Ramy wrote:
Derek, I am not advocating mode S transponder (which I couldn't efford one either ), it is doing nothing to improve safety then mode C,which should cost around 2K in the US, no more then a flight computer. Double that figure, and you'll have a more typical installed cost in the US, particularly in a type certified glider. A transponder installation is a different kettle of fish from a glide computer, a 337 is often required... |
![]() Ramy wrote: Meanwhile, at least in the US, our only option is the 30 years old technology of transponders, which are relatively effordable for most pilots I see flying at the Reno area. Ramy, what if the collision had been between an older Learjet, not equipped with TCAS, and not talking to ATC (in the process of being handed off, talking to FSS, or just tooling around VFR. Transponders would be totally useless in preventing the midair. Remember, unless equipped with TCAS (big jets) or an IFF interrogator (many military fighters), or talking to the controlling agency that is actually watching you and your transponder, it's not going to do any good. It is absolutely no good at preventing VFR - VFR midairs. TPAS is a good solution, since it warns you of someone else tooling around with his xponder on. ADS-B would be nice, if affordable/practicable in a glider. FLARM is pretty much only glider-to-glider, and requires active participation (and is a moot point in the US anyway, at present). If I was going to get up in the flight levels with my glider (no thanks, I happen to like my old gelcoat, thankyou!) I would seriously consider a transponder. Also an attitude indicator!. Down lower, if traffic is an issue, then I'm leaning towards some kind of TPAS - like device. I'm waiting for one with a good aural cue (I think there is one out now). Any comments from current TPAS users out there? Kirk 66 |
Kirk, I happen to be also a TPAS user. I am using the Monroy, which
gives you warning for nearby transponder equipped aircraft. All it does actually is alerting you to scan for traffic when there is traffic nearby. It doesn't tell you where it is though, but for $500 I think it worth it. There is now a better unit offered on Wings and Wheels http://www.wingsandwheels.com/page4.htm Installation is not much of an issue, since those units are so small you can stick them to the glare shield as I do. Just make sure to buy one with voice alerts as you noted, as you would not notice the leds during day time when your eyes are focused outside. Ramy kirk.stant wrote: Ramy wrote: Meanwhile, at least in the US, our only option is the 30 years old technology of transponders, which are relatively effordable for most pilots I see flying at the Reno area. Ramy, what if the collision had been between an older Learjet, not equipped with TCAS, and not talking to ATC (in the process of being handed off, talking to FSS, or just tooling around VFR. Transponders would be totally useless in preventing the midair. Remember, unless equipped with TCAS (big jets) or an IFF interrogator (many military fighters), or talking to the controlling agency that is actually watching you and your transponder, it's not going to do any good. It is absolutely no good at preventing VFR - VFR midairs. TPAS is a good solution, since it warns you of someone else tooling around with his xponder on. ADS-B would be nice, if affordable/practicable in a glider. FLARM is pretty much only glider-to-glider, and requires active participation (and is a moot point in the US anyway, at present). If I was going to get up in the flight levels with my glider (no thanks, I happen to like my old gelcoat, thankyou!) I would seriously consider a transponder. Also an attitude indicator!. Down lower, if traffic is an issue, then I'm leaning towards some kind of TPAS - like device. I'm waiting for one with a good aural cue (I think there is one out now). Any comments from current TPAS users out there? Kirk 66 |
kirk.stant wrote:
Ramy wrote: Meanwhile, at least in the US, our only option is the 30 years old technology of transponders, which are relatively effordable for most pilots I see flying at the Reno area. Ramy, what if the collision had been between an older Learjet, not equipped with TCAS, and not talking to ATC (in the process of being handed off, talking to FSS, or just tooling around VFR. Do they actually do that? And why would they want to, as long as they had radar coverage? I'm having a hard time imagining a professional jet pilot flying around at 300 knots that wouldn't want to be talking to ATC, especially with passengers. I'm not questioning your advice on TPAS units, just wondering how likely your scenario is. The TPAS units would also work with the average Cessna, which is certainly doesn't have TCAS, and even more likely to be without ATC contact. -- Change "netto" to "net" to email me directly Eric Greenwell - Washington State, USA www.motorglider.org - Download "A Guide to Self-launching Sailplane Operation" |
I've just started flying with a Mode C transponder and have been
alerted a couple of times of approaching traffic when it started replying to frequent interrogations. I was able to locate these aircraft visually. Clearly an alert system would be an inexpensive and valuable asset. Having the right of way in a glider is about as useful as having right of way in a sailboat when you're about to be run over by a mega container ship (which has also happened to me). Large aircraft (and vessels) just might not see you and, even if they do, can't avoid you becasue of their mass and speed. I'd just like to steer clear of conflict, which includes alerting others to my presence and learning about theirs. Good grief, there are still folks in the USA (including some well-known glider FBOs) that fly without radios, let alone transponders. Mike |
Flarm is, Flarm to Flarm. Up to now it is mainly fitted to gliders,
practically universal in the European Alps, and widely fitted in Australia. In the Swiss Alps it is also fitted to rescue helicopters, partly because of its obstacle database. ADS-B out can be read by ADS-B in. In Australia they are working on the idea that an enhancement to ADS-B could enable it to read Flarm, and an enhancement to Flarm could enable it to read ADS-B. This is why things may improve when Mode A/C and Mode S are phased out in favour of ADS-B. In Australia Flarm is built under licence (OzFlarm), there are other licensees. Is there nobody interested in doing this in the USA ? It would surely be ideal for any light aircraft. I understand that there is an add-on to Flarm which can sound a signal in headphones. Remember, Modes A/C and S are only transmitted when the Transponder is triggered by an interrogation. Flarm and ADS-B transmit regularly without having to be triggered. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "kirk.stant" wrote in message ups.com... Ramy wrote: Meanwhile, at least in the US, our only option is the 30 years old technology of transponders, which are relatively affordable for most pilots I see flying at the Reno area. snip TPAS is a good solution, since it warns you of someone else tooling around with his xponder on. ADS-B would be nice, if affordable/practicable in a glider. FLARM is pretty much only glider-to-glider, and requires active participation (and is a moot point in the US anyway, at present). snip Kirk 66 |
Are there any low cost ADS-B units available?
