Getting the MOCA
Old June 24th 06, 05:15 PM posted to rec.aviation.ifr
Default Getting the MOCA
Mitty wrote:
On 6/23/2006 8:25 PM, Steven P. McNicoll wrote the following:
"Mitty" wrote in message
No it's not. I have gotten lower than MIA. Just this Wednesday, in
fact. It was a VFR day but I was on an IFR flight plan.
So you were cleared via airways and got the MEA or the MOCA which was
lower than the MIA?
Typing speed ovecame brain speed. I was cleared below the MEA, not the
MIA.
You probably were not cleared below the MIA.
Old June 24th 06, 05:47 PM posted to rec.aviation.ifr
Sam Spade writes:
[snip]
However, if both a MEA and a MOCA are prescribed for a particular route
or route segment, a person may operate an aircraft below the MEA down
to, but not below, the MOCA, when within 22 nautical miles of the VOR
concerned (based on the pilot's reasonable estimate of that distance).
Idle curiosity: From whence came the magic 22 nm. number?
The VOR turns into a pumpkin at 22.1 nm?
Old June 24th 06, 06:02 PM posted to rec.aviation.ifr
"Whence". Not "from whence". "Whence" means "from where". "Whither"
means "to where". "Wither" means "it no longer matters to where".
As to your original question, some idle speculation - the VORs are
certified and flight tested out to 22nm, and beyond that they are not
guaranteed to be usable.
Jose
The monkey turns the crank and thinks he's making the music.
Old June 24th 06, 07:15 PM posted to rec.aviation.ifr
Everett M. Greene wrote:
Sam Spade writes:
[snip]
It is 25 s.m., which is 22 n.m.
I can only speculate that in the early days of VOR it became quickly
apparent that relief from the MEA when nearing a VOR on an airway with a
lower MOCA would provide better descent transitions onto IAPs, etc.
The feds probably had a meeting and asked the electronic experts to come
up with a distance that would work everywhere.
That's how things like that usually come about.
Old June 24th 06, 10:47 PM posted to rec.aviation.ifr
"Sam Spade" wrote in message
news:Nbdng.34735$AB3.24485@fed1read02...
No, I don't. I keep reading the FARs, unlike you.
It's a pity you're unable to comprehend what you've read.
Old June 24th 06, 10:59 PM posted to rec.aviation.ifr
I comprehend the following language of Part 91 a whole lot better than
you do. Then again, I don't argue with regulations, charts, procedures,
safe operating practices, conservative flight operations, etc.
"However, if both a MEA and a MOCA are prescribed for a particular route
concerned (based on the pilot's reasonable estimate of that distance)."
Old June 24th 06, 11:11 PM posted to rec.aviation.ifr
"Everett M. Greene" wrote in message
Can't say for sure, but the 22 knot and 44 knot rules for longitudinal
separation were known as the 25 mph and 50 mph rules before knots and
nautical miles replaced mph and statute miles as standard units for speed
and distance in aviation. I'd bet the magic number for MOCA used to be 25
miles.
Old June 24th 06, 11:14 PM posted to rec.aviation.ifr
"Jose" wrote in message
. com...
Service volume of VORs varies with the class of the VOR and altitude, but
the standard for even Terminal VORs is 25 NM.
  #29
Old June 24th 06, 11:22 PM posted to rec.aviation.ifr
news:mBing.34763$AB3.32586@fed1read02...
I comprehend the following language of Part 91 a whole lot better than you
do.
Actually, you don't, you only think that you do.
Then again, I don't argue with regulations, charts, procedures, safe
If what you wrote in these forums was consistent with regulations, charts,
procedures, safe operating practices, conservative flight operations, etc.,
we would never have an argument. There are regular users here that possess
a great deal of valuable information and experience. They present a
valuable educational resource, but you must change your attitude in order to
take advantage of it.
  #30
Old June 25th 06, 01:47 PM posted to rec.aviation.ifr
do.
Right. You are so full of it, Stevie, it is no wonder many regulars
won't even let you suck them in to feed your tiny, bruised ego.
MEA oddity near Harrisburg, PA? Journeyman Instrument Flight Rules 14 May 16th 06 03:42 PM
MOCA and MEA over water??? Roy Smith Instrument Flight Rules 16 May 16th 05 08:13 PM
