On Mon, 31 Jul 2006 21:54:37 -0400, Bob Martin wrote:
I do this as an alternative to a straight-in landing, especially if there is other traffic. As long as you announce what you're doing there shouldn't be a problem... unless you consider formation flight or patterns smaller than a mile on a side to be inherently dangerous. Or there are aircraft in the pattern without radios. Or aircraft in the pattern tuned to the wrong frequency. Or IFR aircraft flying an approach contrary to the current traffic flow and listening to Center....as often happens at the field Peter was talking about. "The rules and codes and zones they form Are not for such as I, Who like the great wild eagles fling My challenge to the sky, A bold free spirit charging fierce Across the fallow land ... And don't you like these nice white flowers I'm holding in my hand?" -Gil Robb Wilson, "The Last Bouquet" Ron Wanttaja |
"Bob Martin" wrote in message
... How is an overhead break a "stupid pilot trick?" The people I've seen do it around here start with a high-speed, relatively low pass (though not 10 feet off the deck...more like 200-500') and then enter the proper traffic pattern with a climbing turn directly into the downwind. I realize that there are practical issues that are addressed by flying an abbreviated pattern starting with an over-the-runway upwind. However, even doing that starting at pattern altitude is not appropriate at a busy public airport, and when executed as a chandelle it's even more inappropriate (and dangerous). As far as using the maneuver as "an alternative to a straight-in", I fail to see how it would be better than a straight-in, especially if there is other traffic. You spend more time in the pattern than you would with a straight-in, and you do at least part of it in a location where the other pilots in the pattern are less likely to be expecting you. As far as "As long as you announce what you're doing there shouldn't be a problem" goes, that's the classic "everyone has a radio" fallacy. The radio is NOT a replacement for good traffic pattern usage. Pete |
"Peter Duniho" wrote: "Bob Martin" wrote in message ... How is an overhead break a "stupid pilot trick?" The people I've seen do it around here start with a high-speed, relatively low pass (though not 10 feet off the deck...more like 200-500') and then enter the proper traffic pattern with a climbing turn directly into the downwind. I realize that there are practical issues that are addressed by flying an abbreviated pattern starting with an over-the-runway upwind. However, even doing that starting at pattern altitude is not appropriate at a busy public airport, and when executed as a chandelle it's even more inappropriate (and dangerous). As far as using the maneuver as "an alternative to a straight-in", I fail to see how it would be better than a straight-in, especially if there is other traffic. You spend more time in the pattern than you would with a straight-in, and you do at least part of it in a location where the other pilots in the pattern are less likely to be expecting you. As far as "As long as you announce what you're doing there shouldn't be a problem" goes, that's the classic "everyone has a radio" fallacy. The radio is NOT a replacement for good traffic pattern usage. Pete The overhead is a *HELL* of a lot better than the straight in! It gives you a view of traffic in the pattern, keeps you in close, gets you to the downwind and gets a whole flight on the ground in the time it takes to get one plane on the ground. My pet peeve is those who fly wide, extended patterns, pretending that they are in a 747, while flying a Cessna 172. Big flight schools are, IMHO, the biggest offenders, teaching a "stabilized" approach and dragging it in for three miles. This type of instruction may even be a factor in the loss of the Europa at Oshkosh, where the tower wants you to keep it in close, when the pilots may not have been taught to do so. |
"Orval Fairbairn" wrote in message
news ![]() The overhead is a *HELL* of a lot better than the straight in! If so, you probably ought to include information in post supporting that position, rather than the statements you did make. It gives you a view of traffic in the pattern In VFR conditions, you can see the whole traffic pattern from final. Secondly, if you're flying a straight-in, most of the traffic pattern is moot, especially the upwind and the crosswind. keeps you in close Closer than a straight-in? Given that the overhead break necessarily includes flight over the same ground that the straight-in requires, plus some more, in what way is this increased time spent aloft better than a straight-in? And what could be more "in close" than being ON the runway, rather than flying overhead making your turn to downwind? gets you to the downwind Flying straight-in, there's no need to even get to the downwind. and gets a