CFII oral exam guide questions?
Old June 14th 06, 02:23 AM posted to rec.aviation.ifr,rec.aviation.student
Default CFII oral exam guide questions?
too difficult to comprehend for the beginning student who is not an
electronics major
BT
"John R. Copeland" wrote in message
"Jose" wrote in message
. com...
Well, Jim, it almost COULD work that way, but it doesn't. :-[
VOR azimuth angle is measured by a phase comparison
between two sinusoidal signals, not a time-delay measurement.
The VOR reference signal is frequency modulated on a subcarrier,
while the azimuth signal is from amplitude modulation on the
radio-frequency carrier, caused by the VOR's rotating cardioid beam.
It's indirect, but isn't a measurement of phase difference of two
different waves the same as the measurement of the time difference
between crests (once you take into account the frequency and the speed
of light)? It's like saying the alimiter measures altitude. It's not
technically correct (and yes, the difference is meaningful under some
circumstances) but gets the job done.
Jose
The time domain and the frequency domain are related conventionally
through a mathematical manipulation called the Fourier Transform.
However, the measurement methods used in the two domains
are considerably different.
The VOR system was designed for measurements in phase space.
DME, of course, was designed for the time domain.
Old June 14th 06, 04:27 AM posted to rec.aviation.ifr,rec.aviation.student
Capt. Mike wrote:
Who cares how it works ?
R u going to build one or fix one ?
Know how to operate the equipment and not how the equipment operater -
I'm not sure if I'm spending hours with my instructor learning trivia
or useful stuff. However, this is a CFII and not an IR checkride so the
standard for understanding and being able to explain is different.
-Robert
Old June 14th 06, 05:09 AM posted to rec.aviation.ifr,rec.aviation.student
That may be true, but is also a ten dollar irrelevancy. The phase
difference directly relates to the time difference. Operationally, the
circiuitry employs phase relationships rather than a little man with a
fast stopwatch, but new pilots attempting to understand the concept of
VOR navigation don't need to understand RF electronics to "get" the idea
behind the VOR, especially in contrast to the ADF or DME. I find the
analogy completely apt.
This is a useful distinction for ciruit designers, but not for new pilots.
Jose
The price of freedom is... well... freedom.
Old June 14th 06, 06:04 AM posted to rec.aviation.ifr,rec.aviation.student
On 13 Jun 2006 08:23:09 -0700, "Robert M. Gary"
Mitty wrote:
You might look at:
http://www.dauntless-soft.com/PRODUC...?DMODE=FAATEST
I have used their software for written tests and found it to be very
good. I tried the "RideReady" Commercial oral package when it was
very new, a couple of years ago and at that time I thought it was kind
of weak.
They don't appear to have anything for the CFII .
Ahh...yes they do...it's part of the instrument rating s/w, not the
CFI/FOI package. I've used several of their test and oral prep
packages and found them to be extremely good value for the $$...
The oral exam (Ride Ready) preps still worth the $$, not quite as good
as the test preps.
--Don
Don Byrer
Radar Tech & Smilin' Commercial Pilot Guy
Amateur Radio KJ5KB
kj5kb-at-hotmail.com
"I have slipped the surly bonds of earth; now if I can just land without bending the gear..."
"Watch out for those doves...smack-smack-smack-smack..."
Old June 14th 06, 01:53 PM posted to rec.aviation.ifr,rec.aviation.student
I honestly don't see why a pilot needs to know anything beyond, "A VOR
transmits 360 radials, and the NAV receiver can tell which one you're on".
Unlike some of the physics half-truths the FAA pushes, I can't see how this
little white lie could possibly get you into any operational trouble. It
doesn't get in the way of understanding VOR declination, or service
volumes, or scalloping due to signal reflections, or reverse sensing, or
the zone of confusion, or any of a number of little VOR gotchas that pilots
do need to be aware of.
Old June 14th 06, 03:55 PM posted to rec.aviation.ifr,rec.aviation.student
I've been teaching instruments for a few years, and I think you're
learning useful stuff.
If you don't understand how the equipment operates, the only way you
can learn to operate the equipment is by rote. If you're always flying
with everything multiply redundant, always flying with the same stuff,
and can simply squawk anything out of the ordinary and make it someone
else's problem, you can get by that way if you're willing to memorize a
lot. It's an airline pilot sort of attitude. It doesn't work too well
in GA. The people we train often have only one of something, and thus
an understanding of how it works - and thus of the failure modes -
helps detect failures and understand their impact on the operation.
They usually pay for their own maintenance, and often participate in
the maintenance process, and thus being able to diagnose the failure is
valuable. They also upgrade equipment, and understanding how it works
means not needing to be retrained on every new item.
Michael
Old June 14th 06, 04:32 PM posted to rec.aviation.ifr,rec.aviation.student
"Jose" wrote in message . com...
Jose
Jose, you asked and I answered. I didn't disagree with you.
The truth is out there for those who are interested.
But Jim's DME explanation was egregiously wrong, and shouldn't propagate.
Old June 14th 06, 04:42 PM posted to rec.aviation.ifr,rec.aviation.student
"Roy Smith" wrote in message ...
This is usenet so we like to split hairs. :-)
VORs are not limited to "360 radials".
If you want to claim you navigate to 1/2-degree precision, or finer, VORs do that.
Personally, I try not to claim that ability, though. :-/
Oral Exam Prep -- recommendations and recollections Nicholas Kliewer Instrument Flight Rules 0 November 15th 04 05:00 PM
Training for my CFII - Got a couple questions BoDEAN Instrument Flight Rules 11 May 3rd 04 12:42 PM
