#21
![]() wrote in message ... "Max T, CFI" wrote: I disagree with the method described below for calculating a 5/8 wavelenth antenna. As I recall, the formula you have below gives you the length in feet of a half wave length antenna (not the full wavelength as you suggest). So a 5/8 ths wave antenna would be twice as long as you calculated. Also, if you took a 2 meter 5/8's wave antenna, you'd need to lengthen it (not cut it down) to use it as a 5/8 wave antenna on 123 MHz. You probably could take a 5/8 wave 2 meter ham antenna and cut it down to a 1/4 wavelength antenna for use on 123 MHz. The length for that would be somewhere around 22.89 inches. Max T, CFI (and ham radio operator) EDR wrote in message ... In article , CHANGE USERNAME TO westes wrote: How tall was that telescoping antenna? I do not remember how long it extends to. IIRC, the formula is 468/f(MHz) gives the wavelength. Multiply by 5/8 to get the antenna length in feet. For 123.0 MHz (middle of the band), the length is 28.5 inches. Does anyone sell an off the shelf 5/8 wave telescoping antenna with a strong magnetic base? Just purchase a standard ham 2m mag mount antenna and cut a piece of stainless steel rod that fits the mag mount to the above calculated length. I had mine cut for 128.0 MHz to optimize the VHF voice band. The nav frequencies are less important. Ham Radio Specialists in San Diego cut it, and had stock to do 5/8 wave length at that frequency. The whip is much longer than 28.5 inches; somewhere around 40 inches, or so. The "5/8 wavelength" is an electrical, equivalent length. This can be different than a physical length depending on loading coils (inductive) and "top hat" (capacitive) loads are used. In general you can't cut premade antennas. |
![]() "William W. Plummer" wrote: wrote in message ... "Max T, CFI" wrote: I disagree with the method described below for calculating a 5/8 wavelenth antenna. As I recall, the formula you have below gives you the length in feet of a half wave length antenna (not the full wavelength as you suggest). So a 5/8 ths wave antenna would be twice as long as you calculated. Also, if you took a 2 meter 5/8's wave antenna, you'd need to lengthen it (not cut it down) to use it as a 5/8 wave antenna on 123 MHz. You probably could take a 5/8 wave 2 meter ham antenna and cut it down to a 1/4 wavelength antenna for use on 123 MHz. The length for that would be somewhere around 22.89 inches. Max T, CFI (and ham radio operator) EDR wrote in message ... In article , CHANGE USERNAME TO westes wrote: How tall was that telescoping antenna? I do not remember how long it extends to. IIRC, the formula is 468/f(MHz) gives the wavelength. Multiply by 5/8 to get the antenna length in feet. For 123.0 MHz (middle of the band), the length is 28.5 inches. Does anyone sell an off the shelf 5/8 wave telescoping antenna with a strong magnetic base? Just purchase a standard ham 2m mag mount antenna and cut a piece of stainless steel rod that fits the mag mount to the above calculated length. I had mine cut for 128.0 MHz to optimize the VHF voice band. The nav frequencies are less important. Ham Radio Specialists in San Diego cut it, and had stock to do 5/8 wave length at that frequency. The whip is much longer than 28.5 inches; somewhere around 40 inches, or so. The "5/8 wavelength" is an electrical, equivalent length. This can be different than a physical length depending on loading coils (inductive) and "top hat" (capacitive) loads are used. In general you can't cut premade antennas. What do I know? I trusted the guy at a ham radio store (which has a great reputation) and the setup worked great. |
I could hear the ATIS and talk
with ground control five miles from the airport on the freeway. I could drive along I-5 on the coast and talk with LA Center's RCO on Catalina Island. Were you really "talking" to these stations? The 108-136 MHz band(s) is(are) for /air/ mobile operations. Talking to LA Center while driving on I5 would seem to be illegal. since he was "driving" in LA (I sitting in endless traffic), I highly highly doubt he was "mobile." Maybe he was on a tall off-ramp so might have been in the "air." Gerald |
![]() Gerald Sylvester wrote: I could hear the ATIS and talk with ground control five miles from the airport on the freeway. I could drive along I-5 on the coast and talk with LA Center's RCO on Catalina Island. Were you really "talking" to these stations? The 108-136 MHz band(s) is(are) for /air/ mobile operations. Talking to LA Center while driving on I5 would seem to be illegal. since he was "driving" in LA (I sitting in endless traffic), I highly highly doubt he was "mobile." Maybe he was on a tall off-ramp so might have been in the "air." North San Diego County isn't exactly LA. |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Thoughts on handheld Aviation radios (ICOM vs Vertex-Standard) | Barnyard BOb - | Home Built | 5 | September 8th 04 07:27 PM |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Home Built | 3 | May 14th 04 11:55 AM |
Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! | Jay Honeck | Home Built | 18 | January 20th 04 04:02 PM |
Marine Radio using Aviation Antennae | Jim Weir | Home Built | 13 | August 12th 03 10:05 PM |