whole flight on the ground in the time it takes to get one plane on the ground. Firstly, the situations I'm talking about are solo planes, not formations. Secondly, if a particular approach is faster solo, it's faster with a formation. A formation that can fly all the way to landing (the only way to actually "get a whole flight on the ground in the time it takes to get one plane on the ground") can do so using any type of approach, and if the formation has to split up during the overhead break and enter the pattern as individual airplanes, then they are occupying just as much of the pattern as they would had they split up somewhere else (and you certainly are not getting the whole flight on the ground in the time it takes to get one plane on the ground). There may indeed be certain types of operations and airplanes for which an overhead break may be a superior choice but a) you can't generalize those specific situations to the maneuver overall, and b) pilots need to recognize that their own operational preferences cannot take priority over general airport traffic safety. Pete |
On Tue, 01 Aug 2006 20:51:25 GMT, Orval Fairbairn
wrote: In article , "Peter Duniho" wrote: "Bob Martin" wrote in message ... How is an overhead break a "stupid pilot trick?" The people I've seen do it around here start with a high-speed, relatively low pass (though not 10 feet off the deck...more like 200-500') and then enter the proper traffic pattern with a climbing turn directly into the downwind. I realize that there are practical issues that are addressed by flying an abbreviated pattern starting with an over-the-runway upwind. However, even doing that starting at pattern altitude is not appropriate at a busy public airport, and when executed as a chandelle it's even more inappropriate (and dangerous). As far as using the maneuver as "an alternative to a straight-in", I fail to see how it would be better than a straight-in, especially if there is other traffic. You spend more time in the pattern than you would with a straight-in, and you do at least part of it in a location where the other pilots in the pattern are less likely to be expecting you. As far as "As long as you announce what you're doing there shouldn't be a problem" goes, that's the classic "everyone has a radio" fallacy. The radio is NOT a replacement for good traffic pattern usage. Pete The overhead is a *HELL* of a lot better than the straight in! It gives you a view of traffic in the pattern, keeps you in close, gets you to the downwind and gets a whole flight on the ground in the time it takes to get one plane on the ground. My pet peeve is those who fly wide, extended patterns, pretending that they are in a 747, while flying a Cessna 172. Big flight schools are, IMHO, the biggest offenders, teaching a "stabilized" approach and dragging it in for three miles. This type of instruction may even be a factor in the loss of the Europa at Oshkosh, where the tower wants you to keep it in close, when the pilots may not have been taught to do so. I understand that the midfield crosswind entry is standard in Canada. It's also one of the standard entries at my (controlled) home field[1]. From that experience, I find I like it because it gives me good situational awareness of what's going on with closed traffic, 45-degree entries, and base-leg entries. Any Canadians want to chime in on what they teach you north of the 49th? Don [1] San Carlos, CA. Down the road at Palo Alto, they use left and right patterns for a single runway. I do NOT care for that. I'm anxious about where the guy in the other pattern is turning base. San Carlos doesn't do that because there is a lot of helicopter activity and the helos are segregated on one side of the field and land on the apron while fixed-wing craft use the other side and land on the runway. |
Bob Martin wrote:
Peter Duniho wrote: "RST Engineering" wrote in message ... [...] Warbirds, you are not welcome at Oshkosh. We've all got our pet peeves when it comes to other pilots. Around here, where we don't see warbirds on a regular basis during daily flying, it's the RV "squadron" who do high-speed, low passes down Lake Sammamish, or the Mustang replica pilot who does his "overhead break" to a landing at the airport, or any number of other pilots doing stupid pilot tricks. How is an overhead break a "stupid pilot trick?" Just FYI: For those still learning about piloting (like myself) who like to see illustrations of these things, or those who would like to read a summary of the origin and history of the "overhead break," this site seems to be handy: http://www.virtualtigers.com/htm/obreak.htm |
![]() "Jim Logajan" wrote in message .. . Just FYI: For those still learning about piloting (like myself) who like to see illustrations of these things, or those who would like to read a summary of the origin and history of the "overhead break," this site seems to be handy: http://www.virtualtigers.com/htm/obreak.htm THANKS, JIM! -c |
