Reliability and Clubs...
Old August 27th 06, 04:27 PM posted to rec.aviation.piloting
john smith
Default Reliability and Clubs...
Larry Dighera wrote:
Right. But Jay is the sole owner of his PA28. He pays more per hour
of operation, and enjoys increased utility for increased cost.
He also deducts a percentage of his ownership/operating costs as
business deductions on his income taxes.
Old August 23rd 06, 05:09 PM posted to rec.aviation.piloting
Tom Conner
"Jay Honeck" wrote in message
As for buying, I can heartily recommend it. Knowing who
flew the plane last, and having everything in the plane
PRECISELY the way you left it (and always leave it) is worth
all the headaches, IMHO.
It helps if you can write some of the expense off on taxes as a business
expense. How many of your trips do you claim as business, and how many are
just personal?
Old August 23rd 06, 04:12 PM posted to rec.aviation.piloting
Gene Seibel
Never perfect. Expect issues at annuals the first few years after
changing airplanes and after changing mechanics. In between, small
problems will arise, sometimes in clusters. I begin to wonder what's
wrong when months have gone by and there haven't been any little
annoyances.
Gene Seibel
Gene & Sue's Aeroplanes - http://pad39a.com/gene/planes.html
Because we fly, we envy no one.
I've been renting from the local flying club.
In the last five flights I've had 4 issues /maintance problems.
1Pilots PTT switch fails on 3 hour cross country, hand mic inop.
Finished flight using copilots mic jack and PTT.
2)Alternator charge indicator fails. maintance ended up replacing the
alternator.
3)Found cracked cowl on 172 , the fiberglass cowl ring just behind
the spinner was cracked 3/4 of the way around and about to come loose.
4)Took off in 172 to finish my IPC tonight and at 700 feet just off
the end of the runway the engine lost power for the longest 5 seconds
of my life. Returned to the field did a hard runup all normal.
After parking the plane I drained several cups of gas from both wing
tanks and the gas sump under the engine.
No dirt, no water the fuel is perfect.
The Fuel seector was on both and in place.
The primer was locked. (first thing I checked)
Am I just having a run of bad luck, or is this normal for older (mid
70's well used airplanes. All of this really makes me want to buy my
own plane,
I fear that I will be jumping out of the frying pan into the fire.
How long does take to get the bugs and issues worked out of an
older plane once purchased...
a)Never,
b)Its always perfect
c)Somewhere in between?
Lastly in a case of an issue like #4 what do you do if the mechanic
doesn't find anything?
Single-Engine Partnership vs. Used vs. Flying Clubs [email protected] Owning 16 January 14th 06 06:56 AM
