Spoken like a true idiot that never looked at Home Depot lumber.
![]() David Melby Cavalier wrote: ... If Fred plans to build a plane from wood purchased from Home Depot, he should also build a pine box. He will need it. I have never found wood acceptable for aircraft at HD or any other such outlet. Why pass on such bad information? Have you ever looked at the FAS Doug Fir they stock next to the hardwoods? -- FF |
![]() Jim Carriere wrote: wrote: ... Personally I've seen some very knot-free and fine grain birch and fir at the local Lowe's. Of course, there is also plenty "doghouse grade" wood. Lowe's is fifteen minutes closer to me than HD ![]() Other than plywood I've never seen birch in one of the Borgs after visitng more than a score of them in four states. Selection is highly variable, even within the same company in the same region. If you don't like what you see in one, go to another. -- FF |
![]() If Fred plans to build a plane from wood purchased from Home Depot, he should also build a pine box. He will need it. I have never found wood acceptable for aircraft at HD or any other such outlet. Why pass on such bad information? Must disagree with this. You should look a little harder. I have many board feet of really tight grained, vertical sawn, dry, straight hemlock (not hemfir, a fast growing commercial mutant wood) found right in the trim/banister section of our local Sutherlands. Our independant lumber outlet occasionally has 8/4 shop doug fir that also meets AC standards for all criteria. I know of a couple of Piets built long ago with white pine ribs with hardware store flashing leading edges. Years ago, I heard one of the FAA guys give a lecture about final inspections and the use of AC grade materials. At that time he made a comment that homebuilders were the ones that certified the materials and that as far as they were concerned you could use wet cardboard and shaving cream to build your plane. As long as you could back up your material choice with a least some data anything went. However, he did mention that they could also restrict you to 200+ hours ground (taxi) testing prior to flight. Even Rutan ignored the AC quality thing on the first Vari-eze since there wasn't ( and may still not be) anything such as AC certified foam. |
![]() gorgon wrote: If Fred plans to build a plane from wood purchased from Home Depot, he should also build a pine box. He will need it. I have never found wood acceptable for aircraft at HD or any other such outlet. Why pass on such bad information? Must disagree with this. You should look a little harder. I have many board feet of really tight grained, vertical sawn, dry, straight hemlock (not hemfir, a fast growing commercial mutant wood) found right in the trim/banister section of our local Sutherlands. ... Splorf! It sounds like you got your species information from a clerk at the Home Depot. The last ime I asked one iif their Hem-FIr was Helock or Fir he said it was probably a hybrid! Hem-Fir is a softwood lumber association _species group_, like SPF, only one level higher up in quality. Hem-Fir may be Western hemlock or any of several Firs, it won't be any species of pine, larch, Doug Fir, or spruce and the minimum tensile strength requirement for that group is higher than for SPF, but lower than for Southern Yellow pine, or Doug Fir. It may be fast grown or not, but it isn't a hybrid or a mutant any more than SPF (Spruce, Pine or Fir) is a mutant or hybrid wood. Most Douglas Fir and Southern Yellow Pine sold by the Borgs IS fast grown and bears little resemblence to old-growth despite being the named genus, or group of species. -- FF |
![]() Even Rutan ignored the AC quality thing on the first Vari-eze since there wasn't ( and may still not be) anything such as AC certified foam. The Rutans ignored a great deal of "proven" practice in their homebuilt designs yet after they proved unable to make a direct drive pusher VW work in the prototype VariEze (which others had, having less theoretical knowledge but much more common sense than Burt and Dick) decided only certified aircraft engines were any good. Then they freely instructed builders to not only ignore but defy manufacturer's instructions, such as not operating the O-200A as a pusher. In other words they are talking out their mouth and ass simultaneously. When one or the other Rutan does buy it, I won't cheer, but I'm not going to get lachrymose either. Honebuilders don't have the sense to figure out Rutan F'ed them and kicked them out before dawn like an acne-ridden fat broad picked up at a bar. |
Nice article Veeduber, I doubt I'll ever build from wood, or from scratch
for that matter but I enjoyed the read. Thanks. |
"Dave" wrote in message
... Nice article Veeduber, I doubt I'll ever build from wood, or from scratch for that matter but I enjoyed the read. Thanks. That's really my feeling as well. Peter |
Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 04:05 AM |
Wanted: VFR Safety Pilot near Milwaukee, WI - Cheap flying for you | Paul Folbrecht | Instrument Flight Rules | 9 | September 16th 04 03:25 AM |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING | The Ink Company | Aviation Marketplace | 0 | November 5th 03 12:07 AM |
the thrill of flying interview is here! | Dudley Henriques | Piloting | 0 | October 21st 03 07:41 PM |
