
a failed instrument was the final prep flight for the check ride. I
then began to get distracted wondering why he wasn't introducing any
distractions. It was eerie.
Matt
Old June 8th 06, 10:29 PM posted to rec.aviation.piloting
Yea, talk about distractions, there was a Learjet gear up recently at
Sacramento Executive. The pilot said he got distracted looking for a
helicopter.
-Robert
Matt
All: Altimeter
Good; Gas
Pilots; Prop
Must; Mixture
Land; Landing Gear
Fine; Flaps
to check.
Matt
Old June 9th 06, 02:44 PM posted to rec.aviation.piloting
Good stuff as always Dudley.
I invented my own 'cross check' in perhaps the lowest tech retract -
sailplanes. All the retract sailplanes I flew had a 2 part vent window.
I never used the sliding window in flight but used it to cross check
gear operation. The key was the 'roar' that the open window caused.
Rule was "drop & lock gear, listen for gear wind noise, open window to
drown out the noise"
Doing off field 'emergency' landings in gliders is the definition of
distracting. People, cows, geese, power lines, barb wire, ditches,
jumpers, and other sailplanes were all encountered, but the worse was
the promise of continued flight from a low altitude thermal. A 'save'
called for gear up and window closed so I can hear the audio variometer.
Losing the thermal at 500' means gear down, window open. I've been
'distracted' multiple times at 500' and performed that cross check
multiple times before saving or landing.
Then there are tow rope breaks and 'showing off' with worm burner
finishes or even touch and go's - all distractions from routine. My
rule was - can't land without window open, can't open window unless gear
down and heard. 48 off-field glider landings and various idiot
manuevers, no gear ups.
It's not whether you will be distracted, it's what you do when you are
distracted. A cross check needs to be drilled deep in your flying soul.
....But I was never meaningfully drilled on the use of a cross check
during my very limited complex experience. My instructors didn't do
what Dudley outlined and I know I'm "one of those that will" until I
drill that hole. If you don't get what Dudley is saying, you may want
to read it again. Good stuff.
All: Altimeter
Good; Gas
Pilots; Prop
Must; Mixture
Land; Landing Gear
Fine; Flaps
Dudley Henriques
Saratoga Gear Retract Problem Yahoo! News Owning 16 November 29th 05 11:17 PM
Would you cycle the gear? Roy Smith General Aviation 41 April 23rd 04 10:41 PM
Tailwheel endorsement John Harper Piloting 58 December 12th 03 01:48 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Landing gear door operation Elliot Wilen Naval Aviation 11 July 7th 03 03:47 PM
