![]() " wrote in message ups.com... .... For the next level, figure out a way to turn it on remotely! Bill Hale who does it with X-10 but is looking for a cell phone solution! X-10.com has some sort of remote call in box gizmo thingie to do this.... |
On Thu, 29 Jun 2006 20:56:29 -0400, "Kyle Boatright"
wrote: I need a trickle of electrical power about a dozen times a year in my hangar. I need it for my 125 watt preheater if I'm taking an early-morning flight in the winter, and will use it for a .25A trickle charger if I've let the aircraft sit for more than a week or two. The problem is that my T-hangar doesn't have power. One of the other hangar renters had electrical service pulled to his hangar, and sublets 15A breakers for $15/month = $180/year, which is a bit much for me, considering my needs are for a dollar or so of electricity a year. Any suggestions other than either buying a small generator or paying the $15/month? I'm asking because the "power guy" complained last week when I ran a dropcord to a neighboring hangar for an hour last week to run the trickle charger... KB Kyle, Where are you located and do you have an unobstructed southern exposure for solar panels? Could you south facing solar panels on the roof of your hangar? In Georgia, to set up a reliable solar system that would meet the requirements you outlined above will probably cost about $500. Maintenance would be to check the battery water at appropriate intervals (a few times a year). It might be less expensive to run a line from your neighbor's hangar, and pay him a few bucks a month. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
I would hesitate to recommend solar panels and batteries for the
purpose of generating heat - but it is certainly do-able. Were I to decide to go this route I would find some sort of a DC heating element to use - thus avoiding the expense and conversion loss of running an inverter. If your winter flying is infrequent you could figure your recharge time to be a week or more, and thus size your solar array accordingly (and save upfront cost in the process). I have had great success with using solar battery maintainers in my airplane and also in a seldom-used vehicle. This past winter I tried a different approach to preheat. AC was available - with a long extension cord - and I had a couple of the "cube" style ceramic heaters laying around. I picked up a couple of dryer duct flanges and duct taped these to the business ends of the cubes. Then I took an 8' dryer hose, cut it in half and attached the halves to the cubes. Feeding the heat to the engine by way of the cowl flap openings, I let this rig run for half an hour with temperatures in the 20s. I have no idea what the engine temperature was after this treatment, but it did start immediately - just like in warm weather. If no AC is available, one could power heaters of this sort with an inverter in a car. It would take a large one - 3 KW or so for a pair running on high. It occurred to me that a couple of cheap ($10 at Walmart) hair dryers might do the job just as well (the wattage is similar - about 1500) - but I haven't had the opportunity to try it. David Johnson |
On Wed, 5 Jul 2006 08:06:44 -0400, Kyler Laird
wrote: writes: Were I to decide to go this route I would find some sort of a DC heating element What kind of heating element *doesn't* work on DC? --kyler Obviously, any resistive load will heat up if you put DC voltage to it. But now you've got me thinking. What are the design considerations for converting a heating element that has been designed to function on 120VAC to 12VDC? For example, I have a TANIS system in my a/c which draws about 375W @ 120VAC. It consists of four heated intake bolts, and a heated oil screen. It works very well and heats the entire engine to 75-100°F on below zero F days (with a cover). I'd guess, as a minimum, I'd have to rewire everything to handle ten times the current, depending on whether or not the 120V wiring is oversized, or not. That might (or might not) add sufficient weight to have to do a new W&B (A&P and logbook entry required). Obviously have to change the connectors, too. How simple would it be to attach the larger wire to the bolts and engine oil screen? Will the heating elements handle a continuous (DC) as opposed to an intermittent (AC) current? Or will I need some kind of controller/thermostat? I'd also want to retain the ability to run on AC, so I'd need some kind of additional connector -- probably paralleled with the AC connector. What about the AC neutral/ground? If that gets upset in the rewiring, I'll wind up blowing GFCI breakers when I use AC. ?? Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Ron Rosenfeld writes:
Obviously, any resistive load will heat up if you put DC voltage to it. But now you've got me thinking. What are the design considerations for converting a heating element that has been designed to function on 120VAC to 12VDC? Note that I wasn't suggesting using 12VDC. I was thinking in terms of an equivalent voltage DC. That would not require any changes to your installed system. I'm really not even suggesting using DC; I was just pointing out that the heating elements can handle it. Nine 12V batteries in series should give approximately the equivalent power to a resistive load as 120VAC. It could be done but it'd be a pain. I think you'd be happier using a special-purpose (cheap, high-efficiency) inverter on a single 12V battery. You could have a noisy 400 Hz inverter and it would be perfectly fine for your heating elements. ....or you could just buy a decent general-purpose inverter and use it for powering a video projector for late-night drive-in movies at the hangar when the weather is nice. --kyler |
Ron Rosenfeld wrote:
: What are the design considerations for converting a heating element that : has been designed to function on 120VAC to 12VDC? : For example, I have a TANIS system in my a/c which draws about 375W @ : 120VAC. You wouldn't convert it. You'd just hook it up to ~125 VDC. It will work great. You may have trouble if it has an electronic thermostat (SCR/TRIAC) because these require the reversals of the AC voltage to stop conducting (you can turn on a TRIAC with DC across it, but you have to interrupt the current flowing to shut it off). -- Aaron C. |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
Please help -- It's down to the wire | Jay Honeck | Owning | 24 | July 14th 04 06:05 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
