Crashing on takeoff... how odd
Old August 27th 06, 08:21 PM posted to rec.aviation.piloting
Ronald Gardner
Default Crashing on takeoff... how odd
Well looks like a terrible mistake if he took off on 26 instead of 22:
CRJ200 ER
FAR take-off field length (SL, ISA) at MTOW 5,800 ft 1,768 m
FAR 121 landing field length (SL) at MLW 4,850 ft 1,479 m
CRJ200 LR
FAR take-off field length (SL, ISA) at MTOW 6,290 ft 1,918 m
FAR landing field length (SL) at MLW 4,850 ft 1,479 m
These came from the factory website, looks like he needed allot more runway.
Ronald Gardner wrote:
Correct, but the video's show the skid starts about 1/2 mile off a 3500 ft
runway. I suspect a full loaded CRJ needs a bit more than that for a safe
take off. They also have now stated he was cleared for 22 a 7500 ft
runway. But as you state this is all speculation at this point.
john smith wrote:
Early reports indicate that the plane tookoff (or failed to takeoff as
the case may be) on the wrong runway,a runway that was too short.
Only a fools and idiots speculate on the cause of an airplane crash
before the facts are known.
Old August 27th 06, 08:23 PM posted to rec.aviation.piloting
Newps
John Gaquin wrote:
Is there anyone here who actually knows? Is 3500 ft adequate for a fairly
well loaded 202?
No, not in a million years.
Old August 27th 06, 08:24 PM posted to rec.aviation.piloting
John Gaquin
Pardon my ignorance but what do you mean "Is 3500' adequate"? Doesn't
the PIC, as part of the pre-flight routine, estimate the maximum load
The answer to your question is yes, in a simple sense. Whether done by
computer in the dispatch office, or by hand in the cockpit, the calculation
has to be done. With transport aircraft, data is usually available to the
crew to come at the problem from 2 different directions.
1) we know the aircraft weight and the ancillary conditions. How much
runway is required to take off? This is the usual method, since large
aircraft usually operate at airports with multiple, long runways. Thus, it
is just a matter of selecting which runways are acceptable.
2) We know how much runway is available, so how much weight can we carry
under the existing conditions? In large transports, this method would
apply at airports with only one available runway, or perhaps several runways
that are all rather short, such as LGA, MDW, OR DCA.
So, my question addresses method 1, asking if 3500 ft is adequate runway
length for a fairly heavy RJ under normal conditions.
JG
Old August 27th 06, 08:26 PM posted to rec.aviation.piloting
Newps
Larry Dighera wrote:
I once witnessed a Cessna C-172 crash on takeoff at Santa Monica
Airport (KSMO) in the early '70s. The aircraft rotated, and rocketed
skyward at a very high angle, stalled, and nosed into the runway. The
pilot escaped with a broken finger. The cause was a result of the
trim being set wrong. Don't forget your check list.
Full nose up trim is immediately apparent on the application of power.
The fact that he let it get away from him says it all. It doesn't take
a lot of forward stick after takeoff to put the nose where it needs to be.
Old August 27th 06, 08:29 PM posted to rec.aviation.piloting
Steven P. McNicoll[_1_]
"John Gaquin" wrote in message
It is apparently clear the plane was cleared to use one runway but used
the other. The early reports speculated thaat the runway used MAY have
been too short, but did not state so unequivocally.
well loaded 202? It sounds short to me, but I have no data available, no
facts upon which to base a conclusion.
I can't say whether 3500' is sufficient or not but I suspect it is not. But
even if the book said it could be done, if the crew believed the runway they
were using was considerably longer than 3500' they'd probably be in the
weeds at the far end.
Old August 27th 06, 08:42 PM posted to rec.aviation.piloting
Greg Farris
In article .com,
says...
of the airplane given the runway length and other factors (water on the
tarmac, obstruction just beyond the runway, etc.), with assistance from
the flight dispatcher?
I believe "incomprehension" would better qualify your error than "ignorance".
All of the methodology you mention is moot if the crew did not realize they
were on the wrong runway.
"Is 3500 adequate" is a perfectly valid question, as it helps to understand
whether there is any realistic probability that the crew would knowingly and
deliberately attempt taleoff from such a short runway.
I am not a CRJ pilot, and have not bothered to look it up, but I would be
astounded to learn that this is a plausible runway length for this aircraft.
Should this belief be upheld, as well as the fact that the plane did indeed
attempt takeoff from such a runway, it brings us very close to proving that
the crew made a mistake in taxying to the runway, and unwittingly found
themselves on a runway far too short. Thus the question you challenge actually
brings us a long way toward an understanding (to be confirmed and proven) of
the accident.
GF
  #29
Old August 27th 06, 08:44 PM posted to rec.aviation.piloting
Larry Dighera
On Sun, 27 Aug 2006 12:26:00 -0600, Newps wrote
in :
Mmmm, that sounds like the voice of experience.
Wouldn't the aircraft have to reach some speed on the takeoff roll
subsequent to the application of power before the control force would
be apparent on the yoke? Or are you referring to another indication?
That and the apparent lack of use of a checklist. I have no idea of
the pilot's qualifications nor experience.
It doesn't take a lot of forward stick after takeoff to put the nose
I would think it is possible with some effort. What would be your
estimate of the required effort in pounds of push on the yoke to
overcome full up trim in a C-172?
UAV's and TFR's along the Mexico boarder John Doe Piloting 145 March 31st 06 07:58 PM
Approaches and takeoff mins. jamin3508 Instrument Flight Rules 22 September 14th 05 03:51 AM
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 01:18 PM
Overweight takeoff / flight Koopas Ly Piloting 50 December 4th 03 12:53 AM
