Garmin GpsMap 396 - Flight Test
Old July 7th 06, 04:23 AM posted to rec.aviation.owning
Dan[_1_]
Default Garmin GpsMap 396 - Flight Test
I inquired to Garmin Tech support about our problems and got the
following response about clearing the almanac. Probably worth a shot.
--Dan
Problem:
I had a problem with satellite reception over the weekend. In
disucssing this with other GPSMAP 396 users, including one who recently
upgraded to firmware 3.20, it seems they are experiencing similar
problems as well.
(i.e. intermittent GPS satellite loss) I have a GPSMAP 195 and have
never had a satellite signal issue. Is this a known problem? Will there
be a firmware fix?
Thank you for contacting Garmin.
As the GPS uses a satellite almanac of data to track the satellites,
corruption of this almanac will cause the unit to drop the satellite
signals. To correct(erase) the almanac, turn the unit off. Press and
hold the OUT button while turning the GPS on. When the GPS powers on,
release the buttons and let it acquire the satellite signals to start
rebuilding the almanac.
If you have any other questions, please let me know.
Best Regards
Thanks. Would this likely resolve intermittent outages, or is this
only in the case of being completely unable to get a satellite lock at
all?
--Dan
As the unit contains data on all of the satellites and cycles between
all ones available, corruption of even one satellite's data could cause
the unit to have brief outages as it cycles through the list.
Best Regards
Dan wrote:
By the way, this was with firmware version 2.8 which is what came on
the unit. I am planning to upgrade to 3.2 soon.
--Dan
Dan wrote:
I picked up a 396 on Friday and it was fine all the way from Phoenix to
Santa Fe, but lost it's sat signal during landing in Chandler....
Strange, but it seems I am not alone.
--Dan
Mike Spera wrote:
30 seconds after take off, lost
the GPS sat lock. Took about 15 seconds to regain it. In the next 5
minutes, it lost lock several more times. I'm thinking, external antenna
is loopy.
Mike,
For what its worth...
I just flew my Arrow around the country and experienced the same
problem (with my brand spank'n new 396) that you described. Most of the
occurrences were in the takeoff or landing phase of the flight. I had
my old Lowrance airmap 100 on the copilot yoke and it never lost lock
once during the flight. The 396 was connected to the remote antenna
which was sitting on the glare shield, the airmap 100 was using it's
built in antenna.
-Bernie
My fly-about http://www.iperformax.com/flyabout/flyabout.html
Old July 7th 06, 12:03 PM posted to rec.aviation.owning
Denny
Awwww right! I learned something here.. Who says Usenet is useless...
denny
Old July 7th 06, 02:13 PM posted to rec.aviation.owning
john smith
In article .com,
"Dan" wrote:
Press and hold the OUT button while turning the GPS on.
What is the OUT button? (Is that one of the ZOOM buttons?)
Old July 7th 06, 03:28 PM posted to rec.aviation.owning
Dan,
I spoke with Garmin today and got the same reply today. I followed the
procedure to reset the almanac and it took maybe 20 minutes to
complete. I also discussed a problem I am have having with my
lightspeed thirty 3Gs where I get a squeal through the headset when
attached to the 396 when the 396 is plugged in to the cig. lighter.
The support guy suggested I try a ground loop isolator between the 396
and the headset battery box. He mentioned RadioShack, but theirs does
not natively support the 3.5mm (1/8 inch) jack (RS requires a cable
adaptor). I did find a product at crutchfield.com ( 127SNI135 PAC
SNI-1/3.5 Minijack Ground Loop Isolator) that has female / male 3.5 mm
jacks. They web site has 5 testimonials, 2 from 396 owners, asserting
it solved all problems with using the 396's XM radio in the cockpit. I
ordered one today for about $18.00 + $6 shipping. I'll post a reply
next week with the result, but it looks promising.
-Bernie
Old July 9th 06, 01:53 AM posted to rec.aviation.owning
darthpup
GPS units need to have a "quadrifilar" design antenna or they will not
work well.
I had an older Garmin that I connected to an older stock GPS antenna
outside the Cherokee and it still would not work reliably. There is
information on this design antenna on the web. Magellan uses the quad.
http://www.qsl.net/n8imo/qha_4.html
Old July 9th 06, 04:27 PM posted to rec.aviation.owning
RST Engineering
You are either funning us, or you have absolutely no idea what a quadrifilar
antenna is. A two foot high antenna mounted on a 6 foot high mast isn't
going to mount easily on anybody's airplane, let alone a homebuilt.
Your "older Garmin ... connected to an older stock GPS antenna" probably
didn't have an amplifier in the antenna with enough gain to overcome the
loss in the coax you used.
Most GPS external antennas use a modified patch antenna with a 25-30 dB
amplifier mounted to the backside of the patch.
"darthpup" wrote in message
work well.
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Products 10 April 29th 04 06:57 AM