Mike Schumann "W.J. (Bill) Dean (U.K.)." wrote in message ... Flarm is, Flarm to Flarm. Up to now it is mainly fitted to gliders, practically universal in the European Alps, and widely fitted in Australia. In the Swiss Alps it is also fitted to rescue helicopters, partly because of its obstacle database. ADS-B out can be read by ADS-B in. In Australia they are working on the idea that an enhancement to ADS-B could enable it to read Flarm, and an enhancement to Flarm could enable it to read ADS-B. This is why things may improve when Mode A/C and Mode S are phased out in favour of ADS-B. In Australia Flarm is built under licence (OzFlarm), there are other licensees. Is there nobody interested in doing this in the USA ? It would surely be ideal for any light aircraft. I understand that there is an add-on to Flarm which can sound a signal in headphones. Remember, Modes A/C and S are only transmitted when the Transponder is triggered by an interrogation. Flarm and ADS-B transmit regularly without having to be triggered. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "kirk.stant" wrote in message ups.com... Ramy wrote: Meanwhile, at least in the US, our only option is the 30 years old technology of transponders, which are relatively affordable for most pilots I see flying at the Reno area. snip TPAS is a good solution, since it warns you of someone else tooling around with his xponder on. ADS-B would be nice, if affordable/practicable in a glider. FLARM is pretty much only glider-to-glider, and requires active participation (and is a moot point in the US anyway, at present). snip Kirk 66 |
Hmm, the glider is thermalling - probably the easiest thing in the air
to see from another aircraft approaching. So much for professional pilots looking out the window. If the glider had been cruising I could understand it. I've lost gliders I've been following when I knew where they were. But there is little excuse in a two-crew cockpit to miss something as substantial as an 18 meter glider thermalling in front of you! In the AF we called it clearing your flightpath. Everything else is secondary at jet speeds. Good job getting the jet and it's valuable pax back unharmed. Love the pic of the glider spar in the radome! But I would love to hear the crew admit they were heads-down at the time of the collision, if that is what really happened. Of course, I could be totally wrong - sun, bugs on the canopy, etc... And this assumes the glider was actually turning, of course. Well, it's better than trying to take off on the wrong runway, anyway... Check 6, guys! (and 9, and 3, and 12, and...) Kirk 66 |
kirk.stant wrote:
Hmm, the glider is thermalling - probably the easiest thing in the air to see from another aircraft approaching. So much for professional pilots looking out the window. If the glider had been cruising I could understand it. I've lost gliders I've been following when I knew where they were. But there is little excuse in a two-crew cockpit to miss something as substantial as an 18 meter glider thermalling in front of you! A thermalling glider should be able to see approaching aircraft more easily, too. Quite different from being run down by a faster aircraft coming up behind. We probably shouldn't be too smug at this point, until we know the facts for sure. -- Change "netto" to "net" to email me directly Eric Greenwell - Washington State, USA www.motorglider.org - Download "A Guide to Self-launching Sailplane Operation" |
VQ-1's P4M-1Q crash off China - 1956 | Mike | Naval Aviation | 0 | May 6th 06 11:13 PM |
Yet another A36 crash | H.P. | Piloting | 10 | April 23rd 05 05:58 PM |
Seniors Contest | Bob Fidler | Soaring | 68 | March 17th 05 03:50 AM |
Sport Pilot - School Won't Offer | Gary G | Piloting | 38 | February 16th 05 10:41 AM |
Announce/USA: FAA Glider Flying Handbook / Bob Wander | SoarBooks | Soaring | 0 | August 11th 03 03:55 PM |
