Jim Macklin wrote:
The stall buffet comes from disturbance of the air flow over the wing root, but the actual stall comes from the tail. Actual stall comes from the tail?? Meaning?? This is more arcane than I'd bargained for ![]() Ramapriya |
Jim Macklin wrote:
The stall buffet comes from disturbance of the air flow over the wing root, but the actual stall comes from the tail. Ramapriya wrote: Actual stall comes from the tail?? Meaning?? This is more arcane than I'd bargained for ![]() I think that Jim got it bassackwards. Approaching the stall, airflow at the wing root separates and strikes the horizontal stabilizer, shaking it and providing the stall warning required by FAR 23.207. From Wikipedia: In aerodynamics, a stall occurs when the critical angle of attack is exceeded, causing loss of lift and a large increase in drag due to disruption of airflow. Section 23.207: Stall warning. (a) There must be a clear and distinctive stall warning, with the flaps and landing gear in any normal position, in straight and turning flight. (b) The stall warning may be furnished either through the inherent aerodynamic qualities of the airplane or by a device that will give clearly distinguishable indications under expected conditions of flight. However, a visual stall warning device that requires the attention of the crew within the cockpit is not acceptable by itself. (c) During the stall tests required by §23.201(b) and §23.203(a)(1), the stall warning must begin at a speed exceeding the stalling speed by a margin of not less than 5 knots and must continue until the stall occurs. (e) During the stall tests required by §23.203(a)(2), the stall warning must begin sufficiently in advance of the stall for the stall to be averted by pilot action taken after the stall warning first occurs. Bob Moore |
No, I said the buffet comes from the wing root, but the
actual stall is when the tail stalls and looses lift (down force) and then the nose pitches down because the still flying wing CP is behind the CG. http://www.faa.gov/library/manuals/a...83-25-1of4.pdf -- James H. Macklin ATP,CFI,A&P "Bob Moore" wrote in message . 122... | Jim Macklin wrote: | The stall buffet comes from disturbance of the air flow over the wing | root, but the actual stall comes from the tail. | | Ramapriya wrote: | Actual stall comes from the tail?? Meaning?? This is more arcane than | I'd bargained for ![]() | | I think that Jim got it bassackwards. Approaching the stall, airflow at | the wing root separates and strikes the horizontal stabilizer, shaking | it and providing the stall warning required by FAR 23.207. | | From Wikipedia: | In aerodynamics, a stall occurs when the critical angle of attack is | exceeded, causing loss of lift and a large increase in drag due to | disruption of airflow. | | | Section 23.207: Stall warning. | (a) There must be a clear and distinctive stall warning, with the | flaps and landing gear in any normal position, in straight and turning | flight. | | (b) The stall warning may be furnished either through the inherent | aerodynamic qualities of the airplane or by a device that will give | clearly distinguishable indications under expected conditions of flight. | However, a visual stall warning device that requires the attention of | the crew within the cockpit is not acceptable by itself. | | (c) During the stall tests required by §23.201(b) and §23.203(a)(1), | the stall warning must begin at a speed exceeding the stalling speed by | a margin of not less than 5 knots and must continue until the stall | occurs. | | (e) During the stall tests required by §23.203(a)(2), the stall | warning must begin sufficiently in advance of the stall for the stall to | be averted by pilot action taken after the stall warning first occurs. | | Bob Moore |
"Jim Macklin" wrote in message
news:J4Wlg.49291$ZW3.49195@dukeread04... No, I said the buffet comes from the wing root, but the actual stall is when the tail stalls and looses lift (down force) and then the nose pitches down because the still flying wing CP is behind the CG. If that were true, then it wouldn't be possible to sustain a stall (in, say, a C172) by maintaining back pressure on the yoke. But in fact, such a stall can be sustained: the plane is stalled because the wings are past the critical angle of attack; and the tail, which is *not* stalled and does *not* lose lift, can hold that angle of attack if up-elevator pressure is continued. It is possible to stall the tail if the CG is too far forward. This is especially likely during a landing flare, resulting in a sudden drop of the nose. But that's not how a normal stall occurs. http://www.faa.gov/library/manuals/a...83-25-1of4.pdf Are you referring to the paragraph about stalls on p. 3-21? First, the information there is partly incorrect--there is no reason to think that the tail's (downward) lift ceases during a normal stall, and (as I mentioned above) the sustainability of such a stall (by continued back pressure) shows that the tail's lift does not cease. Second, the paragraph does not state that the tail's alleged loss of lift begins the plane's stall, but rather that it contributes to a stall *recovery*. --Gary |
![]() Jim Macklin wrote: No, I said the buffet comes from the wing root, but the actual stall is when the tail stalls and looses lift (down force) and then the nose pitches down because the still flying wing CP is behind the CG. That applies to canards. Tuft-testing of conventional layouts proves that the pitch-down comes from the wing's airflow breaking up, and when that happens the CP moves well aft of the CG and pitches the nose down. Stalling stabilizers/elevators are dangerous and are not designed into the conventional airplane. The early Cardinal had that problem, and would drop the nosewheel hard on the runway during the flare, sometimes breaking it. Cessna had to put slots in the stabilator to keep it from stalling. Ice on the stab can also cause stabilizer stall and control reversal (pull back, nose goes down). Not desireable at all. The aircraft service manual will have control surface travels, as do the Type Certificate Data Sheets. Those travels are intended, in part, to prevent stalling and control reversal. Dan |
Jim Macklin wrote:
No, I said the buffet comes from the wing root, but the actual stall is when the tail stalls and looses lift (down force) and then the nose pitches down because the still flying wing CP is behind the CG. http://www.faa.gov/library/manuals/a...83-25-1of4.pdf You keep referencing this 111 page document, but you don't reference where in it you found what you mention above. What page? Matt |
