Student practices landing with gear up
Old July 20th 06, 07:30 PM posted to rec.aviation.piloting
john smith
Default Student practices landing with gear up
"Peter R." wrote:
It is not until power is pulled almost all the way back, which in my case
typically is less than 50 feet above the runway or about a second before
touchdown.
Wow! That must be something to watch! 50 feet per second vertical rate
of descent on landing! I didn't know Bonanza gear was that stout!
Old July 20th 06, 07:31 PM posted to rec.aviation.piloting
Peter R.
snip
Some of you are so anal it makes me want to return to the bathroom for a
second wipe job to see what I am missing.
Peter
Old July 20th 06, 09:08 PM posted to rec.aviation.piloting
Morgans[_3_]
"Peter R." wrote in message
snip
LOL! Thanks, I needed that!
Comedians out of work everywhere, and some people here are still trying to
be funny! g
Old July 20th 06, 09:12 PM posted to rec.aviation.piloting
john smith
snip
And some are so anal they don't recognize a joke with a smiley! :-))
Old July 20th 06, 09:46 PM posted to rec.aviation.piloting
Matt Whiting
snip
And some write before they think giving us lots of material.
Matt
Old July 20th 06, 08:49 PM posted to rec.aviation.piloting
Newps
In my S35 the gear horn start at about 13-14 inches. Bottom of the
green is 15 inches. I reduce to 15 inches about 5 miles out. My gear
speed is 165 but I like to be around 145 or less to save wear and tear.
After putting some time on my Bo this last 11 months I am convinced
that many gear ups happen because pilots don't slow down enough in the
pattern. I have a hard time getting below 100 without putting the gear
down. I know Bonanza pilots who are deathly afraid to ever get below
100 unless their wheels are inches from the ground.
Peter R. wrote:
Peter Duniho wrote:
As for the warning horn, most retractable gear airplanes are equipped with
gear warning horns, and pilots frequently manage to ignore them
snip
With regards to my Bonanza, this horn is practically useless as it will
only sound when manifold pressure drops below 12 inches, well below the
green arc on the MP gauge (implying that for the majority of the approach
the horn would be silent).
touchdown.
Old July 20th 06, 10:05 PM posted to rec.aviation.piloting
Peter R.
down.
I, also.
We've discussed this before, but you may recall the previous owner of my
aircraft had a cow when I was flying him a few years ago and the stall
warning horn chirped as the wheels touched. He is one of those pilots who
has to land fast.
I enjoy the challenge of landing the Bo in the shortest distance possible,
so I don't have a problem crossing the fence at 60kts.
Peter
Old July 20th 06, 09:45 PM posted to rec.aviation.piloting
Jim Macklin
I think you're talking mph. In any case, being too fast
makes a proper landing difficult. 1.3 Vso is perfectly
safe. Be sure to adjust for actual landing weight.
"Newps" wrote in message
Bottom of the
out. My gear
wear and tear.
convinced
enough in the
putting the gear
ever get below
| Peter R. wrote:
are equipped with
ignore them
| snip
useless as it will
well below the
which in my case
a second before
| touchdown.
Old July 20th 06, 09:43 PM posted to rec.aviation.piloting
Matt Whiting
snip
touchdown.
You must be ex-Navy if you are touching down with a 3,000 fpm rate of
descent (50 ft x 60 s/min).
Matt
Old July 20th 06, 02:27 PM posted to rec.aviation.piloting
Paul Tomblin
In a previous article, "steve" said:
They just sent me an email stating that a student pilot from the flight
center they share it with, landed it with the gear up. How embarrassing,
especially since the plane has an automatic gear down deployment once it
drops below 100mph and the manifold and rpm resemble a landing
configuration. He/she must have shut it off. It has a loud alarm that sounds
off in that situation, so I don't know what might have happened..
Two possibilities:
- he disabled it when he was doing air work earlier OR
- he landed at 90 knots and half throttle.
You had me at
print("Hello World\n");
landing gear interface. Steve Franklin Piloting 6 September 24th 05 03:26 AM
Navy? C2/COD makes single engine, gear up landing. Dave S Piloting 20 August 20th 05 10:27 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
