Jeez, this is so intense?
Old July 1st 06, 04:19 AM posted to rec.aviation.piloting
karl gruber[_1_]
Default Jeez, this is so intense?
turn.
It's not clear what you're correcting. You are right that I should have
written "turn rate" instead of "bank angle". It was kind of late. But
you do also get roll rate from the turn coordinator. It's not "rate of
turn only".
Pete
The turn coordinator senses roll and yaw. It exaggerates the roll and thus
indicates a standard rate turn before the aircraft is actually banked that
far. The exaggeration is good for an autopilot pickup because it reduces the
inherent lag in autopilot systems.
It is not good in turbulence because it makes it easy to over compensate.
That is why rate based autopilots like the S-Tec are not as smooth as
attitude based autopilots in turbulence. There are still arguments about
which is better, a turn coordinator or a turn and bank. A turn and bank is
better in turbulence. A turn coordinator is easier for a student to
visualize, although they seldom know just what they are seeing-----For
instance, a TC will indicate a bank on the ground when turning, when there
is clearly no banking going on.
Karl
"Curator" N185KG
AIRCRAFT MUNITIONS - THE COBALT BOMB Garrison Hilliard Military Aviation 1 August 29th 03 09:22 AM
