primary flight instruments on partial panel
Old August 24th 06, 06:54 PM posted to rec.aviation.ifr
Greg[_1_]
Default primary flight instruments on partial panel
In primary and supporting method of attitude instrument flying, which
do you consider the primary instrument for bank in the partial panel
situation (loss of both attitude indicator and heading indicator)?
Turn coordinator or magnetic compass?
thank you
Greg
greggordon.org/flying
Old August 24th 06, 07:27 PM posted to rec.aviation.ifr
Jim Macklin
You would use the TC or TB to control bank angle, it is the
instrument that you control, therefore primary. You monitor
the compass to fly a heading which is the desired result.
Using the compass as a control instrument generally requires
a south heading so that the compass turning error is in the
correct direction.
James H. Macklin
ATP,CFI,A&P
"Greg" wrote in message
flying, which
partial panel
indicator)?
| thank you
| Greg
Old August 24th 06, 08:22 PM posted to rec.aviation.ifr
Roy Smith
The magnetic compass isn't worth **** in a turn. It should only be
used as a heading reference in straight-and-level flight.
If you've got a good ADF you can tune in an AM broadcast station and
that makes a dandy DG replacement. Pick a station that's far enough
away that azimuth to the station is approximately constant but close
enough that you get a good strong signal. Not that most planes have
ADFs these days, and the ones that do exist tend to be pretty cruddy.
With practice, you can fly a decent ILS with just a TC, ASI, and CDI.
No AI, no DG, not even a wet compass.
Old August 24th 06, 09:34 PM posted to rec.aviation.ifr
Robert M. Gary
Actually compass turns are taught of all instrument pilots. An
instrument pilot should be able to tell you what the compass will
indicate in a turn and be able to turn to exact headings using just the
compass. For most places in the U.S. the correction is +30/-30. See
page 5-25 of the FAA's "Instrument Flying Handbook"
http://www.faa.gov/library/manuals/a...-8083-15-1.pdf
"...For example, when turning from an easterly direction to north,
where the latitude is 30°, start the roll-out when the compass
reads 37° (30° plus one-half the 15° angle of bank, or
whatever amount is appropriate for your rate of roll-out).
When turning from an easterly direction to south, start the
roll-out when the magnetic compass reads 203° (180° plus
30° minus one-half the angle of bank). When making similar
turns from a westerly direction, the appropriate points at
which to begin your roll-out would be 323° for a turn to
north, and 157° for a turn to south...."
-Robert, CFII
Old August 25th 06, 12:29 AM posted to rec.aviation.ifr
Bob Gardner
If I had my druthers, compass turns would be eliminated from training and
timed turns used instead. The PTS does not require compass turns, but most
CFII's teach them anyway. I'll bet my life on a timed turn, but not on a
compass turn.
Whenever this question arises I postulate this scenario: It is a dark and
stormy night, ice is beginning to become apparent, the wife's knuckles are
white and the kids are crying. The heading indicator craps out and the mag
compass looks like a washing machine. What a fine time to be determining
leads and lags and remembering rules.
Bob Gardner
-Robert, CFII
Old August 25th 06, 12:32 AM posted to rec.aviation.ifr
Robert M. Gary
compass turn.
Funny, I think compass turns are much easier under stressful
situations. Having to start and stop the clock and compute the time
necessary for the turn while holding an exact standard rate turn would
be hard. Of course, in most situations, turning within 1degree is not
required.
-Robert
Old August 25th 06, 12:39 AM posted to rec.aviation.ifr
Jose[_1_]
I disagree. A quick calculation tells me where the second hand should
be when I'm done. I roll out, then make little corrections as needed.
Jose
The monkey turns the crank and thinks he's making the music.
Old August 25th 06, 04:53 AM posted to rec.aviation.ifr
Andrew Sarangan[_1_]
I don't like purely timed turns because I rarely get them to work
accurately. It takes time to bank into the turn and bank out and any
inaccuracies in holding a standard rate turn you can be off by 20 or 30
degrees. Using compass turns, even if don't compensate for banking
errors you will only be off by 30 degrees. What I teach is to make
large turns using the compass turns (with or without banking errors),
and then make fine adjustments. In a sense this is a combination of
compass turns and timed turns, except you don't start and stop a clock.
You time the fine adjustments in your head.
compass turn.
Bob Gardner
-Robert, CFII
Old September 1st 06, 04:18 AM posted to rec.aviation.ifr
Allan9
Years ago a FSDO/GADO Inspector pulled that one on me on a instrument flight
check.
Al
Old August 25th 06, 12:05 PM posted to rec.aviation.ifr
David Cartwright
The turn co-ordinator is your primary measure of bank, for a couple of
reasons. First, the compass doesn't measure bank angle - it just shows what
direction you're pointing in - whereas the TC does show the degree to which
you're banked. Second, and most importantly, because of the way it's put
together, the compass doesn't turn steadily, and so it'd be wrong to fool
yourself into thinking that the faster the compass was moving, the more
you're banked.
Have a go one day and you'll see. Take someone competent with you to look
out of the window, get to a safe place and height, make sure your DI's set
correctly, and do a rate-one turn through 720 degrees or more (go around as
much as you like, in fact). In the northern hemisphere at least, you'll note
that when the DI goes through 090 or 270, the compass stands a fair chance
of agreeing with the DI. As you go through north, though, the compass will
under-read, and as you go through south, it'll over-read. The only time you
can rely on the compass is when going in a straight line - which is why you
always check and adjust your DI when flying in a straight line.
Hence if you want to do a partial-panel turn in IMC, you fly straight and
check the compass, then do a rate-one turn (the turn co-ordinator shows you
the bank angle) for the required number of seconds - three degrees per
second for a rate-one turn, of course. You then level out, give the compass
a few seconds to stop wiggling, and then adjust your heading if you're a
little bit out. I seem to recall in the IMC rating test you have to get to
within five or ten degrees of the desired heading with one initial turn and
one "fine tune" adjustment - which is generally pretty achievable.
David C
Stupid Question Crash Lander Piloting 35 July 23rd 06 02:39 AM
CRS: V-22 Osprey Tilt-Rotor Aircraft Mike Naval Aviation 0 October 14th 05 08:14 PM