On Tue, 20 Jun 2006 12:18:27 -0500, "Jim Macklin"
wrote: No, I said the buffet comes from the wing root, but the actual stall is when the tail stalls and looses lift (down force) and then the nose pitches down because the still flying wing CP is behind the CG. http://www.faa.gov/library/manuals/a...83-25-1of4.pdf If the tail stalls there will be no question that the tail stalled. It is not the same as a normal stall we have all experienced. It is abrupt and it had better either happen with enough altitude to recover (hopefully with the capability to recover) from a very steep nose down attitude, or close enough to the ground that you don't brake anything when the nose gear drops. Back in the 50's and 60's there were some T-tailed aircraft that were noted for the tail stalling if you tried to do a full stall landing. That was a situation easily handled by not doing full stall landings in those planes. Another point about tail stalls. Ever wonder why a plane loaded with ice comes down final at near cruise? You might stall the wing from weight, or ice changing the configuration or the tail due to configuration. When you look out there and discover the boots have created a void behind the ice and are doing nothing to that 3 or more inches of horn shaped ice on the leading edge you are now a test pilot flying an airplane with unknown characteristics. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
The tail is more heavily loaded and at a higher angle of
attack than the wing. The tail lift is actually a tail down force. You can look up a textbook on stability, control and weight and balance to see that with a conventional tail, the wing lift is located on the center of pressure, while the CG is located some small distance forward of that point. The tail provides a downward forced on the tail that creates a moment around the CG to balance the moment arm between the center of pressure and the CG. When the pilot feels a stall buffet, it is caused by air flow separation that impacts the tail or some other part of the structure. But the stall break happens when the tail stalls and the CG moment is no longer countered by the tail down force. On a canard aircraft such as Burt Rutan designs, the forward wing is heavily loaded and lifts up and the main wing is more lightly loaded and at a lower angle of attack. When the plane approaches the stall, the forward wing stalls first and the nose drops. see http://www.faa.gov/pilots/training/handbook/ this is the link to the chapters you need http://www.faa.gov/library/manuals/a...83-25-1of4.pdf -- James H. Macklin ATP,CFI,A&P wrote in message oups.com... | Jim Macklin wrote: | The stall buffet comes from disturbance of the air flow over the wing root, but the | actual stall comes from the tail. | | | Actual stall comes from the tail?? Meaning?? This is more arcane than | I'd bargained for ![]() | | Ramapriya | |
No. The wing stalls first, usually.
There have been tail stalls due to ice formtion. karl ATP CFI ETC "Jim Macklin" wrote in message news:I0Wlg.49289$ZW3.19338@dukeread04... The tail is more heavily loaded and at a higher angle of attack than the wing. The tail lift is actually a tail down force. You can look up a textbook on stability, control and weight and balance to see that with a conventional tail, the wing lift is located on the center of pressure, while the CG is located some small distance forward of that point. The tail provides a downward forced on the tail that creates a moment around the CG to balance the moment arm between the center of pressure and the CG. When the pilot feels a stall buffet, it is caused by air flow separation that impacts the tail or some other part of the structure. But the stall break happens when the tail stalls and the CG moment is no longer countered by the tail down force. On a canard aircraft such as Burt Rutan designs, the forward wing is heavily loaded and lifts up and the main wing is more lightly loaded and at a lower angle of attack. When the plane approaches the stall, the forward wing stalls first and the nose drops. see http://www.faa.gov/pilots/training/handbook/ this is the link to the chapters you need http://www.faa.gov/library/manuals/a...83-25-1of4.pdf -- James H. Macklin ATP,CFI,A&P wrote in message oups.com... | Jim Macklin wrote: | The stall buffet comes from disturbance of the air flow over the wing root, but the | actual stall comes from the tail. | | | Actual stall comes from the tail?? Meaning?? This is more arcane than | I'd bargained for ![]() | | Ramapriya | |
Jim Macklin wrote:
The tail is more heavily loaded and at a higher angle of attack than the wing. The tail lift is actually a tail down force. You can look up a textbook on stability, control and weight and balance to see that with a conventional tail, the wing lift is located on the center of pressure, while the CG is located some small distance forward of that point. The tail provides a downward forced on the tail that creates a moment around the CG to balance the moment arm between the center of pressure and the CG. When the pilot feels a stall buffet, it is caused by air flow separation that impacts the tail or some other part of the structure. But the stall break happens when the tail stalls and the CG moment is no longer countered by the tail down force. On a canard aircraft such as Burt Rutan designs, the forward wing is heavily loaded and lifts up and the main wing is more lightly loaded and at a lower angle of attack. When the plane approaches the stall, the forward wing stalls first and the nose drops. see http://www.faa.gov/pilots/training/handbook/ this is the link to the chapters you need http://www.faa.gov/library/manuals/a...83-25-1of4.pdf I did a quick search and find nothing about the tail stalling before the wing under normal conditions. On which page did you see this? Personally, I don't believe this. If this were the case, then during a full stall landing, the airplane would rise upward when the tail stalled as the net force in the vertical direction would be greater upward than downward. Yes the airplane would rotate about the center of lift and the nose would fall, but the wing would be rising at the same time. This isn't the way any airplane I've ever flown behaved. Matt |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Practice stalls on your own? | [email protected] | Piloting | 34 | May 30th 05 05:23 PM |
Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 04:05 AM |
military men "dumb, stupid animals to be used" Kissinger | B2431 | Military Aviation | 3 | April 26th 04 05:46 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