Jim,
Most of the warbirds are classed as Experimental. By definition, they are "our own" as much as the squadrons of glass-cockpit RVs and Lancairs and the increasingly-rare builder-designed or even plans-built birds. Aviation - especially Experimental aviation, VERY especially high-density Experimental aviation - is a high-risk endeavor. Situational awareness is never perfect. Accidents DO happen. A good many T-6 drivers may be hot-doggers. The waddling TBM doesn't lend itself to that sort of attitude, though. Having seen TBMs and RVs up close, though, I can understand how it might be hard to see an RV from a TBM - especially if it was close-aboard. To the under-30 crowd who "can't relate" to WW2 aircraft, I respectfully submit the observation that if not for those aircraft - and the men and women (now in their 80s if they're alive at all) who built, maintained, and flew them - you would almost certainly not be reading this post today. Totalitarian states do not permit experimental aviation. Those "ancient clattertraps" serve to remind us that freedom such as we enjoy is not - has never been, will never be - free. -Corrie RST Engineering wrote: So this afternoon, one of the WWII warbird people who has more money than good sense, and who never learned how to clear the taxiway in front of his aircraft, killed one of our own. There has to be some sort of payback for this sort of stupidity. Warbirds, you are not welcome at Oshkosh. Jim |
Jim,
Don't get me wrong, I certainly appreciate them and the sacrifices of those who operated them. The vaccuum tube computer was an important invention in history too and should be preserved. However, it would be a mere passing curiosity at today's Consumer Electornics Show for instance. It's not that they are not important, but that for me _personally_ they do not hold my interest. They apparently interest plenty of other people and that's fine.... I'll go look at the Cirrus and Eclipse exhibits during that part of the airshow! --Dan CB wrote: Jim, Most of the warbirds are classed as Experimental. By definition, they are "our own" as much as the squadrons of glass-cockpit RVs and Lancairs and the increasingly-rare builder-designed or even plans-built birds. Aviation - especially Experimental aviation, VERY especially high-density Experimental aviation - is a high-risk endeavor. Situational awareness is never perfect. Accidents DO happen. A good many T-6 drivers may be hot-doggers. The waddling TBM doesn't lend itself to that sort of attitude, though. Having seen TBMs and RVs up close, though, I can understand how it might be hard to see an RV from a TBM - especially if it was close-aboard. To the under-30 crowd who "can't relate" to WW2 aircraft, I respectfully submit the observation that if not for those aircraft - and the men and women (now in their 80s if they're alive at all) who built, maintained, and flew them - you would almost certainly not be reading this post today. Totalitarian states do not permit experimental aviation. Those "ancient clattertraps" serve to remind us that freedom such as we enjoy is not - has never been, will never be - free. -Corrie RST Engineering wrote: So this afternoon, one of the WWII warbird people who has more money than good sense, and who never learned how to clear the taxiway in front of his aircraft, killed one of our own. There has to be some sort of payback for this sort of stupidity. Warbirds, you are not welcome at Oshkosh. Jim |
Totalitarian states do not permit experimental aviation. Not true. The German Nazi regime of the 1930s loved experimental aviation (and experimental rocketry), they even gave financial support. A lot of the amateur designers and pilots then went on to play a big part in the Second World War. The contemporary British government tried everything it could to stop amateurs getting into the air. As a result, surviving the Battle of Britain (1940) was as much a matter of luck as judgment. Later on we had to put up with bombs mysteriously falling out of the sky (the V2 long range rocket). If the war in Europe had gone on much longer the first man in space would have been a German piloting a two-stage missile to New York. BTW this difference in attitude between British and German governments continues to this day. This explains why German radio hams are putting together a Mars lander, and we can't fly a suitably-equipped Lancair in IFR. |
Get Rid Of Warbirds At Oshkosh | RST Engineering | Piloting | 131 | August 11th 06 06:00 AM |
Oshkosh Reflections | Jay Honeck | Owning | 44 | August 7th 05 02:31 PM |
Oshkosh Reflections | Jay Honeck | Piloting | 45 | August 7th 05 02:31 PM |
Oshkosh EAA Warbirds ??? | Paul | Restoration | 0 | July 11th 04 04:17 AM |
How I got to Oshkosh (long) | Doug | Owning | 2 | August 18th 03 12:05 AM |
