#21
![]() "Javier Henderson" wrote in message ... "C J Campbell" writes: a) The TBO on the Cirrus engine is 2000 hours. b) The airframe lifetime on the Cirrus is now 12,000 hours. Not true, the SR-22 still is 4350 hours until you can show me a type certificate that says otherwise. If the airframe life limit has been extended then Cirrus is sure keeping quiet about it. So, where does that leave your crusade against Cirrus? Right where I started. I didn't like the plane when I thought the TBO was 2000 hours. -jav (Skylane owner, trying to offer a balanced view) A balanced view does not ignore the facts. |
![]() "Javier Henderson" wrote in message ... "Tom Sixkiller" writes: http:\\http://www.airplanenoise.com/article....%20Cirrus.pdf Biased as hell, but some good statistical comparisons. Some of those comparisons are based on flawed data (airframe life, engine TBO). Actually, those are OLD data (as in "revised" since publication), not "flawed " data. You really should work for the DNC :~) |
![]() "Javier Henderson" wrote in message ... "Tom Sixkiller" writes: http:\\http://www.airplanenoise.com/article....%20Cirrus.pdf Biased as hell, but some good statistical comparisons. Some of those comparisons are based on flawed data (airframe life, engine TBO). Actually, the data are not flawed. Let's see you come up with something that proves it wrong. |
Just a few corrections:
Max. cruise is 165 at 20000 ft. and 88% power. Range WITH 45 miuntes reserve is 635 nm (88% power) to 970 nm (45% power). Gerd ATP, T182T |
"Javier Henderson" wrote in message ... "Tom Sixkiller" writes: "Javier Henderson" wrote in message ... a) The TBO on the Cirrus engine is 2000 hours. Nope...CJ was right, it's 1700 hours (TCM IO-550...normally aspirated). No, CJ is wrong, the IO-550 in the SR22 has a 2000 hour TBO. http://www.tcmlink.com/producthighlights/ENGTBL.PDF The IO-550N is on the second page, sixth line from the bottom. Again, I don't own an SR22 (actually, I own a Skylane) but stating inaccurate data to make a point is not right. Are you implying a lie (ala Joe Wilson) or the fact that they have one model of 550 that has a 2000 hr TBO vs. all their other models with 1700? Oh, good grief. I'm saying that the engine in the SR22, which is the IO-550N, has a TBO of 2000 hours. -jav |
"Javier Henderson" wrote in message ... "Tom Sixkiller" writes: http:\\http://www.airplanenoise.com/article....%20Cirrus.pdf Biased as hell, but some good statistical comparisons. Some of those comparisons are based on flawed data (airframe life, engine TBO). Actually, those are OLD data (as in "revised" since publication), not "flawed " data. You really should work for the DNC :~) Whatever. "Inaccurate information for the purposes of comparing current revisions of the products under consideration". Happy now? You know, we as pilots sure do a **** poor job in promoting evolution. We whine and complain about how it's all old stuff because the FAA gets in the way of everything, but when a new design comes along, we sure are ready to bash it to pieces. -jav |
"Javier Henderson" wrote in message ... "Tom Sixkiller" writes: http:\\http://www.airplanenoise.com/article....%20Cirrus.pdf Biased as hell, but some good statistical comparisons. Some of those comparisons are based on flawed data (airframe life, engine TBO). Actually, the data are not flawed. Let's see you come up with something that proves it wrong. I did post the link to TCM's datasheet on the engine, stating a TBO of 2000 hours. The lifetime of the airframe was recently lifted to 12,000 hours. Now what? -jav |
A balanced view does not ignore the facts. You are ignoring facts, however. You may also have the last word, clearly one can't reasonably discuss this topic with you. -jav |
#29
Javier Henderson wrote:
"C J Campbell" writes: "Javier Henderson" wrote in message ... "Tom Sixkiller" writes: http:\\http://www.airplanenoise.com/article....%20Cirrus.pdf Biased as hell, but some good statistical comparisons. Some of those comparisons are based on flawed data (airframe life, engine TBO). Actually, the data are not flawed. Let's see you come up with something that proves it wrong. I did post the link to TCM's datasheet on the engine, stating a TBO of 2000 hours. The lifetime of the airframe was recently lifted to 12,000 hours. I'd think this would be something Cirrus would be happy to announce. So I'm surprised their Aircraft/FAQ page still says "The SR22 airframe was initially certified for 4,350 using data derived from the SR20 test. Cirrus is nearing completion of the same structural tests used to extend limits of the SR20 and anticipates that the SR22 will soon be rated for the 12,000-hour life." |
#30
C J Campbell wrote:
Even if it was not, you are still faced with a fatal accident rate per 100,000 hours 10 times that of average, Put the average PPL into a Boeing 737, and I bet the accident rate will be even higher. So the 737 is an inherently unsafe plane? Statistics offers the numbers, but they must be interpreted. Stefan |
FS: Cessna 140 wheel pants aluminum | Mark T. | Home Built | 0 | September 9th 04 12:19 AM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 05:40 PM |
Cessna buyers in So. Cal. beware ! | Bill Berle | Home Built | 73 | June 25th 04 04:53 AM |
Cessna Steel Landing Gears, J-3 Seat Sling For Auction | Bill Berle | Home Built | 0 | February 19th 04 06:51 PM |
Cessna wheela and axles | clare @ snyder.on .ca | Home Built | 2 | January 10th 04 04:52 PM |
