Aviation Dilemma 101 - How much trust in a 10 day forecast??
Old July 20th 06, 11:43 PM posted to rec.aviation.piloting
.Blueskies.
Default Aviation Dilemma 101 - How much trust in a 10 day forecast??
"Morgans" wrote in message ...
: "Peter R." wrote
: This time of year (at least during the day) the type of IMC they get is in
: the form of t-storms, is it not? An IFR rating won't really help here.
: I have seen OSH go IFR only, with no T-storms around, but that is the
: exception to the rule. Usually, you are right.
: The one day I am thinking of, it went from closed to VFR, in a period of
: about 3 minutes, then closed again.
: I wonder if the two Harriers, reporting at 5 miles out, coming in low fuel
: had anything to do with that? vbg It did close again, less than a minute
: after they were on the ground! g
: Jim in NC
The down vectored thrust burned a hole that made it VFR. Of course it closed back in after they landed, the heat was
gone...
Old July 21st 06, 03:18 AM posted to rec.aviation.piloting
Morgans[_3_]
gone...
Yea, they did use some downward thrust, for that landing. Did you happen to
see it? I think it was '03.
I happen to be out there flagging 18 traffic on Papa Center, (the next
intersection North of the West Ramp) and they touched down with about half
down thrust, about even with where I was. It had rained, so the runway was
wet, and they kicked up quite a cloud of spray. You couldn't get any
closer, unless you were in the plane! It was _way_ too cool!
Old July 21st 06, 01:44 PM posted to rec.aviation.piloting
john smith
closed back in after they landed, the heat was gone...
There was a book I read 30+ years ago that related the operational
development of radar at an English airfield during WWII. I want to say
Arthur C Clark was the author, but I am not certain.
One of the tales that was related told about an idea someone in the war
ministry had.
The idea was to set out smudge pots along the sides of the runway in a
manner similar to runway lights.
When there was heavy fog and it was necessary to land aircraft, the
ground support crews would drive down the runway and light all the
smudge pots.
The heat generated by the smudge pots would then dissipate the fog along
the runway, allowing aircraft to land.
The smudge pots were lit and the fog did dissipate.
The surprise came when the first aircraft attempted to land. As it
approached the flair, it began to go out of control. The pilot managed
to regain control and successfully land.
Everyone gathered around him as he climbing out of the cockpit, asking
what had happened.
It seems the smudge pots were generating so much heat that the localized
air along the runway became turbulent.
Thus ended the experiment.
Old July 21st 06, 05:11 PM posted to rec.aviation.piloting
john smith
T o d d P a t t i s t wrote:
A link showing it in use with a Lancaster bomber:
http://www.fpp.co.uk/overflow/Dresde...ages/0042.html
Aircraft circling above airfield, fog along the runway begins to clear,
pre-landing briefing...
Scientist to Pilot: "Just land between those two rows of fire."
Pilot: "You want me to what!!!"
Old July 22nd 06, 12:43 PM posted to rec.aviation.piloting
.Blueskies.
"T o d d P a t t i s t" wrote in message
: john smith wrote:
: The idea was to set out smudge pots along the sides of the runway in a
: manner similar to runway lights.
: When there was heavy fog and it was necessary to land aircraft, the
: ground support crews would drive down the runway and light all the
: smudge pots.
: The system was known as FIDO - Fog Intensive Dispersal Of.
: It used perforated pipes along the runway and usually burned
: the local petrol supply. Problems were encountered in the
: early tests, but it was ultimately put to use and developed
: further after the war.
: A link showing it in use with a Lancaster bomber:
: http://www.fpp.co.uk/overflow/Dresde...ages/0042.html
They did something similar with ground based jet engines at Heathrow back in the '60s. Don't know the details...
Old July 22nd 06, 12:52 PM posted to rec.aviation.piloting
Jim Macklin
I seem to remember reading in one of Robert Buck's books
that the airlines were grounded because the weather was
below take-off minimums at some airport in the east, perhaps
JKF. They had several 747s taxi on the runway and that
heated the air enough to raise the RVR to take-off minimums.
As soon as they all started taking off, the heat cleared the
runway.
The FAA tried to violate the crews for "weather
modification, taking off below minimums. They dropped the
case because it was stupid, the weather did improve.
James H. Macklin
ATP,CFI,A&P
".Blueskies." wrote in
message
. net...
the runway in a
aircraft, the
light all the
| : smudge pots.
Of.
burned
developed
ASRS/ASAP reporting systems - how confidential? Tim Epstein Piloting 7 August 4th 05 05:20 PM
Airmens' Freedoms Threatened by Harsh Congressional Proposals Larry Dighera Piloting 24 July 29th 05 06:15 PM
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Aerobatics 0 May 11th 04 10:43 PM
Compiled List of Aircraft-Accessible Aviation Museums Jay Honeck Home Built 23 January 17th 04 10:07 AM
