Modern gliders are small and made of materials that show up poorly on
radar. Are we basically flying stealth aircraft? Johan Larson |
A misnomer... I know for a fact that our LS-4 shows up on local approach
control radar.. as does the Grob 103, and the SGS1-26 and 2-33 is a dead give away. The problem is not the glider, its the relative motion. Software in the "digital computer display" will filter out targets that appear not to be moving to get rid of "clutter" or other atmospheric anomalies.. slow to below 40knts straight line ground speed and you just may get filtered out and not displayed.. core a tight thermal.. same effect.. less that 40knts effective ground speed in a given direction and you will be filtered out and not displayed... in this case.. "beaming to the doppler notch" is a bad thing.. Military fliers will know what I mean. I listen up on the local ATC Radar frequency and have talked to them on occasions.. they have called me as traffic to other aircraft.. "traffic, 2 o'clock, 3 miles.. appears to be a glider, altitude unknown". Our local ATC radar looses coverage about 4000ft AGL and below in the valley where our glider club is. If you really want to know you are seen, invest in a transponder with ModeC and squawk 1200. BT (too many years on both sides of the radar) wrote in message oups.com... Modern gliders are small and made of materials that show up poorly on radar. Are we basically flying stealth aircraft? Johan Larson |
![]() BTIZ wrote: If you really want to know you are seen, invest in a transponder with ModeC and squawk 1200. Thanks for all the advice, but I think you mistake my intentions. I'm practicing my short-landing technique on an outline of the White House roof. ;-) Johan Larson |
That knock on your door is the NSA
![]() wrote in message ups.com... BTIZ wrote: If you really want to know you are seen, invest in a transponder with ModeC and squawk 1200. Thanks for all the advice, but I think you mistake my intentions. I'm practicing my short-landing technique on an outline of the White House roof. ;-) Johan Larson |
![]() Bob wrote: That knock on your door is the NSA ![]() Heh. Blue eyes, white skin, and a name like a viking; I must be the decoy. But seriously, folks, www.acronymfinder.com turns up some very very interesting phrases for "NSA"; but, I fear the phrase Non-surgical Spem Aspiration may have stolen my naivete forever. :-( Johan Larson |
For those Vikings out there, always remember it's, "Mayhem, Rape, Pillage,
and *then* Burn". The order in which one engages these activities being relatively important to a successful raid. Do you think Vikings used checklists? bumper "Don Johnstone" wrote in message ... At 04:06 20 July 2006, wrote: Bob wrote: That knock on your door is the NSA ![]() Heh. Blue eyes, white skin, and a name like a viking; I must be the decoy. Vikings? Hells teeth, look at the problems they caused over this side of the pond with their rape and pillage. George Dunya better watch out if those babies are on his case. :-) |
Johan
Look up Luneberg Lens via Google. We hung them on T-33 target aircraft in exercies to give a radar return the size of a B-47. You could make one out of foam and Rennels (sp) Wrap and put inside your plastic bird and get a much larger radar return for just a few ounces for the lens. These are passive devices and no power is required. Big John `````````````````````````````````````````````````` ```````````````` On 19 Jul 2006 18:25:38 -0700, wrote: Modern gliders are small and made of materials that show up poorly on radar. Are we basically flying stealth aircraft? Johan Larson |
http://www.sailorssolutions.com/inde...ails&Item=RR01
Big John wrote: Johan Look up Luneberg Lens via Google. We hung them on T-33 target aircraft in exercies to give a radar return the size of a B-47. You could make one out of foam and Rennels (sp) Wrap and put inside your plastic bird and get a much larger radar return for just a few ounces for the lens. These are passive devices and no power is required. Big John `````````````````````````````````````````````````` ```````````````` On 19 Jul 2006 18:25:38 -0700, wrote: Modern gliders are small and made of materials that show up poorly on radar. Are we basically flying stealth aircraft? Johan Larson |
Reflectivity is not the problem. We conducted experiments with Boston
control many years ago. They got good radar returns from our glass ships. The problem is the slow speed we generally fly. Usually the center's radar uses MTI (moving target indicator), which gets rid of ground clutter returns and returns from flying birds. When Boston control deactivated the MTI function, they could easily see us. Adding a lens to increase our reflectivity would not help. But if we had doppler generator built into the lens (maybe a spinning wheel propelled by air; we have lots of that available), the lens would be removed from the clutter notch. Maybe ![]() "Mike C 17" wrote in message oups.com... http://www.sailorssolutions.com/inde...ails&Item=RR01 Big John wrote: Johan Look up Luneberg Lens via Google. We hung them on T-33 target aircraft in exercies to give a radar return the size of a B-47. You could make one out of foam and Rennels (sp) Wrap and put inside your plastic bird and get a much larger radar return for just a few ounces for the lens. These are passive devices and no power is required. Big John `````````````````````````````````````````````````` ```````````````` On 19 Jul 2006 18:25:38 -0700, wrote: Modern gliders are small and made of materials that show up poorly on radar. Are we basically flying stealth aircraft? Johan Larson |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
GAO: Electronic Warfa Comprehensive Strategy Needed for Suppressing Enemy | Mike | Naval Aviation | 0 | December 27th 05 06:23 PM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Underwater Gliders | Burt Compton | Soaring | 6 | November 25th 03 04:43 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
