#21
"Dan Luke" wrote: While we are at it, the power plug is VERY tight. I swear I am bunging the thing up putting it in an taking it out. I hope this gets easier with time. It won't. Better buy a spare. I haven't had a problem with the power cable, though I agree that it isn't in a great location relative to the mounting bracket. However, I can't figure out why the USB cable for the GXM30 has a right-angle plug on the end. Even in the auto mount, the plug angle jams the cable down into the mounting surface. Doesn't make any sense to me. It is this cable (or the USB receptacle inside the unit) that I worry about breaking or stressing loose over time. JKG |
It is this cable (or the USB receptacle inside the unit) that I worry about breaking or stressing loose over time. Agreed. I suspect mine is starting to go already... |
Question for GPS396 users...
Would the ability to make displayed items variably/selectively translucent enhance the readability of the display? (The MacIntosh OS X has the ability to make display panes translucent so you can see the screen beneath the pane. Windows VISTA will also have this feature.) |
In article .com,
"Mike Granby" wrote: It is this cable (or the USB receptacle inside the unit) that I worry about breaking or stressing loose over time. Agreed. I suspect mine is starting to go already... I am careful to ONLY grab the top of the plug when I pull it out, and pull it straight out. The receptacle moves a little, though, which worries me that at some point the solder joints are going to break loose. The right-angle plug must have been the brainchild of the same person who decided to put the earth's strongest magnets in the base of the GXM30. I suppose that the end of the cable could be re-terminated with a straight mini-USB plug. JKG |
| Thread Tools | |
| Display Modes | |
| Garmin gpsmap 96 and onlinecontest? | DBn | Soaring | 3 | June 10th 06 12:46 AM |
| WTB: Garmin GPSMAP 196 ccessories | bobo | Aviation Marketplace | 0 | December 7th 04 05:07 AM |
| Garmin gpsmap 76s, glide ratio, airspace zone | Gilles_Sauvagnat | Soaring | 11 | April 15th 04 01:39 AM |
| Garmin GPSmap 196 on 172 Yoke | Otto Braasch | Owning | 2 | February 20th 04 10:58 PM |
| PLEASE HELP! GARMIN GPSMAP 196 Update and now my maps fail to show properl | PaulaJay1 | Owning | 0 | August 13th 03 07:52 PM |
